Boards based on imx7 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx7s.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 29988e867cb17de7119e971f9acfad2c3fccdb47)
arch/arm/boot/dts/imx7d-cl-som-imx7.dts
arch/arm/boot/dts/imx7d-colibri-emmc.dtsi
arch/arm/boot/dts/imx7d-colibri.dtsi
arch/arm/boot/dts/imx7d-nitrogen7.dts
arch/arm/boot/dts/imx7d-pico.dtsi
arch/arm/boot/dts/imx7d-sdb.dts
arch/arm/boot/dts/imx7s-colibri.dtsi
arch/arm/boot/dts/imx7s-warp.dts
arch/arm/boot/dts/imx7s.dtsi
This makes it possible to enable earlycon for debugging by just passing
an empty "earlycon" argument on the kernel command-line.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Acked-by: Ye Li <ye.li@nxp.com>
Add property "cap-power-off-card" to fix the module loadable issue.
Reviewed-by: Frank Li <frank.li@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Add wifi bcm4339 support with fmac driver.
This was removed by upstream commit 5eaeaccdaedb
("ARM: dts: imx7d-sdb: Pass 'enable-gpios' and 'power-supply' properties")
That commit claims that GPIO1_IO01 is not a PWM because it's connected
to a pin labelled "PWREN" of J14 connector. However that pin does behave
as a pwm despite the name.
The exact same pattern happens with imx6ul-evk which has an LCD8000-43T
display on J901.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Upstream modified imx7s.dtsi pwm to have #pwm-cells = <3> so now our
out-of-tree boards need to be modified to use 3 cells.
See commit 9be48d2d9881 ("ARM: dts: imx7: use 3 PWM cells")
Review-by: Liu Ying <victor.liu@nxp.com>
Two different regulators are defined with the same name and label but
distinct properties.
The first definition was added with the first board dts and the second
was added when upstream added flexcan support.
Looking at schematics it is indeed gpio2 14 connected to the STB pin of
the CAN transceiver so remove the first definition. This also makes it
consisent with imx_4.9.y.
The second definition entirely overrides the first so this already
worked and this patch results in no DTB change, just a cleanup.
This reverts commit d8236af53074c61b7f88af773357f3cdcf378a9d.
The mxsfb driver uses old bindings so we need to provide those.
The LCD timings were already upstreamed but then an upstream commit
removed them in favor of adding a DRM path. Making mxsfb work requires
reverting this upstream commit
Acked-by: Robert Chiras <robert.chiras@nxp.com>
Change the pcie phy region in dts accordingly.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Add clock parents and rates for enet_axi and enet_phy in dts via
the asigned-parents and assigned-rates attributes.
These were previously set in the ccm driver via set_parent/set_rate
calls but that has been removed in upstream linux.
Signed-off-by: Adriana Reus <adriana.reus@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
in previous version, the property 'csi-mux-mipi' is used to set GPR for MIPI
mode, but on some SoC like iMX8MQ (reuse the CSI) there's no GPR MUX setting
for it.
Add a new property 'fsl,mipi-mode' and check this first for the mode.
If it's MIPI mode, then parse 'csi-mux-mipi'.
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Reviewed-by: Sandor Yu <Sandor.yu@nxp.com>
For the slot support SD3.0 card, during system suspend, if plug out
the sd card, and insert another SD3.0 card, after system resume back,
SD3.0 card can't be recognised as SD3.0 card, just SD2.0 card.
This is bause the time delay between vmmc regulator off and on is
too small, this patch add the oo-on-delay in vmmc-supply regulator,
to assign proper delay value.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Add BT modem device reset node.
The Linux kernel regulator core implementation does not accept negative
voltage values; all negative values are treated as errors.
The problem with the EPDC is that the panel uses a negative voltage
regulator which fails to be enabled by the regulator core. This issue has
slipped up until the 4.9 rebase because the voltage range [min, max] was
checked against only when min = max. This has been fixed in 4.9, resulting
in errors in the VCOM regulator driver.
The fix is to use the negative values when communicating with the hardware,
but send only positive values to the regulator core.
This patch sends the absolute value to the regulator core and transforms
the received value (from the regulator core) to negative one before sending
it to hardware.
