path: root/arch/arm/boot/dts/kirkwood-rd88f6281-a.dts
2017-01-19ARM: dts: kirkwood-rd88f6281: Utilize new DSA bindingFlorian Fainelli
Utilize the new DSA binding, introduced with commit 8c5ad1d6179d ("net: dsa: Document new binding"). The legacy binding node is kept included, but is marked disabled. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-04-14ARM: dts: kirkwood: Remove address from dsa unit nameAndrew Lunn
The dsa node does not have a reg property, so remove the address from the unit name. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2014-09-13ARM: Kirkwood: Fix DT based DSA.Andrew Lunn
During the conversion of boards to use DT to instantiate Distributed Switch Architecture, nobody volunteered to test. As to be expected, the conversion was flawed. Testers and access to hardware has now become available, and this patch hopefully fixes the problems. dsa,mii-bus must be a phandle to the top level mdio node, not the port specific subnode of the mdio device. dsa,ethernet must be a phandle to the port subnode within the ethernet DT node, not the ethernet node. Don't pinctrl hog the card detect gpio for mvsdio. Rename the .dts files to make it clearer which file is for the Z0 stepping and which for the A0 or later stepping. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Cc: seugene@marvell.com Tested-by: Eugene Sanivsky <seugene@marvell.com> Fixes: e2eaa339af44: ("ARM: Kirkwood: convert rd88f6281-setup.c to DT.") Fixes: e7c8f3808be8: ("ARM: kirkwood: Convert mv88f6281gtw_ge switch setup to DT") Cc: <stable@vger.kernel.org> #v3.15+ Link: https://lkml.kernel.org/r/1409592941-22244-1-git-send-email-andrew@lunn.ch Signed-off-by: Jason Cooper <jason@lakedaemon.net>
