path: root/arch/arm/boot/dts/kirkwood-net5big.dts
2018-03-27arm: dts: kirkwood*.dts: use SPDX-License-Identifier for boards using GPL-2.0Gregory CLEMENT
Follow the recent trend for the license description Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2015-11-03ARM: Kirkwood: add LED DT entries for netxbig boardsSimon Guinot
This patch adds DT entries for the LEDs found on the Kirkwood-based LaCie boards 2Big and 5Big Network v2. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2014-07-13ARM: Kirkwood: allow to use netxbig DTSI for d2net_v2 DTSSimon Guinot
The d2 Network v2 board (d2net_v2) shares a lot of hardware characteristics with the 2Big and 5Big Network v2 boards. This patch prepares the kirkwood-netxbig.dtsi file in order to allow to include it from the d2net_v2 DTS file. The DT nodes only relevant for the 2Big and 5Big Network v2 boards are moved into their respective DTS files. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1404830545-15581-2-git-send-email-simon.guinot@sequanux.org Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-21ARM: kirkwood: fix net5big regulator gpio assignmentsJason Cooper
Late correction from Simon's testing. Reported-by: Simon Guinot <simon.guinot@sequanux.org> Link: https://lkml.kernel.org/r/20140621095001.GW20207@kw.sim.vm.gnt Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-20ARM: Kirkwood: Add DT descriptions for net2big and net5big.Andrew Lunn
Describe LaCie 2Big and 5Big Network v2 using device tree. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1401132591-26305-3-git-send-email-andrew@lunn.ch Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Simon Guinot <simon.guinot@sequanux.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
