path: root/arch/arm/boot/dts/kirkwood-ns2.dts
2015-08-28ARM: Kirkwood: add modes-map property to ns2-leds nodesVincent Donnefort
Since the LED modes mapping is no longer hardcoded inside the leds-ns2 driver, then it must be provided through the modes-map property in the ns2-leds nodes. Signed-off-by: Vincent Donnefort <vdonnefort@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-08-06ARM: kirkwood: Use the preprocessor on device tree filesEzequiel Garcia
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: kirkwood: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Kirkwood boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: ns2: move pinmux configs to the right devicesThomas Petazzoni
When the pinmux mechanism was added in Kirkwood, the device driver core was not yet providing the possibility of attaching pinmux configurations to all devices, drivers had to do it explicitly, and not all drivers were doing this. Now that the driver core does that in a generic way, it makes sense to attach the pinmux configuration to their corresponding devices. This allows the pinctrl subsystem to show in debugfs to which device is related which pins, for example: pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41 pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42 pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43 Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: kirkwood: DT board setup for Network Space v2 and parentsSimon Guinot
This patch adds DT board setup for LaCie Network Space v2 and parents, based on the Marvell Kirkwood 6281 SoC. This includes Network Space v2 (Max) and Internet Space v2. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
