2018-02-25 | ARM: dts: logicpd-som-lv: Fix gpmc addresses for NAND and enet | Adam Ford | |
[ Upstream commit 3c18bbf3d11d2005da08b57ff26f44ff1c2b12d0 ] This patch fixes and issue where the NAND and GPMC based ethernet controller stopped working. This also updates the GPMC settings to be consistent with the Logic PD Torpedo development from the commit listed above. Fixes: 44e4716499b8 ("ARM: dts: omap3: Fix NAND device nodes") Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2017-01-17 | ARM: dts: omap3: Fix Card Detect and Write Protect on Logic PD SOM-LV | Adam Ford | |
This fixes commit ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730 SOM-LV") where the Card Detect and Write Protect pins were improperly configured. Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730 SOM-LV") Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> | |||
2016-02-22 | ARM: DTS: Add minimal Support for Logic PD DM3730 SOM-LV | Adam Ford | |
The Logic PD DM37xx SOM-LV devkit consists of a base board and a SOM. While the SOM (System on Module) supports Bluetooth and WiFi, LPD did not obtain an FCC ID, so anyone who uses it will have to go through certification. I have only tested the Type 28 Display, SMSC9211 Ethernet, SD/MMC and basic power management, however the overall current seems high. Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> |
