2015-08-16 | ARM: dts: keystone: fix dt bindings to use post div register for mainpll | Murali Karicheri | |
commit c1bfa985ded82cacdfc6403e78f329c44e35534a upstream. All of the keystone devices have a separate register to hold post divider value for main pll clock. Currently the fixed-postdiv value used for k2hk/l/e SoCs works by sheer luck as u-boot happens to use a value of 2 for this. Now that we have fixed this in the pll clock driver change the dt bindings for the same. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2014-07-08 | ARM: dts: keystone: fix netcp's clocks definitions | Grygorii Strashko | |
The clocks tree for Keystone 2 NTCP devices should be defined as following: [refclk] - board dependent |- <papllclk> - PLL clock |- <paclk13> - fixed factor clock div=3 mul=1 |- <clkpa> - gated clock |- <clkcpgmac> - gated clock |- <clksa> - gated clock Hence, update Keystone 2 DT to follow HW specification. Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> | |||
2014-02-26 | ARM: dts: keystone: add support for K2 Lamarr SoC and EVM | Murali Karicheri | |
Keystone2 Lamarr (K2L) is a dual Cortex A15 core based SoC with 4 DSPs. It has standard peripherals such as i2c, spi, uart, timer, pcie etc., similar to k2hk, but different set of wireless hardware. This patch add support for k2 Lamarr SoC and EVM. This re-uses the common keystone.dtsi to include common bindings across the various k2 devices. Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> |
