[ Upstream commit c7861adbe37f576931650ad8ef805e0c47564b9a ]
Each eTSEC MAC has its own TBI (SGMII) PCS and private MDIO bus.
But due to a DTS oversight, both SGMII-compatible MACs of the LS1021 SoC
are pointing towards the same internal PCS. Therefore nobody is
controlling the internal PCS of eTSEC0.
Upon initial ndo_open, the SGMII link is ok by virtue of U-boot
initialization. But upon an ifdown/ifup sequence, the code path from
ndo_open -> init_phy -> gfar_configure_serdes does not get executed for
the PCS of eTSEC0 (and is executed twice for MAC eTSEC1). So the SGMII
link remains down for eTSEC0. On the LS1021A-TWR board, to signal this
failure condition, the PHY driver keeps printing
'803x_aneg_done: SGMII link is not ok'.
Also, it changes compatible of mdio0 to "fsl,etsec2-mdio" to match
mdio1 device.
Fixes: 055223d4d22d ("ARM: dts: ls1021a: Enable the eTSEC ports on QDS and TWR")
Signed-off-by: Vladimir Oltean <olteanv@gmail.com>
Reviewed-by: Claudiu Manoil <claudiu.manoil@nxp.com>
Acked-by: Li Yang <leoyang.li@nxp.com>
[ Upstream commit 47768f372eae030db6fab5225f9504a820d2c07f ]
The cooling device properties, like "#cooling-cells" and
"dynamic-power-coefficient", should either be present for all the CPUs
of a cluster or none. If these are present only for a subset of CPUs of
a cluster then things will start falling apart as soon as the CPUs are
brought online in a different order. For example, this will happen
because the operating system looks for such properties in the CPU node
it is trying to bring up, so that it can register a cooling device.
Add such missing properties.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
[ Upstream commit d5c7b4d5ac2237a6da7ced3adfe6b8bf769f8cc6 ]
Commit a22950c888e3 (mmc: sdhci-of-esdhc: add quirk
SDHCI_QUIRK_BROKEN_TIMEOUT_VAL for ls1021a) added logic to the driver to
enable the broken timeout val quirk for ls1021a, but did not add the
corresponding compatible string to the device tree, so it didn't really
have any effect. Fix that.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
In order to maximize the use of MSI, a PCIe controller will share
all MSI controllers. The patch changes msi-parent to refer to all
MSI controller dts nodes.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
"1" should be replaced by "l". This is a typo.
The patch is to fix it.
qoriq clock driver has been updated to parse the clock configuration
information defined in driver itself not in dts.
Since the new implementation and the bindings have been merged,
it is time to update the clock related node and remove redundent clock
configuration information from the dts.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Also add nodes and properties for thermal management support.
Signed-off-by: Jia Hongtao <hongtao.jia@nxp.com>
Add "dis_rxdet_inp3_quirk" boolean property to USB3 node. This property
is used to disable rx detection in P3 PHY mode.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
The DCU IP has distinct clock inputs for register access and the
pixel clocks, at least in some implementations. LS1021a seems to
use the same clock, therefore specify the same clock for "dcu"
and "pix".
Signed-off-by: Stefan Agner <stefan@agner.ch>
Both DSPI have signals SPIn_PCS[0:5] so in summary 6 chip-selects, not 5.
Fix that.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Add gpio nodes for ls1021a platform dts file. The gpio
IP block of the ls1021a can be supported by the code
drivers/gpio/gpio-mpc8xxx.c.
The compatible "fsl,qoriq-gpio" is used by gpio driver:
drivers/gpio/gpio-mpc8xxx.c to implement general gpio
functionalities.
The chip-specific compatible "fsl,ls1021a-gpio" may be
used to fix potential gpio IP block errata or other
chip-specific gpio issues.
Signed-off-by: Liu Gang <Gang.Liu@nxp.com>
Add SCFG MSI dts node and add msi-parent property to PCIe dts node
that points to the corresponding MSI node.
