Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
The number of mailbox fifos and users (IP interrupts) are added
to the Mailbox DT nodes on OMAP2420, OMAP2430, OMAP3, and OMAP5
family of SoCs through the DT properties "ti,mbox-num-fifos" and
"ti,mbox-num-users" properties. This data represents the same data
that used to be represented in hwmod attribute data through the
.num_fifos and .num_users fields previously.
Signed-off-by: Suman Anna <s-anna@ti.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Otherwise legacy boot clock data is used. This patch also includes the
clock data files to the base dtsi files.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
omap-for-v3.16/dt-v2
This patch creates a unique node for each clock in the OMAP2 power,
reset and clock manager (PRCM).
The mailbox module is capable of generating two interrupts
to MPU in OMAP2420, compared to one in OMAP2430. The second
interrupt is to handle interrupts from the additional IVA
processor present only on OMAP2420.
Move the current common mailbox DT node into the SoC
specific files to allow the above differentiation. Also,
added back the interrupt-names on OMAP2420, that were
previously defined in hwmod data.
This fixes regression caused by the recent dropping of
hwmod data in favor for defining it in the .dts files.
[tony@atomide.com: updated description]
In omap2420.dtsi and omap2430.dtsi disable all mcbsp nodes and board dts
files can explicitly enable the mcbsp they are using.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Looks like we're missing few entries for omap2 and the drivers
have only worked because of the omap hwmod building the devices
for the missing entries.
Let's fix the missing entries so we don't need to rely on hwmod
for the basic data and can then later on remove the duplicate
data from hwmod. Otherwise device tree only drivers will not
work properly.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: devicetree@vger.kernel.org
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Add the "ti,gpio-always-on" property to the appropriate GPIO banks to
indicate which banks are always powered and will never lose logic state.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Update the DMTIMER compatibility property to reflect the register level
compatibilty between devices and update the various OMAP/AM timer
bindings with the appropriate compatibility string.
By doing this we can add platform specific data applicable to specific
timer versions to the driver. For example, errata flags can be populated
for the timer versions that are impacted.
Populate DMA client information for McBSP DMIC and McPDM periperhal on
OMAP2+ devices.
Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com>
Add gpios bindings for OMAP2420 and OMAP2430 devices.
Add the device-tree node for GPMC on OMAP2, OMAP4 and OMAP5 devices.
Adds the counter-32k timers nodes present in OMAP2/3/4 devices and
device-tree binding documentation for OMAP counter-32k.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Add the 12 GP timers nodes present in OMAP2.
Add the 12 GP timers nodes present in OMAP3.
Add the 11 GP timers nodes present in OMAP4.
Add the 7 GP timers nodes present in AM33xx.
Add documentation for timer properties specific to OMAP.
Thanks to Vaibhav Hiremath for creating the AM33xx timer nodes. I have modified
Vaibhav's original nodes adding information on which timers support a PWM
output.
V5 changes:
- Updated timer register sizes for OMAP2/3/4.
- Modified AM335x timer register size to be 1KB instead of 4KB to align with
HWMOD.
Acked-Reviewed-&-Tested-By: Vaibhav Hiremath <hvaibhav@ti.com>
The interrupt-parent attribute does not have to be added in each
node since the fmwk will check for the parent as well to get it.
Create an interrupt-parent for OMAP2, OMAP3, AM33xx and remove the
attributes from every nodes that were using it.
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Sebastien Guiriec <s-guiriec@ti.com>
Add pinctrl driver entries for omap2+. These all use
the generic pinctrl-single driver for the padconf
registers.
Cc: devicetree-discuss@lists.ozlabs.org
[tony@atomide.com: updated to drop omap2420.dtsi rename changes]
The McBSP IP within OMAP2420 and 2430 is different we need to create separate
dtsi files for them.