Fix device tree to deal with negative voltage regulator values by setting
min_value = -real_max_value and vice versa. Boards affected:
- imx6dl-sabresd
- imx6ull-14x14-ddr3-arm2
- imx7d-12x12-lpddr3-arm2
- imx7d-sdb
- imx6sll-evk
- imx6sl-evk
- imx6sll-lpddr3-arm2
Signed-off-by: Cristina Ciocan <cristina-mihaela.ciocan@nxp.com>
add imx7d pcie phy node into 7d dts
Change the hardware reset gpio to 'GPIO6_IO15' for mipi dsi to
allow fec2 and mipi dsi can run at the same time. This needs
some hardware rework as follows:
1. Replace R631 with 100K resistor;
2. Remove D14, D24;
3. Solder the Cathode of the diode to R471,
you can use BAT54HT1(ONSEMI) or NSR0320MW2T1G(ONSEMI);
4. Solder the wire to the Anode end of the diode;
5. Scrape the solder mask(Green oil) of the MIPI Reset via,
then solder the end of the wire to the via.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
deferred probe
The assert gpio comes from 'gpio_spi' module, so the framebuffer
depends on the 'gpio_spi' driver loading. And in the case that
the framebuffer driver is loaded earlier than the 'gpio_spi'
driver, the gpio asserting will fail. So handle this gpio in
the framebuffer driver and add deferred probed support.
According to the 7d sdb schematic, only when the 'LCD_PWR_EN' is
low voltage, the 'LCD_3V3' can has the 3.3V voltage. And 'LCD_3V3'
is used to provide 3.3V power for lcd peripherals.
PAD_GPIO1_IO01 bit[31:7] are reserved, remove the setting mapping to
this reserved field.
Add csis-clk-settle property to imx7D SDB mipi csi.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
ov5647 mipi camera sensor is replaced by ov5640
on imx7D SDB RevB board.
bcmdhd can't support removing host during suspend and
driver crash when detect card after resume due to no response
to CMD7.
It looks bcmdhd has a special requirement to enumerate card
by itself which is incompatible with current MMC core.
So implement post-cd feature to allow driver to detect card
as it wants, then we add back non-removable capability
to avoid MMC core to redetect card after resume.
root@imx6qdlsolo:~# echo standby > /sys/power/state
PM: Syncing filesystems ... done.
PM: Preparing system for standby sleep
Freezing user space processes ... (elapsed 0.001 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
PM: Entering standby sleep
evbug: Event. Dev: input3, Type: 0, Code: 0, Value: 1
evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 1
PM: suspend of devices complete after 652.363 msecs
PM: suspend devices took 0.660 seconds
PM: late suspend of devices complete after 1.148 msecs
PM: noirq suspend of devices complete after 1.043 msecs
Disabling non-boot CPUs ...
CPU1: shutdown
Enabling non-boot CPUs ...
CPU1 is up
PM: noirq resume of devices complete after 0.534 msecs
PM: early resume of devices complete after 0.553 msecs
evbug: Event. Dev: input2, Type: 1, Code: 116, Value: 1
evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
evbug: Event. Dev: input2, Type: 1, Code: 116, Value: 0
mmc1: error -110 during resume (card was removed?)
PM: resume of devices complete after 605.525 msecs
PM: resume devices took 0.610 seconds
PM: Finishing wakeup.
Restarting tasks ... done.
WARNING: driver bcmsdh_sdmmc did not remove its interrupt handler!
