path: root/arch/arm/boot/dts/kirkwood-iconnect.dts
2016-04-14ARM: dts: kirkwood: Fixup pcie DT warningsAndrew Lunn
PCIe has a range property, so the unit name should contain an address. Make use of the label to enable individual PCIe busses. Also, fixup the synology dtsi file which added a label pcie2 rather than using the existing pcie1 label. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-04-14ARM: dts: kirkwood: Remove button address and fixup namesAndrew Lunn
The DT compiler is now warning about unit names with addresses but not reg property. Fix all the gpio-key buttons which causes warnings. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2014-05-05ARM: dts: kirkwood: rename pin-controller nodesSebastian Hesselbarth
To prepare pin-controller consolidation, first rename all pinctrl nodes to a more appropriate name regarding ePAPR recommended names. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: add stdout-path property to all boardsSebastian Hesselbarth
ePAPR allows to reference the device used for console output by stdout-path property. With node labels for Kirkwood UART0, now reference it on all Kirkwood boards that already have ttyS0 in their bootargs property. While at it, fix some whitespace issues on mplcec4's chosen node (there are more, but we only fix the chosen node now) Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-01-24Merge tag 'devicetree-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: - Add new documents with guidelines for DT binding stability and review process. This is one of the outcomes of Kernel Summit DT discussions - Remove a bunch of device_type usage which is only for OF and deprecated with FDT - Fix a long standing issue with compatible string match ordering - Various minor binding documentation updates * tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: add rockchip vendor prefix serial: vt8500: Add missing binding document for arch-vt8500 serial driver. dt/bindings: submitting patches and ABI documents DT: Add vendor prefix for Emerging Display Technologies of: add vendor prefixe for EPFL of: add vendor prefix for Gumstix of: add vendor prefix for Ka-Ro electronics GmbH devicetree: macb: Document clock properties dts: bindings: trivial clock bindings doc fixes of: Fix __of_device_is_available check dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc dt/bindings: remove device_type "network" references dt/bindings: remove users of device_type "mdio" dt/bindings: Remove references to linux,phandle properties dt/bindings: Remove all references to device_type "ethernet-phy" of: irq: Ignore disabled intc's when searching map of: irq: Ignore disabled interrupt controllers OF: base: match each node compatible against all given matches first dt-bindings: add GIC-400 binding
2014-01-16dt/bindings: Remove all references to device_type "ethernet-phy"Grant Likely
The device_type property is deprecated for the flattened device tree and the value "ethernet-phy" has never been defined as having a useful meaning. Neither the kernel nor u-boot depend on it. It should never have appeared in PHY bindings. This patch removes all references to "ethernet-phy" as a device_type value from the documentation and the .dts files. This patch was generated mechanically with the following command and then verified by looking at the diff. sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'` Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-08ARM: DT: Kirkwood: Use symbolic names from gpio.hAndrew Lunn
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-12-08ARM: DT: Kirkwood: Use symbolic names from input.hAndrew Lunn
Replace the numeric key value with a symbolic name from <bt-bindings/input/input.h> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-23ARM: mvebu: dts: remove unneeded linux,default-state from led nodesJason Cooper
Generally, power LEDs should indicate when power is applied, and go out once power is removed. _Not_ annoy the developer with migraine-inducing blinking reminicent of some badly animated television series designed to sell sugar to children. On a more serious note, most of these OS-specific properties aren't necessary and should be removed. I left two that are legitimately tying disk LEDs to disk activity. Other than that, we keep the state the bootloader left them in until userspace changes the state via sysfs. Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Move the nand node under the mbus nodeJason Gunthorpe
There should be no nodes that are not children of the mbus. Move the nand node under the mbus, and rework the board .dts files to use an & reference to the nand node. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Remove kirkwood_setup_wins and rely on the DT bindingJason Gunthorpe
kirkwood_setup_wins is the last manual caller of mbus in kirkwood, don't call it for DT boards and rely on the DT having a mbus node with a proper ranges property to setup these windows. Move all the mbus ranges properties for all boards into kirkwood.dtsi, since they are currently all the same. This makes the DT self consistent, since the physical address of the NAND and CRYPTO are both referenced internally. The arbitary Linux constants KIRKWOOD_NAND_MEM_PHYS_BASE and KIRKWOOD_SRAM_PHYS_BASE no longer have to match the DT values. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-08-06ARM: kirkwood: Relocate PCIe device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the PCIe nodes out of the ocp node, placing it directly below the mbus. This is a more accurate representation of the hardware. Moving the PCIe nodes, we now need to introduce an extra cell to encode the window target ID and attribute. Since this depends on the PCIe port, we split the ranges translation entries, to correspond to each MBus window. In addition, we encode the PCIe memory and I/O apertures in the MBus node, according to the MBus DT binding specification. The choice made is 0xe0000000-0xf0000000 for memory space, and 0xf200000-0xf2100000 for I/O space. These apertures can be changed in each per-board DT file. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: kirkwood: Use the preprocessor on device tree filesEzequiel Garcia
