A common CMA memory pool reserved memory node is added, and is attached
to all the DSP nodes through the 'memory-region' property on the 66AK2H
EVM board. This area will be used for allocating virtio rings and buffers.
The common node allows the DSP Memory Protection and Address Extension
(MPAX) module to be configured uniformly across all the DSP processors.
The reserved memory node and all the user DSP nodes are also marked okay
to enable the DSPs on the 66AK2K EVM board.
Signed-off-by: Sam Nelson <sam.nelson@ti.com>
Signed-off-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
The USB OTG mode is not supported by Kestone 2 devices, as result, the
USB devices enumeration and detection will not work properly when
kernel is built with CONFIG_USB_DWC3_DUAL_ROLE=y (default for multi
platform build):
- it's required to load gadget drivers manually to make host mode
work and this confuses current Keystone 2 users
- device mode is not working, because port can't detect and switch to
peripheral/host mode dynamically.
Hence, specify usb mode explicitly in DT: usb0 = "host" for all KS2
devices and usb1 = "peripheral" for K2E.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Roger Quadros <rogerq@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
As reported in [1], rename the k2* dts files to keystone-* files
this will force consistency throughout.
Script for the same (and hand modified for Makefile and MAINTAINERS
files):
for i in arch/arm/boot/dts/k2*
do
b=`basename $i`;
git mv $i arch/arm/boot/dts/keystone-$b;
sed -i -e "s/$b/keystone-$b/g" arch/arm/boot/dts/*[si]
done
NOTE: bootloaders that depend on older dtb names will need to be
updated as well.
[1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2
Reported-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Nishanth Menon <nm@ti.com>
