The regulator has a reg property so include it in the unit name.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
PCIe has a range property, so the unit name should contain an address.
Make use of the label to enable individual PCIe busses. Also, fixup
the synology dtsi file which added a label pcie2 rather than using the
existing pcie1 label.
Most boards use the default UART0/1 pinctrl setting without RTS/CTS.
Add the pinctrl setting to the toplevel SoC UART nodes and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level. Currently, both boards using a different UART pinctrl
setting (Openblocks A6, A7) already overwrite the pinctrl node.
While at it, also fix up some status = "ok" to "okay" and again
whitespace issues on mplcec4 uart nodes.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-10-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
ePAPR allows to reference the device used for console output by
stdout-path property. With node labels for Kirkwood UART0, now
reference it on all Kirkwood boards that already have ttyS0 in
their bootargs property.
While at it, fix some whitespace issues on mplcec4's chosen node
(there are more, but we only fix the chosen node now)
Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
- Add new documents with guidelines for DT binding stability and review
process. This is one of the outcomes of Kernel Summit DT discussions
- Remove a bunch of device_type usage which is only for OF and
deprecated with FDT
- Fix a long standing issue with compatible string match ordering
- Various minor binding documentation updates
* tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt-bindings: add rockchip vendor prefix
serial: vt8500: Add missing binding document for arch-vt8500 serial driver.
dt/bindings: submitting patches and ABI documents
DT: Add vendor prefix for Emerging Display Technologies
of: add vendor prefixe for EPFL
of: add vendor prefix for Gumstix
of: add vendor prefix for Ka-Ro electronics GmbH
devicetree: macb: Document clock properties
dts: bindings: trivial clock bindings doc fixes
of: Fix __of_device_is_available check
dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc
dt/bindings: remove device_type "network" references
dt/bindings: remove users of device_type "mdio"
dt/bindings: Remove references to linux,phandle properties
dt/bindings: Remove all references to device_type "ethernet-phy"
of: irq: Ignore disabled intc's when searching map
of: irq: Ignore disabled interrupt controllers
OF: base: match each node compatible against all given matches first
dt-bindings: add GIC-400 binding
The device_type property is deprecated for the flattened device tree and
the value "ethernet-phy" has never been defined as having a useful
meaning. Neither the kernel nor u-boot depend on it. It should never
have appeared in PHY bindings. This patch removes all references to
"ethernet-phy" as a device_type value from the documentation and the
.dts files.
This patch was generated mechanically with the following command and
then verified by looking at the diff.
sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'`
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Replace the numeric key value with a symbolic name from
<bt-bindings/input/input.h>
This patch provides some whitespace cleanup for NETGEAR
ReadyNAS Duo v2 and 102 .dts files:
- Fixed bad spaces
- Added some space between nodes to improve readability
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
The patch does some cleanup work on NETGEAR ReadyNAS Duo v2 .dts
file. Changes are listed below:
- Converted from value to macros for GPIO voltage level
- Converted all numeric input key values to macros
- Made button names more explicit
- Document ethernet PHY (Marvell 88E1318) via a comment
- Added header for the file to describe content and author
- Made G762 clock node name unique by including g762 in it
- Fixed all node names and labels to use respectively '-' and '_'
- Changed order of included files from general to local
- Removed useless clocks and gpio-keys properties
Without that fix, at the end of the shutdown process, the board is
still powered (led glowing, fan running, ...).
Generally, power LEDs should indicate when power is applied, and go out
once power is removed. _Not_ annoy the developer with migraine-inducing
blinking reminicent of some badly animated television series designed to
sell sugar to children.
On a more serious note, most of these OS-specific properties aren't
necessary and should be removed. I left two that are legitimately tying
disk LEDs to disk activity. Other than that, we keep the state the
bootloader left them in until userspace changes the state via sysfs.
There should be no nodes that are not children of the mbus. Move
the nand node under the mbus, and rework the board .dts files
to use an & reference to the nand node.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
kirkwood_setup_wins is the last manual caller of mbus in kirkwood, don't
call it for DT boards and rely on the DT having a mbus node with
a proper ranges property to setup these windows.
Move all the mbus ranges properties for all boards into kirkwood.dtsi,
since they are currently all the same.
This makes the DT self consistent, since the physical address of the
NAND and CRYPTO are both referenced internally. The arbitary Linux
constants KIRKWOOD_NAND_MEM_PHYS_BASE and KIRKWOOD_SRAM_PHYS_BASE
no longer have to match the DT values.
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
From Jason Cooper:
mvebu dt changes for v3.12
- kirkwood
- add ZyXEL NSA310 board, fan for ReadyNAS Duo v2
- mvebu
- add ReadyNAS 102 board
- misc dts updates and changes.
v2:
- dropped mv64xxx-i2c change
* tag 'dt-3.12' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Fix the Armada 370/XP timer compatible strings
ARM: mvebu: use dts pre-processor for readynas 102
ARM: kirkwood: use dts pre-processor for nsa310 boards
ARM: mvebu: use correct #interrupt-cells instead of #interrupts-cells
ARM: Kirkwood: Add support for another ZyXEL NSA310 variant
ARM: mvebu: Add Netgear ReadyNAS 102 board
arm: kirkwood: readynas duo v2: Add GMT G762 Fan Controller
arch/arm/boot/dts/kirkwood-nsa310.dts
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of the ocp node, placing it directly
below the mbus. This is a more accurate representation of the hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to
correspond to each MBus window.
In addition, we encode the PCIe memory and I/O apertures in the MBus
node, according to the MBus DT binding specification. The choice made
is 0xe0000000-0xf0000000 for memory space, and 0xf200000-0xf2100000 for
I/O space. These apertures can be changed in each per-board DT file.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Kirkwood boards. Phy nodes are also added with reg property set on a
per-board basis.
Now that GMT G762 PWM Fan Controller is available upstream, let's add
missing bindings in Netgear ReadyNAS Duo v2 .dts file.
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
Now that the mvebu-pcie driver is in place and enabled for kirkwood,
convert to initializing PCIe via devicetree.
When the pinmux mechanism was added in Kirkwood, the device driver
core was not yet providing the possibility of attaching pinmux
configurations to all devices, drivers had to do it explicitly, and
not all drivers were doing this.
Now that the driver core does that in a generic way, it makes sense to
attach the pinmux configuration to their corresponding devices.
This allows the pinctrl subsystem to show in debugfs to which device
is related which pins, for example:
pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41
pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42
pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Add support for NETGEAR ReadyNAS Duo v2 (Hardware specs available
here: http://natisbad.org/NAS/). Almost everything is supported via
provided .dts. A board-readynas.c file is nonetheless required for
device not only converted to DT (Gbit controller).
Tested-By: Arnaud Ebalard <arno@natisbad.org>
