path: root/arch/arm/boot/dts/keystone-k2e-evm.dts
2016-08-31ARM: dts: keystone: specify usb mode explicitlyGrygorii Strashko
The USB OTG mode is not supported by Kestone 2 devices, as result, the USB devices enumeration and detection will not work properly when kernel is built with CONFIG_USB_DWC3_DUAL_ROLE=y (default for multi platform build): - it's required to load gadget drivers manually to make host mode work and this confuses current Keystone 2 users - device mode is not working, because port can't detect and switch to peripheral/host mode dynamically. Hence, specify usb mode explicitly in DT: usb0 = "host" for all KS2 devices and usb1 = "peripheral" for K2E. Cc: Sekhar Nori <nsekhar@ti.com> Cc: Roger Quadros <rogerq@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2016-04-13ARM: dts: k2*: Rename the k2* files to keystone-k2* filesNishanth Menon
As reported in [1], rename the k2* dts files to keystone-* files this will force consistency throughout. Script for the same (and hand modified for Makefile and MAINTAINERS files): for i in arch/arm/boot/dts/k2* do b=`basename $i`; git mv $i arch/arm/boot/dts/keystone-$b; sed -i -e "s/$b/keystone-$b/g" arch/arm/boot/dts/*[si] done NOTE: bootloaders that depend on older dtb names will need to be updated as well. [1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2 Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
