path: root/arch/arm/boot/dts/kirkwood-guruplug-server-plus.dts
2014-06-23ARM: dts: kirkwood: fix phy-connection-type for GuruplugSebastian Hesselbarth
Commit eeb845459a72e792a959278b858f9c417e9995bd ("ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-id") added phy-connection-type properties to ethernet PHY nodes. Actually, the property has to be set for the ethernet port node instead. Fix it by moving the corresponding properties to the correct nodes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1403555115-13111-1-git-send-email-sebastian.hesselbarth@gmail.com Fixes: eeb845459a72: ('ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-id') Cc: <stable@vger.kernel.org> # v3.16+ Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-idSebastian Hesselbarth
Ethernet PHYs found on Globalscale Guruplug are connected by RGMII-ID. Set the corresponding phy-connection-type property accordingly. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-16-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: set Guruplug ethernet PHY compatibleSebastian Hesselbarth
Ethernet PHY compatible shall be "ethernet-phy-ieee802.3-c22" and "ethernet-phy-idAAAA.BBBB" if PHY OUI id is known. We know it for the PHY found on Guruplug, so set it accordingly. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-15-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: rename pin-controller nodesSebastian Hesselbarth
To prepare pin-controller consolidation, first rename all pinctrl nodes to a more appropriate name regarding ePAPR recommended names. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: remove clock-frequency properties from UART nodesSebastian Hesselbarth
UART devices found on Kirkwood SoCs derive their baudrate from TCLK. With proper clocks property in the SoCs serial node, boards do not need to overwrite it anymore. Remove the remaining clock-frequency property from all Kirkwood boards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-5-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: add stdout-path property to all boardsSebastian Hesselbarth
ePAPR allows to reference the device used for console output by stdout-path property. With node labels for Kirkwood UART0, now reference it on all Kirkwood boards that already have ttyS0 in their bootargs property. While at it, fix some whitespace issues on mplcec4's chosen node (there are more, but we only fix the chosen node now) Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-01-24Merge tag 'devicetree-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: - Add new documents with guidelines for DT binding stability and review process. This is one of the outcomes of Kernel Summit DT discussions - Remove a bunch of device_type usage which is only for OF and deprecated with FDT - Fix a long standing issue with compatible string match ordering - Various minor binding documentation updates * tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: add rockchip vendor prefix serial: vt8500: Add missing binding document for arch-vt8500 serial driver. dt/bindings: submitting patches and ABI documents DT: Add vendor prefix for Emerging Display Technologies of: add vendor prefixe for EPFL of: add vendor prefix for Gumstix of: add vendor prefix for Ka-Ro electronics GmbH devicetree: macb: Document clock properties dts: bindings: trivial clock bindings doc fixes of: Fix __of_device_is_available check dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc dt/bindings: remove device_type "network" references dt/bindings: remove users of device_type "mdio" dt/bindings: Remove references to linux,phandle properties dt/bindings: Remove all references to device_type "ethernet-phy" of: irq: Ignore disabled intc's when searching map of: irq: Ignore disabled interrupt controllers OF: base: match each node compatible against all given matches first dt-bindings: add GIC-400 binding
2014-01-16dt/bindings: Remove all references to device_type "ethernet-phy"Grant Likely
The device_type property is deprecated for the flattened device tree and the value "ethernet-phy" has never been defined as having a useful meaning. Neither the kernel nor u-boot depend on it. It should never have appeared in PHY bindings. This patch removes all references to "ethernet-phy" as a device_type value from the documentation and the .dts files. This patch was generated mechanically with the following command and then verified by looking at the diff. sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'` Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-08ARM: DT: Kirkwood: Use symbolic names from gpio.hAndrew Lunn
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-24ARM: kirkwood: mark guruplug sdio as non-removableSebastian Hesselbarth
Globalscale Guruplug has AW-GH381 WiFi/BT on sdio which is always present and cannot be detected in any way. Therefore, mark the node as non-removable instead of broken-cd. While at it, also put a note about connected WiFi/BT chip above. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Move the nand node under the mbus nodeJason Gunthorpe
There should be no nodes that are not children of the mbus. Move the nand node under the mbus, and rework the board .dts files to use an & reference to the nand node. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-08-06ARM: kirkwood: Use the preprocessor on device tree filesEzequiel Garcia
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: kirkwood: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Kirkwood boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: guruplug: move pinmux configs to the right devicesThomas Petazzoni
When the pinmux mechanism was added in Kirkwood, the device driver core was not yet providing the possibility of attaching pinmux configurations to all devices, drivers had to do it explicitly, and not all drivers were doing this. Now that the driver core does that in a generic way, it makes sense to attach the pinmux configuration to their corresponding devices. This allows the pinctrl subsystem to show in debugfs to which device is related which pins, for example: pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41 pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42 pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43 Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-15ARM: mvebu: Use standard MMC binding for all users of mvsdioSimon Baatz
In order to prepare the switch to the standard MMC device tree parser for mvsdio, adapt all current uses of mvsdio in the dts files to the standard format. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-30ARM: kirkwood: make use of DT mvsdio on guruplug boardSebastian Hesselbarth
Device tree based guruplug boards still use mvsdio platform_data and kirkwood_sdio_init to enable sdio. DT support for sdio is already there, so make use of it. This also fixes mvsdio accidentially breaking nand by configuring mpp0 to gpio, while used also by nand (nand_io2 on mpp0). Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Soeren Moch <smoch@web.de> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: kirkwood: convert Guruplug Server Plus to use the device treeWilly Tarreau
Add a device tree entry for the Guruplug Server Plus board. This port was based both on the work done on the dreamplug and the dockstar. It builds, boots and works on my Guruplug Server Plus. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
