path: root/arch/arm/boot/dts/imx7d-sdb-epdc.dtsi
2019-02-12MLK-18626-1 ARM: dts: imx7d-sdb-epdc: Fix pin conflict with can2Leonard Crestez
In upstream the flexcan2 regulator was added with its own pinctrl group and the EPDC_DATA14 pin is claimed even if the can controller is marked as disabled. Mark the regulator itself with status = "disabled" so it won't claim the pin. Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com> Acked-by: Robert Chiras <robert.chiras@nxp.com>
2019-02-12MLK-17603 arm: dts: imx7d-sdb-epdc: enable enet1 for epdc extra dts fileFugang Duan
Enable enet1 for epdc extra dts file since only enet2 has pin conflict with epdc. Reviewed-by: Gao Pan <pandy.gao@nxp.com> Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
2019-02-12MLK-12140 ARM: dts: imx7d-sdb-epdc: add EPDC touch support for imx7d-sdbHaibo Chen
EPDC board has touch screen, this patch add touch support on imx7d-sdb TO1.1 board, due to the touch pin conflict with UART5 and GPMI, so disable UART5 in imx7d-sdb-epdc.dtsi. For GPMI, it default disabled in imx7d-sdb.dts, so do not impact touch. Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
2019-02-12MLK-12035 dts: imx7d-sdb-revb: add i.MX7d sdb revb supportLeonard Crestez
Base on i.MX7d sdb revb board change list, below modules has changed: - enet2 and epdc enable pin - usb_otg2 pwr enable pin - ov5647_mipi pwr pin - tsc2046 touch pendown pin - uart5 tx/rx pins - sensor INT pin - pcie power is controlled by por_b, not gpio_spi pin6 - hdmi audio change to SAI3 from SAI1 The patch add the changes for revb, and keep the original functions for reva board. Remove redundancy sim and enet dts files to avoid excessive dts file for reva and revb. After the patch, there have below diff: - default dts file: imx7d-sdb.dts for revb board, imx7d-sdb-reva.dts for reva board - remove enet, sim extended dts files, so these modules are enabled in default dts file for reva and revb board. The change of expanded dts due to pin confliction: - Keep the original expanded name of dts file for revb board, add suffix "-reva" in dts file name for reva board. - Like: hdmi/codec audio: hdmi audio and wm8960 codec are enabled in default dts file for revb board, no extended dts files to separate them. Keep original extended dts files for reva board: imx7d-sdb-reva-hdmi-audio.dts imx7d-sdb-reva-wm8960.dts epdc: imx7d-sdb-epdc.dts is for revb board, imx7d-sdb-reva-epdc.dts is for reva board. gpmi-weim: imx7d-sdb-gpmi-weim.dtsi for revb, imx7d-sdb-reva-gpmi-weim.dtsi for reva. m4: imx7d-sdb-m4.dts for revb, imx7d-sdb-reva-m4.dts for reva. qspi: imx7d-sdb-qspi.dts for revb, imx7d-sdb-reva-qspi.dts for reva. touchscreen: imx7d-sdb-touch.dts for revb, imx7d-sdb-reva-touch.dts for reva. Cherry picked from commit: 2be1a236696d, and disable sai3 since there have many Transmit underrun on kernel 4.1. Signed-off-by: Fugang Duan <B38611@freescale.com> Acked-by: Robby Cai <robby.cai@nxp.com> Acked-by: Gao Pan <pandy.gao@nxp.com> Acked-by: Peter Chen <peter.chen@freescale.com> Acked-by: Chen Bough <Haibo.Chen@freescale.com> Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
