2016-04-14 | ARM: dts: kirkwood: Fixup pcie DT warnings | Andrew Lunn | |
PCIe has a range property, so the unit name should contain an address. Make use of the label to enable individual PCIe busses. Also, fixup the synology dtsi file which added a label pcie2 rather than using the existing pcie1 label. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> | |||
2014-02-05 | ARM: Kirkwood: Add DT description of QNAP 419 | Andrew Lunn | |
Re-implement the Marvell Kirkwood ts41x-setup.c in DT. As with the QNAP 119, there are two variants, depending on which SoC has been used. They differ on Ethernet PHY addresses and number of PCIe busses. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Ian Campbell <ijc@hellion.org.uk> (kirkwood-ts419-6281.dtb) Signed-off-by: Jason Cooper <jason@lakedaemon.net> |
