The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
commit ("766a1fe78fc3 ARM: omap3: Add missing memory node") had
fixes for Torpedo and Overo boards, but this SOM-LV was missed.
This should help prevent the DTC warning:
"Node /memory has a reg or ranges property, but no unit name"
This fix was applied to a bunch of omap3 devices including LogicPD
Torpedo, but this got missed since it was new around the same times
the patches were applied. This makes the GPMC parameters match the
Torpedo since they have the same processor PoP memory.
The Logic PD SOM-LV has a USB Host Controller connected to 3-port
hub. This enables the pin muxing for the host controller and
ehci-phy.
The Logic PD DM37xx SOM-LV devkit consists of a base board and a SOM.
While the SOM (System on Module) supports Bluetooth and WiFi, LPD did not
obtain an FCC ID, so anyone who uses it will have to go through certification.
I have only tested the Type 28 Display, SMSC9211 Ethernet, SD/MMC and basic
power management, however the overall current seems high.