root@imx6qdlsolo:~# Unable to handle kernel NULL pointer dereference at virtual address 0000022c
pgd = 80004000
[0000022c] *pgd=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP ARM
Modules linked in: bcmdhd evbug ov5647_camera_mipi mxc_mipi_csi mx6s_capture
CPU: 1 PID: 780 Comm: kworker/u4:4 Not tainted 4.1.15-01434-g70f4b36 #1310
Hardware name: Freescale i.MX7 Dual (Device Tree)
Workqueue: kmmcd mmc_rescan
task: a974af80 ti: a846e000 task.ti: a846e000
PC is at _raw_spin_lock_irqsave+0x1c/0x5c
LR is at get_parent_ip+0x10/0x2c
pc : [<8077b9d4>] lr : [<8005207c>] psr: 60050093
sp : a846fc20 ip : 0001001f fp : a800b000
r10: 00000000 r9 : 00000001 r8 : 0000022c
r7 : 00000002 r6 : 0000022c r5 : a0050013 r4 : 0000022c
r3 : a974af80 r2 : 00000001 r1 : a846fc44 r0 : 00000000
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: a951406a DAC: 00000015
Process kworker/u4:4 (pid: 780, stack limit = 0xa846e210)
Stack: (0xa846fc20 to 0xa8470000)
fc20: 00000000 a846fc50 a846fc44 80061808 00000000 000001dc 00000000 805037fc
fc40: 8d89d5ec 00000000 a974af80 80053e88 00000000 00000000 ab7293c0 00000000
fc60: 7f09c828 000000c9 7f09c828 a916a804 00000001 0001001f a800b000 7f0698a4
fc80: a974afc8 00000001 00000000 00000000 00012ebc a974af80 00000001 80ad46c0
fca0: a974af80 00000000 a8eeccc0 00000001 0001001f a846fd04 00000000 7f099440
fcc0: a800b000 7f0699c4 a846fcdf 00000000 00000001 7f068834 a937c900 0105c688
fce0: a846fd04 a8e20000 00000000 00000001 00000000 7f071f08 a846fd04 a80a0000
fd00: ffffffff 00000000 ffffffff a8e20000 a8e20000 00000000 7f099440 00000000
fd20: 00000000 7f099440 a800b000 7f072f4c a974af80 00000000 00000000 80778564
fd40: a846fd54 a9346550 80330028 00000001 a846e000 a8e20000 7f099440 00000000
fd60: 18005000 a8eeccc0 00000000 7f099440 a800b000 7f073744 a846fd8c 80052130
fd80: a9273898 00000000 a800b000 a8e20000 7f099440 00000001 a8eec200 a9270000
fda0: 00000000 7f099440 a800b000 7f07cd3c 80b81100 8040003f a800b000 00000000
fdc0: 00000000 a8e20000 7f099440 a9270000 a9273000 a9270000 00000000 7f099440
fde0: a800b000 7f02df4c 00000001 a8e20000 7f099440 a8eec200 00000000 a916e008
fe00: 00000000 a90bfb00 a800b000 7f074cbc a9270000 7f099440 a8e20000 00000000
fe20: a8f81610 7f0765ec 7f0765b0 a8eeccc0 a855df40 7f069310 a916a800 a8eec200
fe40: 7f09b414 7f06a950 7f06a908 a8f81608 a8f81600 8050e8b8 a8f81608 7f09b414
fe60: 80b22c70 80379744 a974af80 a8f8163c a8f81608 803797d4 00000005 a81ce930
fe80: a8f81608 8037923c a8f81608 a8f81608 80b93cf4 80376504 a846fea0 800e0e3c
fea0: 00000000 00000000 a8f81608 000000bd a833f000 00000000 00000000 8050ed04
fec0: 00000001 8050dd8c 400f8c0f a833f000 ffffff92 a833f000 a81ce600 8050de30
fee0: 8050ddbc a833f240 a833f1dc 80506048 a90bfb00 a833f240 a800b000 a81ce600
ff00: 00000000 800462f0 a81ce600 80043c94 00000000 a800b000 a90bfb18 a800b014
ff20: a846e000 00000088 80b39379 a90bfb00 a800b000 8004654c 80ad4100 a800b164
ff40: a90bfb00 00000000 a84856c0 a90bfb00 80046500 00000000 00000000 00000000
