Change the dtsi and dts file, soc initialization code to make
use of DT support clock.
So now in the code we do only need call of_clk_init to initialize
the clocks.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
Add items in arch/arm/boot/dt/Makefile to compile the dtb
for mach-mmp.
Change the dts and dtsi file to use #include instead of \include\
Since more driver names are added into platform id, do the same thing on
compatible names for DT mode.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Add max8925 dts support into mmp2 brownstone platform
Signed-off-by: Qing Xu <qingx@marvell.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Append mmp2 and pxa910 dts files. Update PXA168 dts files for irq,
timer, gpio components.