Tested-by: Alexander Stein <alexander.stein@systec-electronic.com>
Pull more ARM DT changes from Arnd Bergmann:
"Here are some final updates for ARM SoC specific dts files:
- The i.MX changes were sent relatively late, and had a dependency on
the clk tree, so I delayed that a bit. Support for the new i.MX6qp
SoC and a couple of new boards is added in this branch.
- Uniphier renames a few files to match the final product names that
were decided by the company, kudos to the kernel developer(s) for
getting support upstream before the product release. Also two
boards are added. The patches were posted early enough and nice
overall, but we forgot to apply them and decided to give it some
more time in linux-next
- at91 has two small bug fixes"
* tag 'armsoc-dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: dts: at91: sama5d4 Xplained: don't disable hsmci regulator
ARM: dts: at91: sama5d3 Xplained: don't disable hsmci regulator
ARM: dts: uniphier: add pinmux node for I2C ch4
ARM: dts: uniphier: add @{address} to EEPROM node
ARM: dts: uniphier: add PH1-Pro4 Sanji board support
ARM: dts: uniphier: add PH1-Pro4 Ace board support
ARM: dts: uniphier: enable I2C channel 2 of ProXstream2 Gentil board
ARM: dts: uniphier: add EEPROM node for ProXstream2 Gentil board
ARM: dts: uniphier: add reference clock nodes
ARM: dts: uniphier: rework UniPhier System Bus nodes
ARM: dts: uniphier: factor out ranges property of support card
arm64: dts: uniphier: rename PH1-LD10 to PH1-LD20
ARM: dts: imx53-qsb: Fix gpio button polarity
ARM: dts: vfxxx: Add DAC node for Vybrid SoC
ARM: dts: imx6q: add missing links between ipu2 and mipi dsi
ARM: dts: imx: Add support for Advantech/GE B850v3
ARM: dts: imx: Add support for Advantech/GE B650v3
ARM: dts: imx: Add support for Advantech/GE B450v3
ARM: dts: imx: Add support for Advantech/GE Bx50v3
ARM: dts: imx: Add Advantech BA-16 Qseven module
LS1021a contains two PCIe controllers. The patch adds their node to
dts file.
Add the 1588 timer node for ls1021a platform to
support gianfar ptp driver.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Added sata node to ls1021aqds and ls1021atwr board to support
sata function.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
Signed-off-by: Jianwei Wang <jianwei.wang.chn@gmail.com>
Signed-off-by: Meng Yi <b56799@freescale.com>
Add "snps,quirk-frame-length-adjustment" property to
USB3 node for erratum A009116. This property provides
value of GFLADJ_30MHZ for post silicon frame length
adjustment.
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@freescale.com>
This patch adds dma-coherent property for eTSEC nodes, so
coherent DMA operations are supported.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Signed-off-by: Horia Geantă <horia.geanta@freescale.com>
Add basic support for all the eTSEC controllers on the
ls1021a SoC. Second interrupt group register blocks
and their corresponding Rx/Tx/Err interrupt sources are
included as well for each eTSEC node.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
This patch adds dts nodes for audio on LS1021A.
Freescale DSPI driver has been updated and supports TCF interrupt type now.
In the new driver we choose the interrupt type according the compatible
string of the device node.
This patch update the compatible string of DSPI device node of LS1021A in
order to use the correct interrupt type.
Signed-off-by: Haikun Wang <haikun.wang@freescale.com>
On LS1021A SoC, the scfg device is in BE mode.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
This add Freescale QorIQ LS1021A SoC device tree support.
The QorIQ LS1021A processor incorporates dual ARM Cortex-A7 cores,
providing virtualization support, advanced security features and the
broadest array of high-speed interconnects and optimized peripheral
features.
The LS1021A SoC shares IPs with i.MX, Vybrid and PowerPC platform.
For the detail information about Freescale QorIQ LS1021A SoC,
please refer to the QorIQ LS1021A Reference Manual.
Signed-off-by: Chenhui Zhao <chenhui.zhao@freescale.com>
Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com>
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Signed-off-by: Chao Fu <b44548@freescale.com>
Signed-off-by: Jingchang Lu <jingchang.lu@freescale.com>