ff60: 00000000 8004b1e8 2df9acc7 00000000 b5f3ff89 a90bfb00 00000000 00000000
ff80: a846ff80 a846ff80 00000000 00000000 a846ff90 a846ff90 a846ffac a84856c0
ffa0: 8004b10c 00000000 00000000 8000f568 00000000 00000000 00000000 00000000
ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 ecd61557 f82769f5
[<8077b9d4>] (_raw_spin_lock_irqsave) from [<80061808>] (add_wait_queue+0x20/0x48)
[<80061808>] (add_wait_queue) from [<805037fc>] (__mmc_claim_host+0x58/0x1b0)
[<805037fc>] (__mmc_claim_host) from [<7f0698a4>] (sdioh_request_byte+0x1cc/0x2a4 [bcmdhd])
[<7f0698a4>] (sdioh_request_byte [bcmdhd]) from [<7f0699c4>] (sdioh_cfg_write+0x20/0x28 [bcmdhd])
[<7f0699c4>] (sdioh_cfg_write [bcmdhd]) from [<7f068834>] (bcmsdh_cfg_write+0x90/0xdc [bcmdhd])
[<7f068834>] (bcmsdh_cfg_write [bcmdhd]) from [<7f071f08>] (dhdsdio_clk_kso_enab+0x38/0x168 [bcmdhd])
[<7f071f08>] (dhdsdio_clk_kso_enab [bcmdhd]) from [<7f072f4c>] (dhdsdio_clk_devsleep_iovar+0xf4/0x5f4 [bcmdhd])
[<7f072f4c>] (dhdsdio_clk_devsleep_iovar [bcmdhd]) from [<7f073744>] (dhdsdio_bussleep+0x2f8/0x4dc [bcmdhd])
[<7f073744>] (dhdsdio_bussleep [bcmdhd]) from [<7f07cd3c>] (dhd_bus_stop+0x2e8/0x3f0 [bcmdhd])
[<7f07cd3c>] (dhd_bus_stop [bcmdhd]) from [<7f02df4c>] (dhd_detach+0x2a4/0x438 [bcmdhd])
[<7f02df4c>] (dhd_detach [bcmdhd]) from [<7f074cbc>] (dhdsdio_release+0x4c/0x1dc [bcmdhd])
[<7f074cbc>] (dhdsdio_release [bcmdhd]) from [<7f0765ec>] (dhdsdio_disconnect+0x3c/0xa0 [bcmdhd])
[<7f0765ec>] (dhdsdio_disconnect [bcmdhd]) from [<7f069310>] (bcmsdh_remove+0x3c/0x60 [bcmdhd])
[<7f069310>] (bcmsdh_remove [bcmdhd]) from [<7f06a950>] (bcmsdh_sdmmc_remove+0x48/0x60 [bcmdhd])
[<7f06a950>] (bcmsdh_sdmmc_remove [bcmdhd]) from [<8050e8b8>] (sdio_bus_remove+0x30/0xf8)
[<8050e8b8>] (sdio_bus_remove) from [<80379744>] (__device_release_driver+0x70/0xe4)
[<80379744>] (__device_release_driver) from [<803797d4>] (device_release_driver+0x1c/0x28)
[<803797d4>] (device_release_driver) from [<8037923c>] (bus_remove_device+0xd8/0x104)
[<8037923c>] (bus_remove_device) from [<80376504>] (device_del+0x10c/0x210)
[<80376504>] (device_del) from [<8050ed04>] (sdio_remove_func+0x1c/0x28)
[<8050ed04>] (sdio_remove_func) from [<8050dd8c>] (mmc_sdio_remove+0x40/0x70)
[<8050dd8c>] (mmc_sdio_remove) from [<8050de30>] (mmc_sdio_detect+0x74/0x100)
[<8050de30>] (mmc_sdio_detect) from [<80506048>] (mmc_rescan+0xb8/0x314)
[<80506048>] (mmc_rescan) from [<800462f0>] (process_one_work+0x120/0x330)
[<800462f0>] (process_one_work) from [<8004654c>] (worker_thread+0x4c/0x480)
[<8004654c>] (worker_thread) from [<8004b1e8>] (kthread+0xdc/0xf4)
[<8004b1e8>] (kthread) from [<8000f568>] (ret_from_fork+0x14/0x2c)
Code: f10c0080 e3a00001 ebe359b1 f594f000 (e1943f9f)
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
MMC core pm_notify will re-detect card after system suspend/resume,
regardless of post-cd claim.
Since in current MMC implement, non-removeable card only detects once,
this will break post card detect which happens next.
