path: root/arch/arm/boot/dts/kirkwood-linkstation-lswvl.dts
2017-01-03ARM: dts: mvebu: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-02-09ARM: dts: kirkwood: split lswvl dts to linkstation lsvl and lswvlRoger Shimizu
LS-WVL/VL are both kirkwood-6282 based NAS devices, which share many MPP pins. However they are slightly different: - LS-WVL is 2-Bay NAS, and LS-VL is only 1-Bay. - There're two red LED indicator on LS-WVL to show when HDD fails, which is similar to LS-WXL, but there's no such on LS-VL. So after the split, common part goes into .dtsi file: - kirkwood-linkstation-6282.dtsi while all rest part goes into device specific .dts file: - kirkwood-linkstation-lsvl.dts - kirkwood-linkstation-lswvl.dts Signed-off-by: Roger Shimizu <rogershimizu@gmail.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
