commit ae72e95b5e4ded145bfc6926ad9457b74e3af41a upstream.
The hifsys and ethsys needs the definition of the reset-cells
property. Fix this.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Add mediatek's hardware id information for smi larb.
Signed-off-by: Honghui Zhang <honghui.zhang@mediatek.com>
Add xhci nodes and usb3 phy nodes for MT2701
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Signed-off-by: Erin Lo <erin.lo@mediatek.com>
Add ethernet device node for MT2701
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Add audio driver node for mt2701
Signed-off-by: Garlic Tseng <garlic.tseng@mediatek.com>
Add MT2701 i2c device node.
Signed-off-by: Jun Gao <jun.gao@mediatek.com>
Signed-off-by: Rick Chang <rick.chang@mediatek.com>
Signed-off-by: Minghsiu Tsai <minghsiu.tsai@mediatek.com>
[mb: include mt2701-larb-port.h to fix build errors]
Add Mediatek nor flash node.
Signed-off-by: Guochun Mao <guochun.mao@mediatek.com>
This commit add mtk-cirq node to mt2701 dtsi.
Signed-off-by: Youlin Pei <youlin.pei@mediatek.com>
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add thermal controller device nodes for MT2701.
Signed-off-by: Dawei Chien <dawei.chien@mediatek.com>
Add auxadc device node for MT2701.
Signed-off-by: Zhiyong Tao <zhiyong.tao@mediatek.com>
Add mt2701 nand device node, include nfi and bch ecc.
Signed-off-by: Xiaolei Li <xiaolei.li@mediatek.com>
Add spi device node for MT2701.
Signed-off-by: Leilk Liu <leilk.liu@mediatek.com>
Add the dtsi node of iommu and smi for mt2701.
Add power domain controller node (scpsys) for MT2701.
Signed-off-by: James Liao <jamesjj.liao@mediatek.com>
Add MT2701 subsystem clock controllers, inlcude mmsys, imgsys,
vdecsys, hifsys, ethsys and bdpsys.
This patch rearrange MT2701 DT nodes to keep them in ascending order.
[mb: fix pio unit address and order]
We used to use a fixed rate clock for the UARTs. Now that we have clock
support we can associate the correct clocks to the UARTs and drop the
26MHz fixed rate UART clock.
Add clock controller nodes for MT2701, include topckgen, infracfg,
pericfg and apmixedsys. This patch also add two oscillators that
provide clocks for MT2701.
Add pinctrl and GPIO node to mt2701.dtsi
Signed-off-by: Biao Huang <biao.huang@mediatek.com>
This reverts commit 8ba671efdbe5be3e5d691a8b7f77b0d68459b874.
As reported by kbuild test robot <fengguang.wu@intel.com>:
In file included from arch/arm/boot/dts/mt2701-evb.dts:16:0:
>> arch/arm/boot/dts/mt2701.dtsi:18:28: fatal error: mt2701-pinfunc.h: No such file or directory
#include "mt2701-pinfunc.h"
Add enable method to support SMP.
Signed-off-by: Louis Yu <louis.yu@mediatek.com>
This adds basic chip support for Mediatek 2701.
[matthias.bgg@gmail.com: Fixed reg address of mt2701-timer]
