Add i.MX 7 APBH DMA and GPMI NAND modules.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Han Xu <han.xu@nxp.com>
Make the syscon-poweroff driver change only the shutdown bits on the
SNVS_LP control register.
This change fixes an issue with the RTC wakeup alarm, that was
previously disabled during power off.
Signed-off-by: Guy Shapiro <guy.shapiro@mobi-wize.com>
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The PWM driver has now capability to specify the PWM polarity
which is e.g. for backlight control. Allow to make use of PWM
polarity by specifying pwm-cells to be 3 in the base dt.
List GPR block as compatible "fsl,imx6q-iomuxc-gpr" to support drivers
requesting it that way (PCIe driver is one example).
Cc: yurovsky@gmail.com
Cc: Dong Aisheng <aisheng.dong@nxp.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: devicetree@vger.kernel.org
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Add node for GPC and specify as a parent interrupt controller for SoC bus.
Now that support for 'anatop-enable-bit' has been added to ANADIG
driver, reintroduce 'anatop-enable-bit' for all applicable LDOs.
The USDHC instances need the USDHC NAND and IPG clock in order to
operate. Reference them properly by replacing the dummy clocks with
the actual clocks.
Note that both clocks are currently implicitly enabled since they
are part of the i.MX 7 clock drivers init_on list. This might
change in the future.
Acked-by: Dong Aisheng <aisheng.dong@nxp.com>
System Reset Controller in i.MX7 doesn't have any commonality with IP
block found in i.MX5 and i.MX6 SoC families. Given that and the new
upstream driver for i.MX7 variant (see
https://lkml.org/lkml/2017/2/21/466) remove "fsl,imx51-src" from
compatibility string.
Enable ocotp for i.mx7D/S.
Correct the clock entry and compatible string.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Property 'anatop-enable-bit' does not exist, so just remove it.
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
The eLCDIF IP of the i.MX 7 SoC knows multiple clocks and lists them
separately:
Clock Clock Root Description
apb_clk MAIN_AXI_CLK_ROOT AXI clock
pix_clk LCDIF_PIXEL_CLK_ROOT Pixel clock
ipg_clk_s MAIN_AXI_CLK_ROOT Peripheral access clock
All of them are switched by a single gate, which is part of the
IMX7D_LCDIF_PIXEL_ROOT_CLK clock. Hence using that clock also for
the AXI bus clock (clock-name "axi") makes sure the gate gets
enabled when accessing registers.
There seem to be no separate AXI display clock, and the clock is
optional. Hence remove the dummy clock.
This fixes kernel freezes when starting the X-Server (which
disables/re-enables the display controller).
Fixes: e8ed73f691bd ("ARM: dts: imx7d: add lcdif support")
Acked-by: Shawn Guo <shawnguo@kernel.org>
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
To establish a connection between GPIO controllers and pin multiplexor
controller add gpio-ranges properties to all GPIO controllers found
on iMX50, iMX6Q/D, iMX6DL/S, iMX6SL, iMX6SX, iMX6UL and iMX7D/S
SoCs. The change was done after human parsing of output from
% gawk -n '{ sub(/.*__/, ""); if ($1 ~ "^GPIO") print $1, $2/4}' imxXX-pinfunc.h | sort -n
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Add clock-frequency property to CPU nodes. Avoids warnings like
"/cpus/cpu@0 missing clock-frequency property".
Only i.MX 7Dual SoC supports CPU frequencies of up to 1GHz. The i.MX
7Solo can run with up to 800MHz and does so without making use of DVFS
usually. While the device tree clearly specified a too fast operating
point for i.MX 7Solo, the kernel did not used it in practise so far
because the CPUfreq driver does not get loaded on i.MX 7Solo devices
(since the fsl,imx7s compatible string is not in the list of devices
making use of the cpufreq-dt driver...).
Add the three SAI ports nodes.
Add a SDMA entry in the dtsi file.
The i.MX 7 as a GICv2, hence its CPU interface register map (the
second register region) is 8kB long. Add the VGIC maintenance
interrupt which allows to use the new VGIC driver.
Suggested-by: Marc Zyngier <marc.zyngier@arm.com>
Since we have a SoC level node we should make use of it and have
all nodes which are within the SoC, inside that node. This also
saves an extra interrupt-parent properties. While at it, also
order the Coresight nodes according to register addresses.
The base device tree uses KEY_POWER in the snvs-powerkey node,
hence include the input.h header file in the base device tree.
The i.MX 7Solo implements a subset of features available on
i.MX 7Dual. Recreate imx7s.dtsi as the base device tree for
i.MX 7Dual boards. The i.MX 7Dual's additional features over
i.MX 7Solo are:
- Second Cortex-A7 core
- Second Gigabit Ethernet controller
- EPD (Electronc Paper Display, not yet part of the device tree)
- PCIe (not yet part of the device tree)
- Additional USB2.0 OTG controller
The i.MX 7 series currently consists of two SoCs: i.MX 7Solo and
7Dual. The former has a subset of features of the latter, hence
use imx7s.dtsi as the new base device tree. To keep diffstat nice,
just move imx7d.dtsi to imx7s.dtsi temporarily and recreate
imx7d.dtsi in a second commit.
