path: root/arch/arm/boot/dts/lpc4350-hitex-eval.dts
2019-01-26ARM: dts: lpc435x: remove address and size cells from gpio-keys-polled nodesVladimir Zapolskiy
The change removes redundant #address-cells and #size-cells properties from gpio-keys-polled compatible device nodes found in lpc4357-ea4357-devkit and lpc4350-hitex-eval board DTS files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2017-12-21ARM: dts: lpc18xx: Add generic compatible string for I2C EEPROMJavier Martinez Canillas
The at24 driver allows to register I2C EEPROM chips using different vendor and devices, but the I2C subsystem does not take the vendor into account when matching using the I2C table since it only has device entries. But when matching using an OF table, both the vendor and device has to be taken into account so the driver defines only a set of compatible strings using the "atmel" vendor as a generic fallback for compatible I2C devices. So add this generic fallback to the device node compatible string to make the device to match the driver using the OF device ID table. Signed-off-by: Javier Martinez Canillas <javierm@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-09-06ARM: dts: lpc18xx: remove skeleton.dtsi include and fix unit address warningsJoachim Eastwood
Removale of skeleton.dtsi allows us also to fix the following warning from the dts compiler: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name by adding proper unit addresses to the memory nodes. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Rob Herring <robh@kernel.org>
2016-08-27ARM: dts: lpc4350-hitex-eval: fix binding for SE97 i2c deviceGuenter Roeck
The 'compatible = "nxp,jc42"' binding only happened to work because the Linux driver is named jc42. The driver now supports generic bindings for JC-42 compatible chips, so use the generic binding instead. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2016-04-04ARM: dts: lpc4350-hitex-eval: fix unit name warnings from dtcJoachim Eastwood
Fix the following warnings from dtc by either adding or removing the unit name from the node. Warning (unit_address_vs_reg): Node /soc/flash-controller@40003000/flash@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /pca_buttons/button@7 has a unit name, but no reg property Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2016-03-29ARM: dts: lpc4350-hitex-eval: add adc1Joachim Eastwood
Enable adc1 on LPC4350 Hitex Evalution board. This board has a 10k potensiometer (R26) connected to ADC1 channel 2. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4350-hitex-eval: add joystick, buttons and ledsJoachim Eastwood
Add the joystick, buttons and LEDs connected to the I2C I/O expander. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4350-hitex-eval: add i2c0 and devicesAriel D'Alessandro
Add the I2C0 bus and the some of the I2C devices on the Hitex LPC4350 eval board. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4350-hitex-eval: add spifi and flash deviceJoachim Eastwood
The Hitex LPC4350 eval board has a Spansion S25SL064P SPI-NOR Flash connected to the SPIFI perherial. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-08-05ARM: dts: lpc4350-hitex-eval: add emc pins and static memory devicesJoachim Eastwood
Setup the emc pins used by external memory devices and add configuration for the devices found on the Hitex eval board. The Hitex eval board has a NOR Flash attached to chip select 0 and 512 kB of SRAM on chip select 2. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05ARM: dts: lpc4350-hitex-eval: add ethernetAriel D'Alessandro
Enable Ethernet and add pin muxing and set the correct frequency on the enet tx clock input. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05ARM: dts: lpc4350-hitex-eval: add pinctrl and uart0 muxingAriel D'Alessandro
Setup pin muxing and properties for the debug console on uart0. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-11ARM: dts: lpc18xx: add cgu and ccu clock-controller nodesJoachim Eastwood
Add CGU and CCU clock-controller nodes for lpc18xx together with the fixed input clocks. Also remove the temporary fixed-factor pll1 clock from both lpc18xx and lpc4350-hitex-eval DTS now that proper clock drivers are inplace. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Michael Turquette <mturquette@baylibre.com>
2015-05-15ARM: dts: Add DT for Hitex LPC4350 Evaluation BoardAriel D'Alessandro
Add basic support for Hitex LPC4350 Evaluation Board. Board features a LPC4350 Soc, 8 MB SDRAM, 8 MB SPI Flash, USB and Ethernet. More information can be found on: http://www.hitex.com/index.php?id=3212 Signed-off-by: Ariel D'Alessandro <ariel.dalessandro@gmail.com> Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
