Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The mbus node has a ranges property.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Fix audio on kirkwood-openrd-client:
1) The audio-controller was left disabled.
2) The probe fails because cs42l51 is missing #sound-dai-cells.
/sound/simple-audio-card,codec: could not get #sound-dai-cells for /ocp@f1000000/i2c@11000/cs42l51@4a
asoc-simple-card sound: parse error -22
asoc-simple-card: probe of sound failed with error -22
3) The mapping is incorrect:
asoc-simple-card sound: cs42l51-hifi <-> spdif mapping ok
should be:
asoc-simple-card sound: cs42l51-hifi <-> i2s mapping ok
Reported-by: Rick Thomas <rbthomas@pobox.com>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Rick Thomas <rbthomas@pobox.com>
Explicitly use the SoC specific compatible strings in kirkwood.dtsi and
dove.dtsi, so that the crypto devices have access to the TDMA feature
when attached to the new CESA driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
The new bindings split the crypto and sram node in two separate devices.
Modify the existing crypto nodes to match the new representation.
During the conversion of boards to use DT to instantiate Distributed
Switch Architecture, nobody volunteered to test. As to be expected,
the conversion was flawed. Testers and access to hardware has now
become available, and this patch hopefully fixes the problems.
dsa,mii-bus must be a phandle to the top level mdio node, not the port
specific subnode of the mdio device.
dsa,ethernet must be a phandle to the port subnode within the ethernet
DT node, not the ethernet node.
Don't pinctrl hog the card detect gpio for mvsdio.
Rename the .dts files to make it clearer which file is for the Z0
stepping and which for the A0 or later stepping.
Cc: seugene@marvell.com
Tested-by: Eugene Sanivsky <seugene@marvell.com>
Fixes: e2eaa339af44: ("ARM: Kirkwood: convert rd88f6281-setup.c to DT.")
Fixes: e7c8f3808be8: ("ARM: kirkwood: Convert mv88f6281gtw_ge switch setup to DT")
Cc: <stable@vger.kernel.org> #v3.15+
Link: https://lkml.kernel.org/r/1409592941-22244-1-git-send-email-andrew@lunn.ch
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The sound node is missing a #sound-dai-cells property. Add it, so that
the sounds node can be used in combination with the simple-audio-card
binding.
Link: https://lkml.kernel.org/r/1399141819-23924-5-git-send-email-andrew@lunn.ch
There is only one valid pinctrl setting for I2C0 on Kirkwood. Now that we
have the setting in the common SoC pinctrl, move it to the I2C0 controller
node directly and remove it from the individual boards.
While at it, also fix up status = "okay" to "ok" on one board's I2C0 node.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-13-git-send-email-sebastian.hesselbarth@gmail.com
There is only one valid pinctrl setting for NAND on Kirkwood. Now that we
have the setting in the common SoC pinctrl, move it to the NAND controller
While at it, also fix up status = "okay" to "ok" on one board's NAND node.
Link: https://lkml.kernel.org/r/1398862602-29595-12-git-send-email-sebastian.hesselbarth@gmail.com
Most Kirkwood boards use the default SPI0 pinctrl setting anyway. Add a
default pinctrl setting to the toplevel SoC SPI0 node and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level.
Currently, only T5325 is using a different setting and already
overwrites the corresponding pinctrl node.
Link: https://lkml.kernel.org/r/1398862602-29595-11-git-send-email-sebastian.hesselbarth@gmail.com
Most boards use the default UART0/1 pinctrl setting without RTS/CTS.
Add the pinctrl setting to the toplevel SoC UART nodes and put a note
on board level. Currently, both boards using a different UART pinctrl
setting (Openblocks A6, A7) already overwrite the pinctrl node.
While at it, also fix up some status = "ok" to "okay" and again
whitespace issues on mplcec4 uart nodes.
Link: https://lkml.kernel.org/r/1398862602-29595-10-git-send-email-sebastian.hesselbarth@gmail.com
On Kirkwood, there is only one valid pinctrl setting for GBE1. With
a common SoC pinctrl node, we can now set it in the node instead of
in each board file.
Link: https://lkml.kernel.org/r/1398862602-29595-9-git-send-email-sebastian.hesselbarth@gmail.com
All SoCs have the same pinctrl setting for NAND, UART0/1, SPI, TWSI0,
and GBE1. Move it to the common pinctrl node that we now have.
Link: https://lkml.kernel.org/r/1398862602-29595-8-git-send-email-sebastian.hesselbarth@gmail.com
All Kirkwood SoCs have their pinctrl registers at the same address.
Instead of replaying the same reg property on each SoC, have the
reg property set in the common SoC file already. This also allows
us to move common pinctrl settings to this node later on.
Link: https://lkml.kernel.org/r/1398862602-29595-7-git-send-email-sebastian.hesselbarth@gmail.com
This adds missing node labels to Kirkwood common and SoC specific nodes
to allow to reference them more easily.
