Most Kirkwood boards use the default SPI0 pinctrl setting anyway. Add a
default pinctrl setting to the toplevel SoC SPI0 node and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level.
Currently, only T5325 is using a different setting and already
overwrites the corresponding pinctrl node.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-11-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
ePAPR allows to reference the device used for console output by
stdout-path property. With node labels for Kirkwood UART0, now
reference it on all Kirkwood boards that already have ttyS0 in
their bootargs property.
While at it, fix some whitespace issues on mplcec4's chosen node
(there are more, but we only fix the chosen node now)
Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com
Mechanically translate rd88f6192-nas-setup.c into DT equivelent.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