2013-07-25ARM: kirkwood: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Kirkwood boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree changes from Arnd Bergmann: "These changes from 30 individual branches for the most part update device tree files, but there are also a few source code changes that have crept in this time, usually in order to atomically move over a driver from using hardcoded data to DT probing. A number of platforms change their DT files to use the C preprocessor, which is causing a bit of churn, but that is hopefully only this once" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits) ARM: at91: dt: rm9200ek: add spi support ARM: at91: dt: rm9200: add spi support ARM: at91/DT: at91sam9n12: add SPI DMA client infos ARM: at91/DT: sama5d3: add SPI DMA client infos ARM: at91/DT: fix SPI compatibility string ARM: Kirkwood: Fix the internal register ranges translation ARM: dts: bcm281xx: change comment to C89 style ARM: mmc: bcm281xx SDHCI driver (dt mods) ARM: nomadik: add the new clocks to the device tree clk: nomadik: implement the Nomadik clocks properly ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency ARM: dts: omap4-panda: Fix DVI EDID reads ARM: dts: omap4-panda: Add USB Host support arm: mvebu: enable mini-PCIe connectors on Armada 370 RD ARM: shmobile: irqpin: add a DT property to enable masking on parent ARM: dts: AM43x EPOS EVM support ARM: dts: OMAP5: Add bandgap DT entry ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone ...
2013-05-27arm: kirkwood: convert Iomega Iconnect to use DT for the PCIe interfaceThomas Petazzoni
Now that the PCIe mvebu driver is usable on Kirkwood, use it instead of the legacy PCIe code, since it allows to describe the PCIe interfaces in the Device Tree. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: iconnect: move pinmux configs to the right devicesThomas Petazzoni
When the pinmux mechanism was added in Kirkwood, the device driver core was not yet providing the possibility of attaching pinmux configurations to all devices, drivers had to do it explicitly, and not all drivers were doing this. Now that the driver core does that in a generic way, it makes sense to attach the pinmux configuration to their corresponding devices. This allows the pinctrl subsystem to show in debugfs to which device is related which pins, for example: pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41 pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42 pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43 Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: iconnect: give meaningful names to pinmux configsThomas Petazzoni
The Kirkwood iConnect Device Tree is currently using totally meaningless names for the pinmux configuration: pmx_gpio_XY. This patch fixes that by using some more meaningful names such as pmx_button_power. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-08ARM: kirkwood: of_serial: fix clock gating by removing clock-frequencyJason Cooper
When DT support for kirkwood was first introduced, there was no clock infrastructure. As a result, we had to manually pass the clock-frequency to the driver from the device node. Unfortunately, on kirkwood, with minimal config or all module configs, clock-frequency breaks booting because of_serial doesn't consume the gate_clk when clock-frequency is defined. The end result on kirkwood is that runit gets gated, and then the boot fails when the kernel tries to write to the serial port. Fix the issue by removing the clock-frequency parameter from all kirkwood dts files. Booted on dreamplug without earlyprintk and successfully logged in via ttyS0. Reported-by: Simon Baatz <gmbnomis@gmail.com> Tested-by: Simon Baatz <gmbnomis@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-24ARM: Kirkwood: Convert iConnect to pinctrl.Andrew Lunn
2012-09-22ARM: Kirkwood: Describe iconnect nand in DT.Arnaud Patard (Rtp)
Define the nand and its partitions in DT and remove them from cmdline Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-22ARM: Kirkwood: Describe iconnect keys in DT.Arnaud Patard (Rtp)
Define the 2 keys found on iconnect in DT. It's also changing the keycodes/ switches to use better ones. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-08-15ARM: Kirkwood: Fix iconnect ledsArnaud Patard (Rtp)
While converting, a led has been missed leading to wrong power blue led definition. Add it back and fix the gpio used on the power blue led. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-07-27ARM: Kirkwood: Describe iConnects LEDs in DT.Andrew Lunn
2012-07-27ARM: Kirkwood: Describe iConnects temperature sensor in DT.Andrew Lunn
Now that we have I2C support in DT, describe the LM63 in the DT file for the iConnect. Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2012-07-25ARM: Kirkwood: Replace mrvl with marvellAndrew Lunn
It has been decided to use marvell, not mrvl, in the compatibility property. Search & replace. Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2012-05-15kirkwood: Add iconnect supportArnaud Patard (Rtp)
Add support for Iomega Iconnect system. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Tested-By: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