Link: https://lkml.kernel.org/r/1398862602-29595-3-git-send-email-sebastian.hesselbarth@gmail.com
When using platform_driver instantiation, the i2c bus was given bus
number 0. The kirkwood-t5325 audio driver has this bus number hard
coded for the address of the codec. However by default device tree i2c
busses are dynamically allocated a bus number, starting from 1. Thus
the kirkwood-t5325 cannot find its audio codec. By adding an alias in
the DT file we can control the bus number and set it to 0. The codec
can then be found.
The binding has existed for a while, so add the missing node so it can
be used by devices.
Make use of the mvebu system controller, by placing a node into the
dtsi file.
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Now that the Feroceon L2 cache has a DT binding, make use of it.
In order to support multiplatform builds the watchdog devicetree binding
was modified and now the 'reg' property is specified to need two
entries. This commit adds the second entry as-per the new specification.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
- Add new documents with guidelines for DT binding stability and review
process. This is one of the outcomes of Kernel Summit DT discussions
- Remove a bunch of device_type usage which is only for OF and
deprecated with FDT
- Fix a long standing issue with compatible string match ordering
- Various minor binding documentation updates
* tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt-bindings: add rockchip vendor prefix
serial: vt8500: Add missing binding document for arch-vt8500 serial driver.
dt/bindings: submitting patches and ABI documents
DT: Add vendor prefix for Emerging Display Technologies
of: add vendor prefixe for EPFL
of: add vendor prefix for Gumstix
of: add vendor prefix for Ka-Ro electronics GmbH
devicetree: macb: Document clock properties
dts: bindings: trivial clock bindings doc fixes
of: Fix __of_device_is_available check
dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc
dt/bindings: remove device_type "network" references
dt/bindings: remove users of device_type "mdio"
dt/bindings: Remove references to linux,phandle properties
dt/bindings: Remove all references to device_type "ethernet-phy"
of: irq: Ignore disabled intc's when searching map
of: irq: Ignore disabled interrupt controllers
OF: base: match each node compatible against all given matches first
dt-bindings: add GIC-400 binding
device_type is deprecated and the kernel doesn't require it in most
cases. The only exceptions for flat tree users are the "gianfar",
"ucc_geth" and "ibm,emac" bindings, and arguably that requirement could
be relaxed for ucc_geth and ibm,emac (that is a task for separate
patches though).
This patch removes references to device_type="network" from the binding
documentation where possible and removes the properties from ARM and
microblaze dts files. This patch does not modify the powerpc .dts files
since there are a much larger number of them affected and I think the
ucc_geth, ibm,emac and gianfar users should be addressed before clearing
out the references to reduce the chance of breakage.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Michal Simek <monstr@monstr.eu>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Add nodes for the two SATA PHYs on kirkwood.
Add node for the one SATA PHY on Dove.
Add pHandles to the PHYs in the sata nodes.
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
This has caused merge conflicts in the past.
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Replace the numeric key value with a symbolic name from
<bt-bindings/input/input.h>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
From Tony Lindgren:
Changes needed to prepare for making omap3 device tree only:
- Always build in board-generic, and add pdata quirks and auxdata
support for it so we have all the pdata related quirks
in the same place.
- Merge of the drivers/pinctrl changes that are needed for PM
to continue working on omap3 and also needed for other omaps
eventually. The three pinctrl related patches have been acked
by Linus Walleij and are pulled into both the pinctrl tree
and this branch.
- Few defconfig related changes for drivers needed.
* tag 'omap-for-v3.13/quirk-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (523 commits)
ARM: configs: omap2plus_defconfig: enable dwc3 and dependencies
ARM: OMAP2+: Add WLAN modules and of_serial to omap2plus_defconfig
ARM: OMAP2+: Run make savedefconfig on omap2plus_defconfig to shrink it
ARM: OMAP2+: Add minimal 8250 support for GPMC
ARM: OMAP2+: Use pdata quirks for wl12xx for omap3 evm and zoom3
ARM: OMAP: Move DT wake-up event handling over to use pinctrl-single-omap
ARM: OMAP2+: Add support for auxdata
pinctrl: single: Add support for auxdata
pinctrl: single: Add support for wake-up interrupts
pinctrl: single: Prepare for supporting SoC specific features
ARM: OMAP2+: igep0020: use display init from dss-common
ARM: OMAP2+: pdata-quirks: add legacy display init for IGEPv2 board
+Linux 3.12-rc4
Signed-off-by: Kevin Hilman <khilman@linaro.org>
There should be no nodes that are not children of the mbus. Move
the nand node under the mbus, and rework the board .dts files
to use an & reference to the nand node.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
the crypto node under the mbus.
kirkwood_setup_wins is the last manual caller of mbus in kirkwood, don't
call it for DT boards and rely on the DT having a mbus node with
a proper ranges property to setup these windows.
Move all the mbus ranges properties for all boards into kirkwood.dtsi,
since they are currently all the same.
This makes the DT self consistent, since the physical address of the
NAND and CRYPTO are both referenced internally. The arbitary Linux
constants KIRKWOOD_NAND_MEM_PHYS_BASE and KIRKWOOD_SRAM_PHYS_BASE
no longer have to match the DT values.
