path: root/arch/arm/boot/dts/lpc4357-ea4357-devkit.dts
2016-09-06ARM: dts: lpc18xx: remove skeleton.dtsi include and fix unit address warningsJoachim Eastwood
Removale of skeleton.dtsi allows us also to fix the following warning from the dts compiler: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name by adding proper unit addresses to the memory nodes. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Rob Herring <robh@kernel.org>
2016-04-04ARM: dts: lpc4357-ea4357: fix unit name warnings from dtcJoachim Eastwood
Fix the following warnings from dtc by either adding or removing the unit name from the node. Warning (unit_address_vs_reg): Node /soc/flash-controller@40003000/flash@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /gpio_joystick/button@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /gpio_joystick/button@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /gpio_joystick/button@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /gpio_joystick/button@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /gpio_joystick/button@4 has a unit name, but no reg property Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2016-03-29ARM: dts: lpc4357-ea4357: add dacJoachim Eastwood
Enable the DAC on the EA4357 dev kit. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2016-03-29ARM: dts: lpc4357-ea4357: add adc0Joachim Eastwood
Enable adc0 on EA4357 dev kit. This kit has a 22k potentiometer (R94) connected on ADC0 channel 3. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-12-14ARM: dts: lpc4357-ea4357: add mma7455 i2c accelerometerJoachim Eastwood
Add Freescale MMA7455 3-axis I2C accelerometer as found on Embedded Artists' LPC4357 Developer's Kit to the device tree. This makes it possible to access the accelerometer through the API provided by IIO. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4357-ea4357: add i2c0 and devicesJoachim Eastwood
Add I2C0 and some of the I2C devices on the EA4357 dev kit. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4357-ea4357: add ssp0Joachim Eastwood
The SSP0 can be found on the EA4357 Dev Kit on J15 pin 3-6. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-09-30ARM: dts: lpc4357-ea4357: add spifi and flash deviceJoachim Eastwood
The EA4357 dev kit has a Spansion S25FL016K SPI-NOR Flash connected to the SPIFI perherial. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-08-05ARM: dts: lpc4357-ea4357: add mmio-gpio ledsJoachim Eastwood
Hook up LEDs on the outputs from the D-type flip-flop found on the address/data bus. Note that the LEDx label in the schematics is reversed in regard to the bits on the data bus. Hence the reverse ordering used here. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05ARM: dts: lpc4357-ea4357: add emc pins and static memory devicesJoachim Eastwood
Setup the emc pins used by external memory devices and add configuration for the devices found on the EA4357 devkit. The EA4357 devkit has a NOR Flash attached to chip select 0 and a D-type flip-flop used for LEDs on chip select 2. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05ARM: dts: lpc4357-ea4357: add usb0Joachim Eastwood
Enable USB0 on the EA4357 devkit and setup the required USB0 control pins. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-14ARM: dts: lpc4357-ea4357: add uart3Joachim Eastwood
Enable UART3 that is routed to the J17 DSUB9 connector on the EA4357 devkit. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-07-14ARM: dts: lpc4357-ea4357: add ethernetJoachim Eastwood
Enable Ethernet and add pin muxing and set the correct frequency on the enet tx clock input. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-07-14ARM: dts: lpc4357-ea4357: add gpio joystickJoachim Eastwood
Hook up the small joystick found on the EA4357 devkit. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-07-11ARM: dts: lpc4357-ea4357: add mmcsdJoachim Eastwood
Enable the MMC/SD controller on EA4357 devkit and add pin muxing plus a regulator. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-07-11ARM: dts: lpc4357-ea4357: add pinctrl and uart0 muxingJoachim Eastwood
Setup pin muxing and properties for the debug console on uart0. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-15ARM: dts: Add DT for Embedded Artists LPC4357 Developers KitJoachim Eastwood
Adds basic support for Embedded Artists' LPC4357 Developer's Kit. Board features a LPC4357 Soc, 32 MB SDRAM, 128 MB NAND Flash, 16 MB SPI Flash, USB and Ethernet. More information can be found on: http://www.embeddedartists.com/products/kits/lpc4357_kit.php Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
