commit c0b0d540db1a8bfb041166c4991dd6f624e8de45 upstream.
Below two wrong nodes in existing DTS files would cause a fail boot since
in fact the address 0 is not the correct place the memory device locates
at.
memory {
device_type = "memory";
reg = <0x0 0x0 0x0 0x0>;
memory@80000000 {
reg = <0x0 0x80000000 0x0 0x40000000>;
In order to avoid having a memory node starting at address 0, we can't
include file skeleton64.dtsi and instead need to explicitly manually
define a few of properties the DTS relies on such as #address-cells
and #size-cells in root node and device_type in the node memory@80000000.
Cc: stable@vger.kernel.org
Fixes: 31ac0d69a1d4 ("ARM: dts: mediatek: add MT7623 basic support")
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Cc: Rob Herring <robh+dt@kernel.org>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
commit 0629a01920c0f8a3f825361b24863d760610884a upstream.
Fix that USB initialization fails as below runtime log is present during
booting on bananapi-r2 board by adding missing regulators the USB device
requires. Current regulators USB device uses are being updated with the
correct ones to reflect real configurations which are all from fixed
regulators rather than MT6323 one's output.
xhci-mtk 1a1c0000.usb: 1a1c0000.usb supply vbus not found, using dummy regulator
xhci-mtk 1a240000.usb: 1a240000.usb supply vbus not found, using dummy regulator
Fixes: f4ff257cd160 ("arm: dts: mt7623: add support for Bananapi R2 (BPI-R2) board")
[mb: update kernel log in commit message]
commit b96a696fb2a8dd1ee4e6cfee48dcac270fc53287 upstream.
Fix that bananapi-r2 booting from SD-card would fail since incorrect
polarity is applied to the previous setup with GPIO_ACTIVE_HIGH.
Fixes: 0eed8d097612 ("arm: dts: mt7623: Add SD-card and EMMC to bananapi-r2")
Tested-by: Matthias Brugger <matthias.bgg@gmail.com>
Dummy patch to sort nodes alphabetically and add some blank lines
for consistency.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
The bananapi-r2 board has an SD-card controller and built-in
EMMC storage so enables those devices in the devicetree.
Add support for the Bananapi R2 (BPI-R2) development board from
BIPAI KEJI. Detailed hardware information for BPI-R2 which could be
found on http://www.banana-pi.org/r2.html
The patch added nodes into the SoC-level file mt7623.dtsi such as CPU OPP
table and thermal zone treating CPU as one of cooling devices and also
added nodes into board-level file mt7623n-bananapi-bpi-r2.dts such as
MediaTek GMAC, MT7530 Switch, the crypto engine, USB, IR, I2S, I2C, UART,
SPI, PWM, GPIO keys, GPIO LEDs and PMIC LEDs. As to the other missing
hardware and peripherals, they would be added and integrated continuously.
Acked-by: Rob Herring <robh@kernel.org>
