Add support for Flexcan.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Currently the LCD is turned on thanks to the bootloader initialization.
In order to make the kernel to turn on the LCD on is own, pass the
'enable-gpios' and 'power-supply' properties.
Also, the GPIO1_IO01 is not used as PWM functionality on this board. It is
connected to the PWREN pin of connector J14 and has a GPIO function, so
remove the PWM1 node and change the GPIO1_IO01 IOMUX to GPIO function.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
It is preferred to use the panel compatible string rather than passing the
LCD timming in the device tree.
So pass the "innolux,at043tn24" compatible string to describe the parallel
LCD on this board.
Pass the phy-reset-gpios property so that Ethernet PHYs can go
through a proper reset.
According to mx7sabresd schematics the MIPI CSI/DSI voltage rails
should be 2.8V but the voltage provided is a maximum of 3.3V and
minimum of 1.8V. Providing such a higher voltage might damage the
peripherals and violates the schematic settings.
Signed-off-by: Gautam Bhat <mindentropy@gmail.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
imx7d-sdb has a BCM4339 BT chip connected to UART6.
Add support for it.
imx7d-sdb has a BCM4339 Wifi chip connected to USDHC2.
Add support for it.
While at it, move the WL_REG_ON pin to the correct pinctrl node.
It is not recommended to place the regulator nodes inside 'simple-bus',
so adjust them accordingly.
The motivation for rearranging this is to make it easier to add new
regulator nodes in the future.
Change "WDOD1" to "WDOG1" in watchdog pin names.
Enable PCIe peripheral on this board.
Cc: yurovsky@gmail.com
Cc: Dong Aisheng <aisheng.dong@nxp.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: devicetree@vger.kernel.org
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Add node for U38, a 74LV595PW serial-in shift register that acts as a
GPIO expander on the board.
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
i.MX device tree updates for 4.11:
- New board support: vf610-zii-dev-rev-c, imx6ul-opos6uldev,
imx6ul-isiot, imx6qdl-savageboard, imx6q-mccmon6.
- A patch from Alexandre to correct the mangled license text which
has been copied & pasted all over the i.MX device tree files.
- Update cpu nodes of some i.MX SoCs to make them consistent and match
ePAPR spec.
- Add OCOTP device for i.MX6UL SoC.
- Add security violation interrupt for i.MX25 DryIce.
- Enable USB OTG, WIFI and Bluetooth support for i.MX6SX Udoo Neo
board.
- Enable S/PDIF and 2nd display pipeline support for CompuLab board..
- Add SPI and LTC3676 PMIC support for Gateworks Ventana boards.
- A few random device addition for various boards: TVE DAC regulators
for imx53-qsb, EEPROM for vf610-zii-dev, eMMC and NAND support for
i.MX6UL Engicam boards.
- Cleanups on obsoleted or unused properties.
* tag 'imx-dt-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (32 commits)
ARM: dts: udoo_neo: Add Bluetooth support
ARM: dts: udoo_neo: Add Wifi support
ARM: dts: udoo_neo: Add UDOO Neo USB OTG1 and OTG2 support
ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL NAND initial support
ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL eMMC initial support
ARM: dts: imx6qdl: Fix "ERROR: code indent should use tabs where possible"
ARM: dts: vf610-zii-dev: add EEPROM entry to Rev C
ARM: dts: add Armadeus Systems OPOS6UL and OPOS6ULDEV support
ARM: dts: imx6q-utilite-pro: enable 2nd display pipeline
ARM: dts: vf610-zii-dev: Add .dts file for rev. C
ARM: dts: vf610-zii-dev-rev-b: Remove leftover PWM pingroup
ARM: dts: imx6: Support Savageboard quad
ARM: dts: imx6: Support Savageboard dual
ARM: dts: imx6: Add Savageboard common file
ARM: dts: imx53-qsb: Provide the TVE DAC regulators
ARM: dts: imx6q: Add mccmon6 board support
Doc: devicetree: bindings: Add vendor prefix entry - lwn
ARM: dts: imx/vf: Correct license text
ARM: dts: imx25.dtsi: DryIce security violation interrupt
ARM: dts: imx: Add ocotp node for imx6ul
The i.MX7 has two iomux controllers. the iomuxc and the iomuxc_lpsr.
In a board dts we have to make sure that both controllers are supplied
with the correct pins. It's way too easy to do this wrong since only
a look into the reference manual can reveal which pins belong to which
controller. To make this clearer add "LPSR" to the pin names which
belong to the LPSR controller.
The watchdog pin and the pwm output pin are controlled by the
iomuxc_lpsr, not the regular iomux, so move the pins there.
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Fix misspelled "ti,x-plate-ohms" property name of TI TSC2046
touchscreen controller.
Fixes: d09e6beafa23 ("ARM: dts: imx7d-sdb: Add support for touchscreen")
The base device tree uses KEY_POWER in the snvs-powerkey node,
hence include the input.h header file in the base device tree.
Signed-off-by: Stefan Agner <stefan@agner.ch>
The i.MX 7Solo implements a subset of features available on
i.MX 7Dual. Recreate imx7s.dtsi as the base device tree for
i.MX 7Dual boards. The i.MX 7Dual's additional features over
i.MX 7Solo are:
- Second Cortex-A7 core
- Second Gigabit Ethernet controller
- EPD (Electronc Paper Display, not yet part of the device tree)
- PCIe (not yet part of the device tree)
- Additional USB2.0 OTG controller
The i.MX 7 series currently consists of two SoCs: i.MX 7Solo and
7Dual. The former has a subset of features of the latter, hence
use imx7s.dtsi as the new base device tree. To keep diffstat nice,
just move imx7d.dtsi to imx7s.dtsi temporarily and recreate
imx7d.dtsi in a second commit.
Add support for tsc2046 touchscreen.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Add support for the LCD8000-43T display.
imx7d-sdb has WDOG1_B pin connected to the PMIC.
Pass the 'fsl,ext-reset-output' property so that the watchdog
can trigger a system POR reset via the PMIC.
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean
property to enable the wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Add ADC support for imx7d-sdb board.
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
Enable fec1 and fec2 for i.MX7d-sdb board.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Add support for USBOTG1 and USBOTG2.
Acked-by: Peter Chen <peter.chen@freescale.com>
imx7d-sdb board has a eMMC5.0 on usdhc3. This eMMC support HS400.
This patch add usdhc3 support for HS400
Acked-by: Dong Aisheng <aisheng.dong@freescale.com>
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
add imx7d sdb board support
Signed-off-by: Frank Li <Frank.Li@freescale.com>