e.g. when we suspend/resume system first, then load Broadcom wifi module,
we will get below dump:
root@imx6qdlsolo:/mnt/nfs/vte_IMX6QP-Sabre-SD# modprobe bcmdhd firmware_path=/lib/firmware/bcm/ZP_BCM4339/fw_bcmdhd.bin nvram_path=/lib/firmware/bcm/ZP_BCM4339/bcmdhd.ZP.SDIO.cal
dhd_module_init in
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
failed to power up DHD generic adapter, 3 retry left
wifi_platform_bus_enumerate device present 0
-----------[ cut here ]-----------
Kernel BUG at 80513170 [verbose debug info unavailable]
Internal error: Oops - BUG: 0 1 PREEMPT SMP ARM
Modules linked in: bcmdhd ov5642_camera ov5640_camera_mipi_int ov5640_camera_int mxc_v4l2_capture mxc_dcic ipu_bg_overlay_sdc ipu_still v4l2_int_device ipu_prp_enc ipu_csi_enc ipu_fg_overlay_sdc
CPU: 1 PID: 1487 Comm: modprobe Not tainted 4.1.15-1.0.0+g54cf6a2 #1
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
task: a881e3c0 ti: a9152000 task.ti: a9152000
PC is at mmc_sdio_remove+0x7c/0x80
LR is at mmc_sdio_force_remove+0xc/0x34
pc : [<80513170>] lr : [<80513180>] psr: 60030013
sp : a9153d28 ip : 00000000 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 7f0f76e0
r7 : a9153d58 r6 : 00000000 r5 : 00000000 r4 : a83f1800
r3 : 00000000 r2 : 00000000 r1 : 809c02f4 r0 : a83f1800
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 38d7804a DAC: 00000015
Process modprobe (pid: 1487, stack limit = 0xa9152210)
Stack: (0xa9153d28 to 0xa9154000)
3d20: 00000000 7f0c569c a9ffe440 00000003 00000000 7f0c58f4
3d40: a81942c0 8032e33c a8195960 7f0fbf68 00020002 00000000 a9153d58 a9153d58
3d60: fffffdfb 80bc0db4 a81af810 7f0f9518 fffffdfb 00000008 00000000 5624ce5c
3d80: 00000124 80381140 80bc0db4 a81af810 7f0f9518 00000000 00000008 8037f9dc
3da0: a81af810 7f0f9518 a81af844 80b288b0 00000000 8037fbec 00000000 7f0f9518
3dc0: 8037fb60 8037e068 a8025c5c a818fa34 7f0f9518 a20ff280 00000000 8037f16c
3de0: 7f0f0330 a9ffe440 00000000 7f0f9518 a9ffe440 00000000 80bb18f4 803801ec
3e00: 7f0fbf68 a9ffe440 00000000 7f0c5fdc 80b01720 80b01720 a9ffe440 7f11f000
3e20: 00000000 00000001 5624ce5c 80009730 abc7b120 800e316c 000000c8 a9209a00
3e40: 8040003f 00000001 00010000 800b0dfc 000000c8 8040003f abc7dc60 80afc2b0
3e60: abc75880 80afc260 a8001f00 80afe6c0 00000124 800e4944 7f0f9718 00000001
3e80: 7f0f9718 00000001 a9ffeb00 7f0f9718 a9db31c0 8078e47c 7f0f9718 a9db31c0
3ea0: a9153f58 00000001 a9db31c8 80094094 7f0f9724 00007fff 800910d4 00000000
3ec0: 00000000 7f0f9760 00000000 7f0f9860 c0fce8f4 7f0f9724 00000000 8079aa0c
3ee0: c0f07000 000c7944 00b6817a 00000000 0000000e 00000000 00000000 00000000
3f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
3f20: 00000000 00000000 00000000 00000000 00000640 00000000 00000003 01608348
3f40: 0000017b 8000f604 a9152000 00000000 01608270 800944f8 c0f07000 000c7944
3f60: c0fce28c c0f83439 c0f99248 0007aff8 0008f968 00000000 00000000 00000000
3f80: 00000029 0000002a 00000020 00000024 00000015 00000000 01608348 00000073
3fa0: 00000000 8000f480 01608348 00000073 00000003 01608348 00000000 00000000
3fc0: 01608348 00000073 00000000 0000017b 01608218 00000000 00000073 01608270
3fe0: 7e9ab8c0 7e9ab8b0 0001f2c0 76eac340 600d0010 00000003 00000000 00000000
[<80513170>] (mmc_sdio_remove) from [<7f0c58f4>] (dhd_wifi_platform_load+0x180/0x39c [bcmdhd])
[<7f0c58f4>] (dhd_wifi_platform_load [bcmdhd]) from [<80381140>] (platform_drv_probe+0x44/0xac)
[<80381140>] (platform_drv_probe) from [<8037f9dc>] (driver_probe_device+0x174/0x2b4)
[<8037f9dc>] (driver_probe_device) from [<8037fbec>] (__driver_attach+0x8c/0x90)
