Add arch timer node to enable arch-timer support. MT8127 firmware
doesn't correctly setup arch-timer frequency and CNTVOFF, add
properties to workaround this.
This also set cpu enable-method to enable SMP.
Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
The instance address for uart nodes are incorrect. Correct them.
This add dts support for mt8127 and mt8135 SOC UART
Signed-off-by: Eddie Huang <eddie.huang@mediatek.com>
Add sysirq settings for mt6589/mt8135/mt8127
This also correct timer interrupt flag. The old setting works
because boot loader already set polarity for timer interrupt.
Without intpol support, the setting was not changed so gic
can get the irq correctly.
This adds a basic dtsi for MT8127 SoC.
Signed-off-by: Joe.C <yingjoe.chen@mediatek.com>
