path: root/arch/arm/boot/dts/kirkwood-linkstation-6282.dtsi
2016-02-09ARM: dts: kirkwood: split lswvl dts to linkstation lsvl and lswvlRoger Shimizu
LS-WVL/VL are both kirkwood-6282 based NAS devices, which share many MPP pins. However they are slightly different: - LS-WVL is 2-Bay NAS, and LS-VL is only 1-Bay. - There're two red LED indicator on LS-WVL to show when HDD fails, which is similar to LS-WXL, but there's no such on LS-VL. So after the split, common part goes into .dtsi file: - kirkwood-linkstation-6282.dtsi while all rest part goes into device specific .dts file: - kirkwood-linkstation-lsvl.dts - kirkwood-linkstation-lswvl.dts Signed-off-by: Roger Shimizu <rogershimizu@gmail.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
