path: root/arch/arm/boot/dts/keystone-k2hk-netcp.dtsi
2017-01-19ARM: keystone: dts: fix netcp clocks and add namesMurali Karicheri
Fix the pa clock to point to the clkpa which has clock rate of 1/3 of PA PLL clock and add clock names. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2016-04-13ARM: dts: k2*: Rename the k2* files to keystone-k2* filesNishanth Menon
As reported in [1], rename the k2* dts files to keystone-* files this will force consistency throughout. Script for the same (and hand modified for Makefile and MAINTAINERS files): for i in arch/arm/boot/dts/k2* do b=`basename $i`; git mv $i arch/arm/boot/dts/keystone-$b; sed -i -e "s/$b/keystone-$b/g" arch/arm/boot/dts/*[si] done NOTE: bootloaders that depend on older dtb names will need to be updated as well. [1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2 Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
