There is only one valid pinctrl setting for NAND on Kirkwood. Now that we
have the setting in the common SoC pinctrl, move it to the NAND controller
node directly and remove it from the individual boards.
While at it, also fix up status = "okay" to "ok" on one board's NAND node.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-12-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Most boards use the default UART0/1 pinctrl setting without RTS/CTS.
Add the pinctrl setting to the toplevel SoC UART nodes and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level. Currently, both boards using a different UART pinctrl
setting (Openblocks A6, A7) already overwrite the pinctrl node.
While at it, also fix up some status = "ok" to "okay" and again
whitespace issues on mplcec4 uart nodes.
Link: https://lkml.kernel.org/r/1398862602-29595-10-git-send-email-sebastian.hesselbarth@gmail.com
To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
UART devices found on Kirkwood SoCs derive their baudrate from TCLK.
With proper clocks property in the SoCs serial node, boards do not
need to overwrite it anymore.
Remove the remaining clock-frequency property from all Kirkwood boards.
Link: https://lkml.kernel.org/r/1398862602-29595-5-git-send-email-sebastian.hesselbarth@gmail.com
ePAPR allows to reference the device used for console output by
stdout-path property. With node labels for Kirkwood UART0, now
reference it on all Kirkwood boards that already have ttyS0 in
their bootargs property.
While at it, fix some whitespace issues on mplcec4's chosen node
(there are more, but we only fix the chosen node now)
Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
- Add new documents with guidelines for DT binding stability and review
process. This is one of the outcomes of Kernel Summit DT discussions
- Remove a bunch of device_type usage which is only for OF and
deprecated with FDT
- Fix a long standing issue with compatible string match ordering
- Various minor binding documentation updates
* tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt-bindings: add rockchip vendor prefix
serial: vt8500: Add missing binding document for arch-vt8500 serial driver.
dt/bindings: submitting patches and ABI documents
DT: Add vendor prefix for Emerging Display Technologies
of: add vendor prefixe for EPFL
of: add vendor prefix for Gumstix
of: add vendor prefix for Ka-Ro electronics GmbH
devicetree: macb: Document clock properties
dts: bindings: trivial clock bindings doc fixes
of: Fix __of_device_is_available check
dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc
dt/bindings: remove device_type "network" references
dt/bindings: remove users of device_type "mdio"
dt/bindings: Remove references to linux,phandle properties
dt/bindings: Remove all references to device_type "ethernet-phy"
of: irq: Ignore disabled intc's when searching map
of: irq: Ignore disabled interrupt controllers
OF: base: match each node compatible against all given matches first
dt-bindings: add GIC-400 binding
The device_type property is deprecated for the flattened device tree and
the value "ethernet-phy" has never been defined as having a useful
meaning. Neither the kernel nor u-boot depend on it. It should never
have appeared in PHY bindings. This patch removes all references to
"ethernet-phy" as a device_type value from the documentation and the
.dts files.
This patch was generated mechanically with the following command and
then verified by looking at the diff.
sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'`
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
There should be no nodes that are not children of the mbus. Move
the nand node under the mbus, and rework the board .dts files
to use an & reference to the nand node.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of the ocp node, placing it directly
below the mbus. This is a more accurate representation of the hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to
correspond to each MBus window.
In addition, we encode the PCIe memory and I/O apertures in the MBus
node, according to the MBus DT binding specification. The choice made
is 0xe0000000-0xf0000000 for memory space, and 0xf200000-0xf2100000 for
I/O space. These apertures can be changed in each per-board DT file.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Kirkwood boards. Phy nodes are also added with reg property set on a
per-board basis.
This commit converts the Marvell DB-88F6281/DB-88F6282 board to the
Device Tree. In fact, the code was supporting two different boards:
one with the 6281 SoC variant, and one with the 6282 SoC variant. The
difference between the two being that the 6281 has one PCIe interface,
and the 6282 has two PCIe interfaces.
In order to handle that with the Device Tree, we create a
'kirkwood-db.dtsi' file that contains the definitions common to both
boards, and 'kirkwood-db-88f6281.dts' and 'kirkwood-db-88f6282.dts'
for the definitions specific to each board. This is similar to what is
done for the QNAP TS219 Kirkwood platform.
We have kept one single Kconfig option, just like it was before.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
