Fixes commit 687c27676151 ("ARM: dts: Add minimal support for LogicPD
Torpedo DM3730 devkit")
This patch corrects an issue where the cd-gpios was improperly setup
using IRQ_TYPE_LEVEL_LOW instead of GPIO_ACTIVE_LOW.
Fix commit 05c4ffc3a266 ("ARM: dts: LogicPD Torpedo: Add MT9P031 Support")
In the previous commit, I indicated that the only testing was done by
showing the camera showed up when probing. This patch fixes an incorrect
pin muxing on cam_d0, cam_d1 and cam_d2.
This patch fixes the following DTC warnings:
"dmtimer-pwm@10 has a unit name, but no reg property"
"display@0 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
LogicPD has two main Torpedo styles, a version with wireless and a version
without wireless. This version has Bluetooth and WiFi, but there really
isn't an easy way to identify them automatically. This simply adds
"Wireless" to the model to distinguish it from the 'base' model that will
come soon.
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
The backlight pin is shared with Timer 10 PWM. This patch allows the
pwm_bl driver to enable the pwm run by this timer to dim the backlight.
This patch defines the pin muxing to configure the hsusb0 through
the twl4030 PMIC, because we can't always assume the bootloader will
do it correctly.
The devkit has an AT25 EEPROM on MCSPI1. Enable this with default
parameters.
Setup regulator and fix pin muxing to allow Panel to sleep and
wake from sleep for some low power improvements.
The Logic PD Torpedo standard kits come with a SOM populated to us an
8-bit parallel camera interface. This patch pin muxes the omap3-isp
pins, sets the MT9P031 clicks, and configures the i2c2 bus to communicate
with the mt9p031 on address 0x48.
I have not done a lot of testing, but when modprobing
mt9p031, then omap3-isp, the board responds with
MT9P031 detected at address 0x48.
The development kit uses a TSC2004 chip attached to I2C3.
Revert 6f0f6c40b66 ("ARM: dts: Set VAUX1 and VAUX4 on Logic PD Torpedo")
because it It was already done and it's just a duplicate. See:
2d11961f3e55 ("ARM: dts: Set VAUX1 and VAUX4 to 3.0V and 1.8V respectively")
Add basic support for Logic PD type 15 display for older development kits.
This uses GPIO for the backlight.
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup
source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: "BenoƮt Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The schematic expects VAUX1 to be 3.0V attached to the debug port.
The schematic expects VAUX4 to be 1.8V.
VAUX4 powers VDDS_CSI2 on processor.
Signed-off-by: Adam Ford <adam.ford@logicpd.com>
The development kit schematic expects VAUX1 to be 3.0V. Most users use the development kit as a reference.
The development kit schematic expects VAUX4 to be 1.8V. VAUX4 powers VDDS_CSI2 on processor. If the voltage is too high it could damage the processor.
If it's too low, it won't work.
Use the TWL4030 Codec with mcbsp2 on Torpedo.
Some omaps are producing imprecise external aborts because we are
wrongly trying to init SRAM for device tree based booting. Only
omap3 is still using the legacy SRAM code, so we need to make it
omap3 specific. Otherwise we can get errors like this on at least
dm814x:
Unhandled fault: imprecise external abort (0xc06) at 0xc08b156c
(omap_rev) from [<c08b12e0>] (omap_sram_init+0xf8/0x3e0)
(omap_sram_init) from [<c08aca0c>] (omap_sdrc_init+0x10/0xb0)
(omap_sdrc_init) from [<c08b581c>] (pdata_quirks_init+0x18/0x44)
(pdata_quirks_init) from [<c08b5478>] (omap_generic_init+0x10/0x1c)
(omap_generic_init) from [<c08a57e0>] (customize_machine+0x1c/0x40)
(customize_machine) from [<c00098a4>] (do_one_initcall+0x80/0x1dc)
(do_one_initcall) from [<c08a2ec4>] (kernel_init_freeable+0x218/0x2e8)
(kernel_init_freeable) from [<c063a554>] (kernel_init+0x8/0xec)
(kernel_init) from [<c000f890>] (ret_from_fork+0x14/0x24)
Let's fix the issue by making sure omap_sdrc_init only gets called for
omap3. To do that, we need to have compatible "ti,omap3" in the dts
files. And let's also use "ti,omap3630" instead of "ti,omap36xx" like
we're supposed to.
The LogicPD Torpedo DM3730 devkit consists of a base board and
two processor boards. One of the processor boards has a WLAN and
the other one does not.
Let's set up basic dts file so we can move to device tree only
based booting over next few merge windows. So far I've tested
that UARTs, MMC1, USB OTG, smsc911x, and basic PM support works.
Note that the wireless support in kernel for wl1283 seems to be
broken, it tries to load wl127x-nvs.bin instead of wl128x-nvs.bin
with firmware.
Cc: Tim Nordell <tim.nordell@logicpd.com>
