A CMA memory pool reserved memory node is added, and is attached
to the DSP node through the 'memory-region' property on the K2G
ICE board. This area will be used for allocating virtio rings and
buffers. This node allows the DSP Memory Protection and Address
Extension (MPAX) module to be configured properly for the DSP
processor, and matches the values used on the other Keystone 2
boards for software compatibility.
The reserved memory node and the user DSP node are also marked
okay to enable the DSP on the K2G ICE board.
Signed-off-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
