i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The clocks group properties and the clock@0 node have been obsolete for two
years, remove them.
Cc: Joachim Eastwood <manabian@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Define Phontech MPA 1600 main and slow crystals frequencies.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
to prepare the switch to the macro.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
[nicolas.ferre@atmel.com: remove unneeded address-cells and size-cells to gpio-keys]