[<8037fbec>] (__driver_attach) from [<8037e068>] (bus_for_each_dev+0x68/0x9c)
[<8037e068>] (bus_for_each_dev) from [<8037f16c>] (bus_add_driver+0x148/0x1f0)
[<8037f16c>] (bus_add_driver) from [<803801ec>] (driver_register+0x78/0xf8)
[<803801ec>] (driver_register) from [<7f0c5fdc>] (dhd_wifi_platform_register_drv+0x1bc/0x208 [bcmdhd])
[<7f0c5fdc>] (dhd_wifi_platform_register_drv [bcmdhd]) from [<80009730>] (do_one_initcall+0x8c/0x1d4)
[<80009730>] (do_one_initcall) from [<8078e47c>] (do_init_module+0x5c/0x1a8)
[<8078e47c>] (do_init_module) from [<80094094>] (load_module+0x1ba8/0x1e50)
[<80094094>] (load_module) from [<800944f8>] (SyS_finit_module+0x80/0x90)
[<800944f8>] (SyS_finit_module) from [<8000f480>] (ret_fast_syscall+0x0/0x3c)
(cherry picked from commit 2ce993c504798e7fad0910432bd2c6cbd332120d)
Moving fsl,tuning-step property into SoC.dtsi due to it's mainly SoC
dependant. User could also overwrite it in board.dts for special board
requirment.
pinmux settings using GPIO1_IO0[0-7] should use iomuxc_lpsr,
but not iomuxc. If use iomuxc, you will set wrong register
and may impact other functions.
Without this patch, SAI3_MCLK use GPIO1_IO03 pinmux and impacts
QSPI function.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Change GPIO pad setting to control EPDC/ENET signals on REV B board from 0x59
to default one 0x14 in order to remove stripe when do EPDC unit test.
EPDC board has touch screen, this patch add touch support on imx7d-sdb TO1.1
board, due to the touch pin conflict with UART5 and GPMI, so disable UART5 in
imx7d-sdb-epdc.dtsi. For GPMI, it default disabled in imx7d-sdb.dts, so do not
impact touch.
For imx7d-sdb TO1.1 board, the touch interrupt pin no longer conflict
with HDMI, so move touch support is now inside imx7d-sdb.dts. To
compatible with TO1.0 board, still use imx7d-sdb-reva-touch.dts to
support touch.
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
add audio support for imx7d-sdb revb board.
Signed-off-by: Zidan Wang <zidan.wang@freescale.com>
Base on i.MX7d sdb revb board change list, below modules has changed:
- enet2 and epdc enable pin
- usb_otg2 pwr enable pin
- ov5647_mipi pwr pin
- tsc2046 touch pendown pin
- uart5 tx/rx pins
- sensor INT pin
- pcie power is controlled by por_b, not gpio_spi pin6
- hdmi audio change to SAI3 from SAI1
The patch add the changes for revb, and keep the original functions for
reva board. Remove redundancy sim and enet dts files to avoid excessive
dts file for reva and revb.
After the patch, there have below diff:
- default dts file: imx7d-sdb.dts for revb board, imx7d-sdb-reva.dts for reva board
- remove enet, sim extended dts files, so these modules are enabled in default dts
file for reva and revb board.
The change of expanded dts due to pin confliction:
- Keep the original expanded name of dts file for revb board, add suffix "-reva" in dts
file name for reva board.
- Like:
hdmi/codec audio:
hdmi audio and wm8960 codec are enabled in default dts file for revb board,
no extended dts files to separate them.
Keep original extended dts files for reva board:
imx7d-sdb-reva-hdmi-audio.dts
imx7d-sdb-reva-wm8960.dts
epdc:
imx7d-sdb-epdc.dts is for revb board, imx7d-sdb-reva-epdc.dts is for reva board.
gpmi-weim:
imx7d-sdb-gpmi-weim.dtsi for revb, imx7d-sdb-reva-gpmi-weim.dtsi for reva.
m4:
imx7d-sdb-m4.dts for revb, imx7d-sdb-reva-m4.dts for reva.
qspi:
imx7d-sdb-qspi.dts for revb, imx7d-sdb-reva-qspi.dts for reva.
touchscreen:
imx7d-sdb-touch.dts for revb, imx7d-sdb-reva-touch.dts for reva.
