path: root/arch/arm/boot/dts/nspire.dtsi
2015-10-23ARM: dts: TI-Nspire: fix cpu compatible valueVladimir Zapolskiy
The change corrects cpu compatible property to a defined one, see Documentation/devicetree/bindings/arm/cpus.txt Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-03-04devicetree: Add TI-NSPIRE USB OTG support to device treeDaniel Tang
Signed-off-by: Daniel Tang <dt.tangr@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-21arm: Add device trees for TI-Nspire hardwareDaniel Tang
This patch adds device trees for describing the TI-Nspire hardware. Changes between v1 and v2: * Change "keymap" binding to the standard "linux,keymap" binding. Signed-off-by: Daniel Tang <dt.tangr@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
