path: root/arch/arm/boot/dts/mt2701.dtsi
2018-02-22arm: dts: mt2701: Add reset-cellsMatthias Brugger
commit ae72e95b5e4ded145bfc6926ad9457b74e3af41a upstream. The hifsys and ethsys needs the definition of the reset-cells property. Fix this. Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-04arm: dts: mediatek: add larbid property for larbHonghui Zhang
Add mediatek's hardware id information for smi larb. Signed-off-by: Honghui Zhang <honghui.zhang@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-08-01arm: dts: mt2701: Add usb3 device nodesChunfeng Yun
Add xhci nodes and usb3 phy nodes for MT2701 Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-08-01arm: dts: mt2701: Add ethernet device nodeSean Wang
Add ethernet device node for MT2701 Signed-off-by: Sean Wang <sean.wang@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-06-07arm: dts: mediatek: Add audio driver node for MT2701Garlic Tseng
Add audio driver node for mt2701 Signed-off-by: Garlic Tseng <garlic.tseng@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-05-31arm: dts: Add Mediatek MT2701 i2c device nodeJun Gao
Add MT2701 i2c device node. Signed-off-by: Jun Gao <jun.gao@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-05-31arm: dts: mt2701: Add node for Mediatek JPEG DecoderRick Chang
Signed-off-by: Rick Chang <rick.chang@mediatek.com> Signed-off-by: Minghsiu Tsai <minghsiu.tsai@mediatek.com> [mb: include mt2701-larb-port.h to fix build errors] Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-05-15arm: dts: mt2701: add nor flash nodeGuochun Mao
Add Mediatek nor flash node. Signed-off-by: Guochun Mao <guochun.mao@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-05-15ARM: dts: mt2701: Add mtk-cirq node for mt2701Youlin Pei
This commit add mtk-cirq node to mt2701 dtsi. Signed-off-by: Youlin Pei <youlin.pei@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-02-07ARM: DTS: Fix register map for virt-capable GICMarc Zyngier
Since everybody copied my own mistake from the DT binding example, let's address all the offenders in one swift go. Most of them got the CPU interface size wrong (4kB, while it should be 8kB), except for both keystone platforms which got the control interface wrong (4kB instead of 8kB). In a few cases where I knew for sure what implementation was used, I've added the "arm,gic-400" compatible string. I'm 99% sure that this is what everyone is using, but short of having the TRM for all the other SoCs, I've left them alone. Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-01-24arm: dts: mt2701: Add thermal device node.Dawei Chien
Add thermal controller device nodes for MT2701. Signed-off-by: Dawei Chien <dawei.chien@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Add auxadc device node.Zhiyong Tao
Add auxadc device node for MT2701. Signed-off-by: Zhiyong Tao <zhiyong.tao@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Add nand device nodeXiaolei Li
Add mt2701 nand device node, include nfi and bch ecc. Signed-off-by: Xiaolei Li <xiaolei.li@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Add spi device nodeLeilk Liu
Add spi device node for MT2701. Signed-off-by: Leilk Liu <leilk.liu@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13ARM: dts: mt2701: add iommu/smi dtsi node for mt2701Honghui Zhang
Add the dtsi node of iommu and smi for mt2701. Signed-off-by: Honghui Zhang <honghui.zhang@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Add power domain controller device nodeJames Liao
Add power domain controller node (scpsys) for MT2701. Signed-off-by: James Liao <jamesjj.liao@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Add subsystem clock controller device nodesJames Liao
Add MT2701 subsystem clock controllers, inlcude mmsys, imgsys, vdecsys, hifsys, ethsys and bdpsys. Signed-off-by: James Liao <jamesjj.liao@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-01-13arm: dts: mt2701: Sort DT nodes by register addressJames Liao
This patch rearrange MT2701 DT nodes to keep them in ascending order. Signed-off-by: James Liao <jamesjj.liao@mediatek.com> [mb: fix pio unit address and order] Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2016-11-11arm: dts: mt2701: Use real clock for UARTsErin Lo
We used to use a fixed rate clock for the UARTs. Now that we have clock support we can associate the correct clocks to the UARTs and drop the 26MHz fixed rate UART clock. Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2016-11-11arm: dts: mt2701: Add clock controller device nodesJames Liao
Add clock controller nodes for MT2701, include topckgen, infracfg, pericfg and apmixedsys. This patch also add two oscillators that provide clocks for MT2701. Signed-off-by: James Liao <jamesjj.liao@mediatek.com> Signed-off-by: Erin Lo <erin.lo@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2016-04-13arm: dts: Add pinctrl/GPIO/EINT node for mt2701Biao Huang
Add pinctrl and GPIO node to mt2701.dtsi Signed-off-by: Biao Huang <biao.huang@mediatek.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2016-02-28Revert "arm: dts: Add pinctrl/GPIO/EINT node for mt2701"Arnd Bergmann
This reverts commit 8ba671efdbe5be3e5d691a8b7f77b0d68459b874. As reported by kbuild test robot <fengguang.wu@intel.com>: In file included from arch/arm/boot/dts/mt2701-evb.dts:16:0: >> arch/arm/boot/dts/mt2701.dtsi:18:28: fatal error: mt2701-pinfunc.h: No such file or directory #include "mt2701-pinfunc.h" ^ Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-02-11arm: dts: Add pinctrl/GPIO/EINT node for mt2701Biao Huang
2016-02-11ARM: dts: mt2701: enable basic SMP bringup for mt2701Louis Yu
Add enable method to support SMP. Signed-off-by: Louis Yu <louis.yu@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-11-20ARM: dts: mediatek: add MT2701 basic supportErin Lo
This adds basic chip support for Mediatek 2701. Signed-off-by: Erin Lo <erin.lo@mediatek.com> [matthias.bgg@gmail.com: Fixed reg address of mt2701-timer] Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