Cherry picked from commit: 2be1a236696d, and disable sai3 since there have many
Transmit underrun on kernel 4.1.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Acked-by: Robby Cai <robby.cai@nxp.com>
Acked-by: Gao Pan <pandy.gao@nxp.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Chen Bough <Haibo.Chen@freescale.com>
Enable sim1 in imx7d-sdb.dts. To avoid the pin confict with epdc,
disable sim1 in imx7d-sdb-epdc.dts.
Signed-off-by: Gao Pan <B54642@freescale.com>
According to schematic, the pad used for CAN STBY signal
should be EPDC_DATA14, not GPIO1_IO07. So correct it.
And due to pin is conflict with epdc, so we also update
the imx7d-sdb-epdc.dts.
Reported-by: Peng Fan <Peng.Fan@freescale.com>
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Add gpmi nand support on i.MX7D sdb board.
Signed-off-by: Han Xu <b45815@freescale.com>
During 4.14 rebase found that imx7s.dtsi already has a gpmi-nand node
added by upstream, preferred that one and skipped the definition in
imx7d.dtsi. The definitions differed on clocks.
Update max voltage of SW1A to 3.3V on PF3000, see below datasheet:
http://cache.freescale.com/files/analog/doc/data_sheet/PF3000.pdf?fsrch=1&sr=1&pageNum=1
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit 5cd7d3c5933b052b899183a45fa4be8cdb2a0c69)
Currently the ramp up delay for VDD_SD1 regulator is 1s, the delay
is added in the following patch:
commit 558c8cde973b9b2abf9a69e3be5a887d38185da3
MLK-11277 dts: imx7d-sdb: add ramp up delay for VDD_SD1 regulator
Here we find this delay will also impact the sd1 resume time cost, and
1s is too much for the sd1 resume, so we try to reduce the delay time
of this VDD_SD1 regulator, finally 200ms pass our test.
This patch change the ramp up delay for VDD_SD1 regulator from 1s to
200ms.
(cherry picked from commit 16523e1bd8613c38b8182da36fdae99564980e24)
There's a Broadcom WiFi on usdhc2.
Add this property due to Broadcom WiFi driver needs call wifi_card_detect
function.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
(cherry picked from commit 72015985537b5bd14ac7b0c97860ab26309ad1a1)
Broadcom WiFi requires reset by operating wlreg_on regulator
when doing insmod/rmmod.
Keep wlreg_on will cause card state wrong and unable to re-insmod.
(cherry picked from commit d65683e1d0717fa039ebd4c55562e6ee745354b7)
Add Broadcom WiFi chip BCM4339 on board support.
Need adds a bcmdhd_wlan@0 node for WiFi driver to probe properly.
Upstream already added usdhc2 with a few extra args, kept their
definition.
Upstream added regulator with same gpio but different voltage? Kept
both definitions.
Add epdc support on i.MX7D SDB board
Since EPDC has pin conflict with ENET1/2, a new DTS file is added.
And EPDC has pin conflict with SIM, so disable SIM by default.
Signed-off-by: Robby Cai <r63905@freescale.com>
add sai<->sii902x sound card support for imx7d-sdb board
Add sii902x hdmi driver to imx6sl, imx6sx and imx7d boards.
Signed-off-by: Sandor Yu <R01008@freescale.com>
Add imx v4l2 capture driver.
Add usdhc1 support for SD3.0 and add usdhc3 support for HS400 mode.
enable pcie support on imx7d platforms.
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
add sai<->wm8960 sound card support for imx7d-sdb.
- Add additional pad settiongs for iomuxc_lspr controller
- Move pinctrl_pwm1 to iomuxc_lspr domain
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Fixed for upstream LPSR renaming in 4.14.
Dropped wdog_b change because upstream already handles this nicely.
Enable mpl3115, fxas2100x, fxos8700 sensor.
(cherry picked from commit: 85e2a3f268ce315ea67ef8805f11a1a1266a3e33)
Enable uart5 for GPS
Upstream already added uart6 in 4.14
Enable epxp in device node by default on imx7d-sdb board.
Signed-off-by: Fancy Fang <chen.fang@freescale.com>
Add dts support for sim1 on imx_4.1.y branch.
Signed-off-by: Gao Pan <b54642@freescale.com>
