git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into next/dt
Merge "ARM: dts: Keystone DTS for 4.9" from Santosh Shilimkar
Add K2G nodes for GPIO, IRQ and Message Manager
* tag 'keystone_dts_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone:
ARM: dts: keystone-k2g: Add Message Manager node
ARM: dts: keystone-k2g: Add DSP GPIO controller node
ARM: dts: keystone-k2g: Add keystone IRQ controller node
ARM: dts: keystone-k2g: Add device state controller node
ARM: dts: keystone: specify usb mode explicitly
The USB OTG mode is not supported by Kestone 2 devices, as result, the
USB devices enumeration and detection will not work properly when
kernel is built with CONFIG_USB_DWC3_DUAL_ROLE=y (default for multi
platform build):
- it's required to load gadget drivers manually to make host mode
work and this confuses current Keystone 2 users
- device mode is not working, because port can't detect and switch to
peripheral/host mode dynamically.
Hence, specify usb mode explicitly in DT: usb0 = "host" for all KS2
devices and usb1 = "peripheral" for K2E.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Roger Quadros <rogerq@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
Revert commit 51d5d12b8f3d ("ARM: keystone: dts: add psci command
definition"), which was inadvertently added twice.
Cc: Russell King - ARM Linux <linux@armlinux.org.uk>
Cc: Vitaly Andrianov <vitalya@ti.com>
This commit adds definition for cpu_on, cpu_off and cpu_suspend
commands. These definitions must match the corresponding PSCI
definitions in boot monitor.
Having those command and corresponding PSCI support in boot monitor
allows run time CPU hot plugin.
Link: http://lkml.kernel.org/r/E1b8koV-0004Hf-2j@rmk-PC.armlinux.org.uk
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Cc: Pratyush Anand <panand@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Simon Horman <horms@verge.net.au>
Now that Keystone PCIe controller supports error interrupt handling
add interrupt property to PCI controller DT bindings to enable
error interrupt handling.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
The PCI DT bindings contain a bogus entry for IO space which is not
supported on Keystone. The current bogus entry has an invalid size
and throws following error during boot.
[0.420713] keystone-pcie 21021000.pcie: error -22: failed to map
resource [io 0x0000-0x400000003fff]
So remove it from the dts. While at it also add a bus-range
value that eliminates following log at boot up.
[0.420659] No bus range found for /soc/pcie@21020000, using [bus 00-ff]
This commit adds definition for cpu_on, cpu_off and cpu_suspend commands.
These definitions must match the corresponding PSCI definitions in
boot monitor.
Having those command and corresponding PSCI support in boot monitor allows
Add aliases for SPI nodes, this is required to probe the SPI devices in
U-Boot.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Update the compatible flags to allow specific SoC identification.
Signed-off-by: Nishanth Menon <nm@ti.com>
Add ti,keystone-spi to the compatible field for the SPI node. This new
entry insures that the proper prescaler limit is used for keystone devices
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into fixes
ARM: Couple of Keysyone MDIO DTS fixes for 4.2-rc6+
These are necessary to get the NIC card working on all Keystone
EVMs. Couple of boards are broken without these two fixes.
* tag 'keystone-dts-late-fixes-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone:
ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file
ARM: dts: keystone: fix the clock node for mdio
Currently mdio bindings are defined in keystone.dtsi and this results
in incorrect unit address for the node on K2E and K2L SoCs. Fix this
by moving them to SoC specific DTS file.
Currently the MDIO clock is pointing to clkpa instead of clkcpgmac.
MDIO is part of the ethss and the clock should be clkcpgmac.
Now that PCIe DT binding is disabled in SoC specific DTS,
we need a way to override it in a board specific DTS. So
rename the PCIe nodes accordingly.
Currently PCIe DT bindings are broken. PCIe driver can't function
without having a SerDes driver that provide the phy configuration.
On K2E EVM, this causes problem since the EVM has Marvell SATA
controller present and with default values in the SerDes register,
it seems to pass the PCIe link check, but causes issues since
the configuration is not correct. The manifestation is that when
EVM is booted with NFS rootfs, the boot hangs. We shouldn't enable
PCIe on this EVM since to work, SerDes driver has to be present as
well. So by default, the PCIe DT binding should be disabled in SoC
specific DTS. It can be enabled in the board specific DTS when the
SerDes device driver is also present.
So fix the status of PCIe DT bindings in the SoC specific DTS to
"disabled". To enable PCIe, the status should be set to "ok" in
the EVM DTS file when SerDes driver support becomes available in
the upstream tree.
Add common DT bindings to support PCI controller driver for port 0 on all
of the K2 SoCs that has Synopsis Designware based pcie h/w.
The IO range size is set incorrectly for USB PHY0 deivice
it should be 24 instead of 32. Otherwise, It causes
USB PHY1 probing failure.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Add Keystone IRQ controller IP node which allows ARM
CorePac core to receive signals from DSP cores.
The Keystone 2 has MDIO HW block which are compatible
to Davinci SoCs:
See "Gigabit Ethernet (GbE) Switch Subsystem"
See http://www.ti.com/lit/ug/sprugv9d/sprugv9d.pdf
Hence, add corresponding DT entry for Keystone 2.
Pull part two of ARM SoC updates from Arnd Bergmann:
"This is a small follow-up to the larger ARM SoC updates merged last
week, almost entirely for the keystone platform.
