Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Kirkwood boards. Phy nodes are also added with reg property set on a
per-board basis.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
When the pinmux mechanism was added in Kirkwood, the device driver
core was not yet providing the possibility of attaching pinmux
configurations to all devices, drivers had to do it explicitly, and
not all drivers were doing this.
Now that the driver core does that in a generic way, it makes sense to
attach the pinmux configuration to their corresponding devices.
This allows the pinctrl subsystem to show in debugfs to which device
is related which pins, for example:
pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41
pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42
pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
LaCie has released two products under the CloudBox name. The
netspace_mini_v2 machine is embedded in the oldest product. The cloudbox
machine is embedded in the newest one. In order to allow a CloudBox user
to select the right machine support, this patch adds some informations
to the netspace_mini_v2 Kconfig description. A comment is also added to
the dts file.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
This patch adds DT board setup for the LaCie NAS Network Space Mini v2
(aka SafeBox). The hardware characteristics are very close to those of
the Network Space Lite v2. The main difference are:
- A GPIO fan which is only available on the NS2 Mini.
- A single USB host port is wired on the NS2 Mini. The NS2 Lite provides
an additional dual-mode USB port (host/device).
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