There appears to be an error in the second address of the second XOR
engine in the Kirkwood SoC device tree, which is specified as 0xd0b00
but should be 0x60b00.
For confirmation of address see table 581 page 658 of:
http://www.marvell.com/embedded-processors/kirkwood/assets/FS_88F6180_9x_6281_OpenSource.pdf
Also see definition of XOR1_HIGH_PHYS_BASE in
arch/arm/mach-kirkwood/include/mach/kirkwood.h
Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
Reviewed-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The kirkwood.dtsi cpu@0 node is missing the mandatory reg property.
This causes of_get_cpu_node() to fail to find the node and as a result
the cpufreq driver fails in its probe function.
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of the ocp node, placing it directly
below the mbus. This is a more accurate representation of the hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to
correspond to each MBus window.
In addition, we encode the PCIe memory and I/O apertures in the MBus
node, according to the MBus DT binding specification. The choice made
is 0xe0000000-0xf0000000 for memory space, and 0xf200000-0xf2100000 for
I/O space. These apertures can be changed in each per-board DT file.
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This macro is used to define window's target ID and attribute cells
for the MBus ranges entries.
Add a minimal MBus node, just to allow the MBus driver to probe.
Follow-up patches will migrate the rest of the nodes appropriately.
With recent support for true irqchip and clocksource drivers for Orion
SoCs, now make use of it on DT enabled Kirkwood boards.
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Kirkwood boards. Phy nodes are also added with reg property set on a
per-board basis.
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
Although the internal register window size is 1 MiB, the previous
ranges translation for the internal register space had a size of
0x4000000. This was done to allow the crypto and nand node to access
the corresponding 'sram' and 'nand' decoding windows.
In order to describe the hardware more accurately, we declare the
real 1 MiB internal register space in the ranges, and add a translation
entry for the nand node to access the 'nand' window.
This commit will make future improvements on the MBus DT binding easier.
The Kirkwood CPU Freq driver needs a CPU definition in order for the probe
routine to activate it. Add a suitable definition to kirkwood.dtsi
This definition is only correct for single core SoCs. There is a dual core
SoC in the kirkwood family (88F632X) but the rest of the Kirkwood drivers in
the kernel don't currently support it. If they ever do the cpus definition
would need to be duplicated in each of the SoC specific include files.
Signed-off-by: Adam Baker <linux@baker-net.org.uk>
Some kirkwood variants (for instance present in the prestera SoCs) do
not have all the peripherals whose nodes are declared in
kirkwood.dtsi. These missing peripherals are SATA, SDIO, and RTC.
As discussed in [1], to avoid that these missing peripherals get
initialized which could result in system hangs when accessing
undocumented/not present HW registers, their corresponding OF nodes
should not get declared at all for some kirkwood variants.
The corresponding OF nodes of these peripherals thus are moved from
kirkwood.dtsi to the kirkwood-628x.dtsi files so that they still are
initialized for these variants where they are present.
[1]
http://lists.infradead.org/pipermail/linux-arm-kernel/2013-May/167154.html
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
This commit adds Device Tree details to enable the PCIe interfaces on
Kirkwood. The 6281 has one PCIe interface, the 6282 has two PCIe
interfaces.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
In order to prepare the switch to the standard MMC device tree parser
for mvsdio, adapt all current uses of mvsdio in the dts files to the
standard format.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
The Marvell RTC on Kirkwood makes use of the runit clock. Ensure the
driver clk_prepare_enable() this clock, otherwise there is a danger
the SoC will lockup when accessing RTC registers with the clock
disabled.
Reported-by: Simon Baatz <gmbnomis@gmail.com>
Tested-by: Simon Baatz <gmbnomis@gmail.com>
The kirkwood SoC GPIO cores use the runit clock. Add code to
clk_prepare_enable() runit, otherwise there is a danger of locking up
the SoC by accessing the GPIO registers when runit clock is not
ticking.
When DT support for kirkwood was first introduced, there was no clock
infrastructure. As a result, we had to manually pass the
clock-frequency to the driver from the device node.
Unfortunately, on kirkwood, with minimal config or all module configs,
clock-frequency breaks booting because of_serial doesn't consume the
gate_clk when clock-frequency is defined.
The end result on kirkwood is that runit gets gated, and then the boot
fails when the kernel tries to write to the serial port.
Fix the issue by removing the clock-frequency parameter from all
kirkwood dts files.
Booted on dreamplug without earlyprintk and successfully logged in via
ttyS0.
Now that the SDIO controller has a Device Tree binding, let's use it
in kirkwood.dtsi.
The gpio controller on kirkwood can provide interrupts but is missing
the #interrupt-cells property. This patch just adds it to both gpio
controllers.
Without the clock being held by a driver, it gets turned off at a bad
time causing the SoC to lockup. This is often during reboot.
Tested-by: Stefan Peter <s.peter@mpl.ch>
