path: root/arch/arm/boot/dts/mt8135.dtsi
2019-01-30ARM: dts: Kill off skeleton{64}.dtsiRob Herring
Remove the usage of skeleton.dtsi in the remaining dts files. It was deprecated since commit 9c0da3cc61f1 ("ARM: dts: explicitly mark skeleton.dtsi as deprecated"). This will make adding a unit-address to memory nodes easier. The main tricky part to removing skeleton.dtsi is we could end up with no /memory node at all when a bootloader depends on one being present. I hacked up dtc to check for this condition. Acked-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Antoine Tenart <antoine.tenart@bootlin.com> Acked-by: Alexandre TORGUE <alexandre.torgue@st.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Tested-by: Kevin Hilman <khilman@baylibre.com> Reviewed-by: Kevin Hilman <khilman@baylibre.com> Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Reviewed-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Gregory CLEMENT <gregory.clement@bootlin.com> Tested-by: Gregory CLEMENT <gregory.clement@bootlin.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-05-02arm: dts: mediatek: converted to using SPDX identifiersSean Wang
Convert boilerplate license statement into proper SPDX identifier style. Signed-off-by: Sean Wang <sean.wang@mediatek.com> Cc: Philippe Ombredanne <pombredanne@nexb.com> Cc: Rob Herring <robh+dt@kernel.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2017-02-07ARM: DTS: Fix register map for virt-capable GICMarc Zyngier
Since everybody copied my own mistake from the DT binding example, let's address all the offenders in one swift go. Most of them got the CPU interface size wrong (4kB, while it should be 8kB), except for both keystone platforms which got the control interface wrong (4kB instead of 8kB). In a few cases where I knew for sure what implementation was used, I've added the "arm,gic-400" compatible string. I'm 99% sure that this is what everyone is using, but short of having the TRM for all the other SoCs, I've left them alone. Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-11-24ARM: mediatek: DT: Move reset controller constants into common locationPhilipp Zabel
By popular vote, the DT binding includes for reset controllers are located in include/dt-bindings/reset/. Move the mediatek reset constants in there, too, to avoid confusion. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-10-12ARM: dts: mt8135: enable basic SMP bringup for mt8135Yingjoe Chen
Add arch timer node to enable arch-timer support. MT8135 firmware doesn't correctly setup arch-timer frequency and CNTVOFF, add properties to workaround this. This also set cpu enable-method to enable SMP. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-07-17ARM: dts: mediatek mt8135: Use real UART clocksSascha Hauer
We used to provide dummy clocks for the UART. Now that we have common clock support we can provide the real clocks to the UART. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-07-17ARM: dts: mt8135: Add pmic wrapper nodesSascha Hauer
This adds the pmic wrapper node to the MediaTek MT8135 dtsi file. This unit is used to access the PMIC on MediaTek boards. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-07-17ARM: dts: mediatek: Enable clock support for Mediatek MT8135.James Liao
This patch adds MT8135 clock controllers into device tree. Signed-off-by: James Liao <jamesjj.liao@mediatek.com> Signed-off-by: Henry Chen <henryc.chen@mediatek.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-05-04ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135.Hongzhou Yang
Add pinctrl,GPIO and EINT node to mt8135.dtsi. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-01-02ARM: mediatek: add UART dts for mt8127 and mt8135Eddie Huang
This add dts support for mt8127 and mt8135 SOC UART Signed-off-by: Eddie Huang <eddie.huang@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-01-02ARM: mediatek: Add sysirq in mt6589/mt8135/mt8127 dtsiYingjoe Chen
Add sysirq settings for mt6589/mt8135/mt8127 This also correct timer interrupt flag. The old setting works because boot loader already set polarity for timer interrupt. Without intpol support, the setting was not changed so gic can get the irq correctly. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-11-12ARM: mediatek: Add basic support for mt8135Joe.C
This adds a basic dtsi for MT8135 based SoC. Signed-off-by: Joe.C <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