The main change here is to use the new dma-ranges parsing code that
came in through Russell's ARM tree. This allows the keystone platform
to do cache-coherent DMA and to finally support all the available
physical memory when LPAE is enabled.
Aside from this, the keystone reset driver has been rewritten, and
there is a small bug fix to allow building the orion5x platform again"
* tag 'soc2-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: keystone: Drop use of meminfo since its not available anymore
ARM: orion5x: fix mvebu_mbus_dt_init call
ARM: configs: keystone: enable reset driver support
ARM: dts: keystone: update reset node to work with reset driver
ARM: keystone: remove redundant reset stuff
ARM: keystone: Update the dma offset for non-dt platform devices
ARM: keystone: Switch over to coherent memory address space
ARM: configs: keystone: add MTD_SPI_NOR (new dependency for M25P80)
ARM: configs: keystone: drop CONFIG_COMMON_CLK_DEBUG
The pll controller register set and device state control registers
include sets of registers with different purposes, so it's logically
to add syscon entry to be able to access them from appropriate places.
So added pll controller and device state control syscon entries.
The keystone driver requires the next additional properties:
"ti,syscon-pll" - phandle/offset pair. The phandle to syscon used to
access pll controller registers and the offset to use
reset control registers.
"ti,syscon-dev" - phandle/offset pair. The phandle to syscon used to
access device state control registers and the offset
in order to use mux block registers for all watchdogs.
"ti,wdt-list" - option to declare what watchdogs are used to reboot
the SoC, so set "0" WDT as default.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Keystone supports dma-coherent on USB master and also needs
dma-ranges to specify the hardware alias memory range in which DMA
can be operational.
Cc: Olof Johansson <olof@lixom.net>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
The dma-ranges property has to be specified per bus and has format:
< DMA addr > - Base DMA address for Bus (Bus format 32-bits)
< CPU addr > - Corresponding base CPU address (CPU format 64-bits)
< DMA range size > - Size of supported DMA range
SPI nodes should always have #address-cells and #size-cells defined,
otherwise warnings will be produced in case of adding any child
nodes to the SPI bus in DT:
Warning (avoid_default_addr_size): Relying on default #address-cells value for /soc/spi@21000400/n25q128a11@0
Warning (avoid_default_addr_size): Relying on default #size-cells value for /soc/spi@21000400/n25q128a11@0
Hence, ensure that all SPIx nodes have #address-cells and #size-cells
properties defined.
I2C devices are not the part of Keystone SoC and have to be
defined in board DTS files.
Hence, move i2c0 EEPROM device node from Keystone SoC to
k2hk, k2e, k2l EVM files as they all have similar EEPROM SoCs
installed.
I2C nodes should always have #address-cells and #size-cells defined,
otherwise warnings will be produced in case of adding child
nodes to the I2C bus in DT:
Warning (avoid_default_addr_size): Relying on default #address-cells value for /soc/i2c@2530800/pca@20
Warning (avoid_default_addr_size): Relying on default #size-cells value for /soc/i2c@2530800/pca@20
Hence, ensure that all i2cX nodes have #address-cells and #size-cells
properties defined.
This is likely a copy-and-paste error from the
ARM GIC documentation, that has already been fixed.
address-cells should have been set to 0, as with the size
cells. As having those properties set to 0 is the
same thing as not specifying them, drop them completely.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Rob Herring <robh@kernel.org>
Add AEMIF/NAND device entry.
Current keystone.dtsi includes SoC specific definitions for K2HK
SoCs. In order to support two addition keystone devices, k2 Edison
and K2 Lamarr and corresponding EVMs, This patch restructure the
dts files for the following:-
- All clock nodes that are only available in k2hk SoC are moved
from keystone-clocks.dtsi to a new k2hk-clocks.dtsi include file
- The CPU nodes are now part of the soc specific k2hk.dtsi.
- Change the compatibility string to ti,k2hk-evm and change
the model name accordingly
- Finally include k2hk-clocks.dtsi in k2hk.dtsi and that in
k2hk-evm.dts
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Mark Rutland <mark.rutland@arm.com>
This patch adds Keystone GPIO IP device definitions in DT which supports
up to 32 GPIO lines and each GPIO line can be configured as separate
interrupt source (so called "unbanked" IRQ).
For more information see:
http://www.ti.com/lit/ug/sprugv1/sprugv1.pdf
Add keystone timer entry to keystone device tree.
This 64-bit timer is used as backup clock event device.
Add watchdog entry to keystone device tree.
Acked-by: Guenter Roeck <linux@roeck-us.net>
Added device tree support for TI's Keystone USB driver and updated the
Documentation with device tree binding information.
Signed-off-by: WingMan Kwok <w-kwok2@ti.com>
Added device tree support for TI's Keystone USB PHY driver and updated the
Update the Keystone gic device tree entry to add the maintenance
interrupt information.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Update the Keystone gic node to add the GICV and GIGH address space
needed by the KVM.
This patch adds K2 Kepler/Hawking evm (k2hk-evm) specific dts file.
To enable re-use of bindings across multiple evms of this family,
rename current keystone.dts to keystone.dtsi and include it in the
evm specific dts file.
K2 SoC has separate ref clock inputs for various clocks. So add
separate ref clock nodes for ARM, DDR3A, DDR3B and PA PLL input
clocks in k2hk-evm.dts. While at it, rename refclkmain to
refclksys based on device User Guide naming convention
