Most of the peripherals on LPC18xx/43xx devices have their reset
lines hooked up to internal reset controller (RGU). Add reset
entries to the device nodes so a driver can use the reset line.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
NXP LPC SoCs family, which includes LPC18xx/LPC43xx, provides a State
Configurable Timer (SCT) which can be configured as a Pulse Width
Modulator.
Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar>
Add node for the watchdog timer found on LPC18xx/LPC43xx.
Add NXP LPC1778 I2C controller nodes to the dtsi for all
lpc18xx/43xx devices.
Add dmas entries to the four UART peripherals on LPC18xx/43xx devices
so that DMA can be used to transfer data.
Add dmas entries to the two SSP peripherals on LPC18xx/43xx devices
Add node for the DMA multiplexer placed in front of the PL080 DMA
controller on lpc18xx/43xx devices.
Add the ARM PL080 DMA controller node to the dtsi for all
Add the NXP LPC1773 SPIFI (SPI Flash Interface) flash controller
node to the dtsi for all lpc18xx/43xx devices.
Add the NXP LPC1850 RGU (Reset Generation Unit) reset controller
All devices in the LPC18xx/43xx familiy contain a ARM PL172
MultiPort Memory Controller (MPMC).
NXP LPC185x and LPC435x/70 devices contain a ARM PL111 lcd controller.
Signed-off-by: Joachim Eastwood <joachim.eastwood@gmail.com>
Add the USB OTG phy under the CREG syscon node and attach it to
the USB0 EHCI controller.
Add nodes for the two USB EHCI controllers found on lpc18xx.
The CREG block contains a collection of miscellaneous
configuration register like Ethernet phy mode, low
power clocks and DMA multiplexer. These registers
needs to be accessed from other drivers and syscon
provides this capability.
Add nodes for the ARM SSP controllers on lpc18xx.
Add gpio and mapping between pinctrl/gpio namespace with
gpio-ranges property.
Add pinctrl node for lpc1850-scu.
Add lpc1850-uart compatible string on uarts together with
proper clock-names.
Add CGU and CCU clock-controller nodes for lpc18xx together with
the fixed input clocks. Also remove the temporary fixed-factor
pll1 clock from both lpc18xx and lpc4350-hitex-eval DTS now that
proper clock drivers are inplace.
Acked-by: Michael Turquette <mturquette@baylibre.com>
NXP LPC18xx/43xx SoCs are very similar devices and should be able to
share a common base (lpc18xx.dtsi). Diffences between the devices are
put in a dtsi which is specific to that device.
