path: root/arch/arm/boot/dts/imx7d-sdb-epdc.dts
2017-02-23MLK-12035 dts: imx7d-sdb-revb: add i.MX7d sdb revb supportFugang Duan
Base on i.MX7d sdb revb board change list, below modules has changed: - enet2 and epdc enable pin - usb_otg2 pwr enable pin - ov5647_mipi pwr pin - tsc2046 touch pendown pin - uart5 tx/rx pins - sensor INT pin - pcie power is controlled by por_b, not gpio_spi pin6 - hdmi audio change to SAI3 from SAI1 The patch add the changes for revb, and keep the original functions for reva board. Remove redundancy sim and enet dts files to avoid excessive dts file for reva and revb. After the patch, there have below diff: - default dts file: imx7d-sdb.dts for revb board, imx7d-sdb-reva.dts for reva board - remove enet, sim extended dts files, so these modules are enabled in default dts file for reva and revb board. The change of expanded dts due to pin confliction: - Keep the original expanded name of dts file for revb board, add suffix "-reva" in dts file name for reva board. - Like: hdmi/codec audio: hdmi audio and wm8960 codec are enabled in default dts file for revb board, no extended dts files to separate them. Keep original extended dts files for reva board: imx7d-sdb-reva-hdmi-audio.dts imx7d-sdb-reva-wm8960.dts epdc: imx7d-sdb-epdc.dts is for revb board, imx7d-sdb-reva-epdc.dts is for reva board. gpmi-weim: imx7d-sdb-gpmi-weim.dtsi for revb, imx7d-sdb-reva-gpmi-weim.dtsi for reva. m4: imx7d-sdb-m4.dts for revb, imx7d-sdb-reva-m4.dts for reva. qspi: imx7d-sdb-qspi.dts for revb, imx7d-sdb-reva-qspi.dts for reva. touchscreen: imx7d-sdb-touch.dts for revb, imx7d-sdb-reva-touch.dts for reva. Cherry picked from commit: 2be1a236696d, and disable sai3 since there have many Transmit underrun on kernel 4.1. Signed-off-by: Fugang Duan <B38611@freescale.com> Acked-by: Robby Cai <robby.cai@nxp.com> Acked-by: Gao Pan <pandy.gao@nxp.com> Acked-by: Peter Chen <peter.chen@freescale.com> Acked-by: Chen Bough <Haibo.Chen@freescale.com> Conflicts: arch/arm/boot/dts/Makefile arch/arm/boot/dts/imx7d-sdb-epdc.dts arch/arm/boot/dts/imx7d-sdb-gpmi-weim.dtsi arch/arm/boot/dts/imx7d-sdb-m4.dts arch/arm/boot/dts/imx7d-sdb-reva-epdc.dts arch/arm/boot/dts/imx7d-sdb-touch.dts arch/arm/boot/dts/imx7d-sdb.dts
2017-02-23MLK-12021 ARM: dts: add sim1 support for imx7d-sdb boardGao Pan
Enable sim1 in imx7d-sdb.dts. To avoid the pin confict with epdc, disable sim1 in imx7d-sdb-epdc.dts. Signed-off-by: Gao Pan <B54642@freescale.com>
2017-02-23MLK-11944-1 ARM: dts: disable sii902x due to pin conflict with EPDCRobby Cai
Disable sii902x to avoid pin conflict Signed-off-by: Robby Cai <r63905@freescale.com>
2017-02-23MLK-11800 dts: imx7d-sdb: correct flexcan stby gpio pinDong Aisheng
According to schematic, the pad used for CAN STBY signal should be EPDC_DATA14, not GPIO1_IO07. So correct it. And due to pin is conflict with epdc, so we also update the imx7d-sdb-epdc.dts. Reported-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> (cherry picked from commit 9036478549729580a89db90835ee5c688acbc282) Conflicts: arch/arm/boot/dts/imx7d-sdb.dts
2017-02-23MLK-11556-6 ARM: dts: imx7d-sdb: add epdc supportRobby Cai
Add epdc support on i.MX7D SDB board Since EPDC has pin conflict with ENET1/2, a new DTS file is added. And EPDC has pin conflict with SIM, so disable SIM by default. Signed-off-by: Robby Cai <r63905@freescale.com>
