2017-01-03 | ARM: dts: mvebu: Correct license text | Alexandre Belloni | |
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> | |||
2016-02-09 | ARM: dts: orion5x: split linkstation lswtgl into common and device parts | Roger Shimizu | |
In order to support more linkstation devices, common part of current .dts file goes into .dtsi file. Some .dtsi start with "mvebu-" prefix because other kirkwood based linkstation devices are similar, and will be migrated to use these .dtsi some time later. - orion5x-linkstation.dtsi - mvebu-linkstation-fan.dtsi - mvebu-linkstation-gpio-simple.dtsi while all rest part remains in device specific .dts file: - orion5x-linkstation-lswtgl.dts Signed-off-by: Roger Shimizu <rogershimizu@gmail.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> |
