path: root/arch/arm/boot/dts/kirkwood-ts419-6281.dts
2014-02-05ARM: Kirkwood: Add DT description of QNAP 419Andrew Lunn
Re-implement the Marvell Kirkwood ts41x-setup.c in DT. As with the QNAP 119, there are two variants, depending on which SoC has been used. They differ on Ethernet PHY addresses and number of PCIe busses. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Ian Campbell <ijc@hellion.org.uk> (kirkwood-ts419-6281.dtb) Signed-off-by: Jason Cooper <jason@lakedaemon.net>
