path: root/arch/arm/boot/dts/kirkwood-linkstation-lswxl.dts
2017-01-03ARM: dts: mvebu: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-02-09ARM: dts: kirkwood: split lswxl dts to linkstation lswsxl and lswxlRoger Shimizu
LS-WXL/WSXL are both kirkwood-6281 based 2-Bay NAS devices, which share many MPP pins. However they are slightly different: - There're two red LED indicator on LS-WXL to show when HDD fails, but there's no such on LS-WSXL. - There's 4-level speed adjustable FAN on LS-WXL, but not LS-WSXL. So after the split, common part goes into .dtsi file: - kirkwood-linkstation.dtsi - kirkwood-linkstation-duo-6281.dtsi while all rest part goes into device specific .dts file: - kirkwood-linkstation-lswsxl.dts - kirkwood-linkstation-lswxl.dts Signed-off-by: Roger Shimizu <rogershimizu@gmail.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
