path: root/arch/arm/boot/dts/kirkwood-guruplug-server-plus.dts
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-23ARM: dts: kirkwood: fix phy-connection-type for GuruplugSebastian Hesselbarth
Commit eeb845459a72e792a959278b858f9c417e9995bd ("ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-id") added phy-connection-type properties to ethernet PHY nodes. Actually, the property has to be set for the ethernet port node instead. Fix it by moving the corresponding properties to the correct nodes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1403555115-13111-1-git-send-email-sebastian.hesselbarth@gmail.com Fixes: eeb845459a72: ('ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-id') Cc: <stable@vger.kernel.org> # v3.16+ Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-idSebastian Hesselbarth
Ethernet PHYs found on Globalscale Guruplug are connected by RGMII-ID. Set the corresponding phy-connection-type property accordingly. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-16-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: set Guruplug ethernet PHY compatibleSebastian Hesselbarth
Ethernet PHY compatible shall be "ethernet-phy-ieee802.3-c22" and "ethernet-phy-idAAAA.BBBB" if PHY OUI id is known. We know it for the PHY found on Guruplug, so set it accordingly. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-15-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: rename pin-controller nodesSebastian Hesselbarth
To prepare pin-controller consolidation, first rename all pinctrl nodes to a more appropriate name regarding ePAPR recommended names. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: remove clock-frequency properties from UART nodesSebastian Hesselbarth
UART devices found on Kirkwood SoCs derive their baudrate from TCLK. With proper clocks property in the SoCs serial node, boards do not need to overwrite it anymore. Remove the remaining clock-frequency property from all Kirkwood boards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-5-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: add stdout-path property to all boardsSebastian Hesselbarth
ePAPR allows to reference the device used for console output by stdout-path property. With node labels for Kirkwood UART0, now reference it on all Kirkwood boards that already have ttyS0 in their bootargs property. While at it, fix some whitespace issues on mplcec4's chosen node (there are more, but we only fix the chosen node now) Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-01-24Merge tag 'devicetree-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: - Add new documents with guidelines for DT binding stability and review process. This is one of the outcomes of Kernel Summit DT discussions - Remove a bunch of device_type usage which is only for OF and deprecated with FDT - Fix a long standing issue with compatible string match ordering - Various minor binding documentation updates * tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: add rockchip vendor prefix serial: vt8500: Add missing binding document for arch-vt8500 serial driver. dt/bindings: submitting patches and ABI documents DT: Add vendor prefix for Emerging Display Technologies of: add vendor prefixe for EPFL of: add vendor prefix for Gumstix of: add vendor prefix for Ka-Ro electronics GmbH devicetree: macb: Document clock properties dts: bindings: trivial clock bindings doc fixes of: Fix __of_device_is_available check dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc dt/bindings: remove device_type "network" references dt/bindings: remove users of device_type "mdio" dt/bindings: Remove references to linux,phandle properties dt/bindings: Remove all references to device_type "ethernet-phy" of: irq: Ignore disabled intc's when searching map of: irq: Ignore disabled interrupt controllers OF: base: match each node compatible against all given matches first dt-bindings: add GIC-400 binding
2014-01-16dt/bindings: Remove all references to device_type "ethernet-phy"Grant Likely
The device_type property is deprecated for the flattened device tree and the value "ethernet-phy" has never been defined as having a useful meaning. Neither the kernel nor u-boot depend on it. It should never have appeared in PHY bindings. This patch removes all references to "ethernet-phy" as a device_type value from the documentation and the .dts files. This patch was generated mechanically with the following command and then verified by looking at the diff. sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'` Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-08ARM: DT: Kirkwood: Use symbolic names from gpio.hAndrew Lunn
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-24ARM: kirkwood: mark guruplug sdio as non-removableSebastian Hesselbarth
Globalscale Guruplug has AW-GH381 WiFi/BT on sdio which is always present and cannot be detected in any way. Therefore, mark the node as non-removable instead of broken-cd. While at it, also put a note about connected WiFi/BT chip above. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Move the nand node under the mbus nodeJason Gunthorpe
There should be no nodes that are not children of the mbus. Move the nand node under the mbus, and rework the board .dts files to use an & reference to the nand node. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-08-06ARM: kirkwood: Use the preprocessor on device tree filesEzequiel Garcia
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: kirkwood: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Kirkwood boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: guruplug: move pinmux configs to the right devicesThomas Petazzoni
When the pinmux mechanism was added in Kirkwood, the device driver core was not yet providing the possibility of attaching pinmux configurations to all devices, drivers had to do it explicitly, and not all drivers were doing this. Now that the driver core does that in a generic way, it makes sense to attach the pinmux configuration to their corresponding devices. This allows the pinctrl subsystem to show in debugfs to which device is related which pins, for example: pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41 pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42 pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43 Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-15ARM: mvebu: Use standard MMC binding for all users of mvsdioSimon Baatz
In order to prepare the switch to the standard MMC device tree parser for mvsdio, adapt all current uses of mvsdio in the dts files to the standard format. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-30ARM: kirkwood: make use of DT mvsdio on guruplug boardSebastian Hesselbarth
Device tree based guruplug boards still use mvsdio platform_data and kirkwood_sdio_init to enable sdio. DT support for sdio is already there, so make use of it. This also fixes mvsdio accidentially breaking nand by configuring mpp0 to gpio, while used also by nand (nand_io2 on mpp0). Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Soeren Moch <smoch@web.de> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: kirkwood: convert Guruplug Server Plus to use the device treeWilly Tarreau
Add a device tree entry for the Guruplug Server Plus board. This port was based both on the work done on the dreamplug and the dockstar. It builds, boots and works on my Guruplug Server Plus. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
