path: root/arch/arm/boot/dts/omap3-beagle-xm.dts
2016-08-31ARM: dts: omap3: Add missing unit name to memory nodesJavier Martinez Canillas
This patch fixes the following DTC warnings: "Node /memory has a reg or ranges property, but no unit name" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-06-29ARM: dts: omap3-beagle-xm: remove unneeded unit namesJavier Martinez Canillas
This patch fixes the following DTC warnings for omap3-beagle-xm.dtb: "encoder@0 has a unit name, but no reg property" "encoder@0/ports/port@0/endpoint@0 has a unit name, but no reg property" "encoder@0/ports/port@1/endpoint@0 has a unit name, but no reg property" "connector@0 has a unit name, but no reg property" "connector@1 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-17ARM: dts: omap: replace legacy *,wakeup property with wakeup-sourceSudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30ARM: dts: omap3-beagle-xm: Use OMAP3_*_IOPAD pinmux macrosJavier Martinez Canillas
Use the pinmux IOPAD macros to define the register absolute physical address instead of the offset from the padconf base address. This makes the DTS easier to read since matches the addresses listed in the Technical Reference Manual. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-12ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boardsJavier Martinez Canillas
Many OMAP2+ DTS are not using the defined constants to express the GPIO polarity. Replace these so the DTS are easier to read. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-04-22Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "As always, this tends to be one of our bigger branches. There are lots of updates this release, but not that many jumps out as something that needs more detailed coverage. Some of the highlights are: - DTs for the new Annapurna Labs Alpine platform - more graphics DT pieces falling into place on Exynos, bridges, clocks. - plenty of DT updates for Qualcomm platforms for various IP blocks - some churn on Tegra due to switch-over to tool-generated pinctrl data - misc fixes and updates for Atmel at91 platforms - various DT updates to add IP block support on Broadcom's Cygnus platforms - more updates for Renesas platforms as DT support is added for various IP blocks (IPMMU, display, audio, etc)" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits) ARM: dts: alpine: add internal pci Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135." ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB ARM: dts: qcom: Add idle state device nodes for 8064 ARM: dts: qcom: Add idle states device nodes for 8084 ARM: dts: qcom: Add idle states device nodes for 8974/8074 ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs devicetree: bindings: Document qcom,idle-states devicetree: bindings: Update qcom,saw2 node bindings dt-bindings: Add #defines for MSM8916 clocks and resets arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974 arm: dts: qcom: Add LCC nodes arm: dts: qcom: Add TCSR support for MSM8960 arm: dts: qcom: Add TCSR support for MSM8660 arm: dts: qcom: Add TCSR support for IPQ8064 ...
2015-04-03coresight: remove the unnecessary configuration coresight-default-sinkKaixu Xia
The coresight-default-sink configuration option has been removed from the framework. As such remove it from DT and bindings. Signed-off-by: Kaixu Xia <xiakaixu@huawei.com> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-16ARM: dts: omap3: Remove all references to ti,codec propertyMarek Belisko
ti,codec property is not used (parsed) in omap-twl4030 driver. The ti,twl4030-audio which ti,codec points by phandle is mfd driver and device for ASoC codec is created w/o DT compatible string. Removing all references in DT files. Signed-off-by: Marek Belisko <marek@goldelico.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-07coresight: adding support for beagle and beagleXMMathieu Poirier
Currently supporting ETM and ETB. Support for TPIU and SDTI are yet to be added. Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-18ARM: dts: omap: Remove WAKEUPENABLE mux options for UARTsTony Lindgren
This is no longer needed as the device specific wake-up event can now be specified with interrupts-extended property where the second interrupt is the pinctrl-single register, such as the UART3 RX pin. Note that twl4030_omap3.dtsi needs to set WAKEUPENABLE for off-idle to properly trigger the PMIC scripts. And GPIO pins still need to set WAKEUPENABLE for wake-up events. Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-06-16ARM: dts: Enable twl4030 off-idle configuration for selected omapsTony Lindgren
N900 now seems to shut down the external oscillator when hitting off-idle. And Beagle XM seems to have OSC_EN pin connected to allow shutting down the oscillator looking at the schematics. The oscillator output is cut off in off-idle and you can monitor it from R56 on the bottom side of the board near the power jack. Note that for beagle we need to also enable the UART wake-up event, the others have that enabled in earlier patches. OMAP37XX EVM (TMDSEVM3730) does not seem to have twl4030 clken pin connected, so there is no point trying to enable shutting down of the oscillator on it for the extra latency it adds. Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-19ARM: omap3-beagle-xm.dts: add display informationTomi Valkeinen
Add DT data for OMAP3 Beagle-xM board. The board has the following displays: dvi: uses TFP410 encoder to convert DPI to DVI tv: analog svideo Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-02-28ARM: dts: omap3: Set disabled status for McBSP instances as default statePeter Ujfalusi
In omap3.dtsi disable all mcbsp nodes and board dts files can explicitly enable the mcbsp they are using. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-01-07ARM: dts: Split omap3 pinmux core deviceLaurent Pinchart
The omap3_pmx_core pinmux device in the device tree handles the system controller module (SCM) PADCONFS fonction. Its control registers are split in two distinct areas, with other SCM registers in-between. Those other registers can't thus be requested by other drivers as the memory region gets reserved by the pinmux driver. Split the omap3_pmx_core device tree node in two for the two memory regions. The second region address and size depends on the SoC model. The change in omap3.dtsi fixes an "external abort on non-linefetch" when doing cat /sys/kernel/debug/pinctrl/.../pins on a Nokia N900. Note that the core2 padconf region is different for 3430 vs 3630, and does not exist on 3517 as noted by Nishanth Menon <nm@ti.com>. Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-By: Sebastian Reichel <sre@debian.org> Signed-off-by: Nishanth Menon <nm@ti.com> [tony@atomide.com: updated for 3430 vs 3630 core2 based on Nishant's patch] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-11-26ARM: dts: omap3-beagle: Fix USB host on beagle boards (for 3.13)Roger Quadros
Beagle (rev. C4) and Beagle-XM (all revs) need VAUX2 1.8V supply for the USB PHY. As the generic PHY driver can't handle more than one supply at the moment, we configure this supply to be always on. This will cause a very small power impact if the USB host subsystem is not in use, about 76.86 micro-W + LDO power. Older Beagle boards (prior to C4) don't have VAUX2 connected anywhere, so there won't be any functional impact on those boards other than some additional LDO power consumption. Reported-by: Nishanth Menon <nm@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-11-11Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Most of this branch consists of updates, additions and general churn of the device tree source files in the kernel (arch/arm/boot/dts). Besides that, there are a few things to point out: - Lots of platform conversion on OMAP2+, with removal of old board files for various platforms. - Final conversion of a bunch of ux500 (ST-Ericsson) platforms as well - Some updates to pinctrl and other subsystems. Most of these are for DT-enablement of the various platforms and acks have been collected" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits) ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx) ARM: dts: bcm281xx: Add card detect GPIO ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt) ARM: bcm281xx: Add device node for the GPIO controller ARM: mvebu: Add Netgear ReadyNAS 104 board ARM: tegra: fix Tegra114 IOMMU register address ARM: kirkwood: add support for OpenBlocks A7 platform ARM: dts: omap4-panda: add DPI pinmuxing ARM: dts: AM33xx: Add RNG node ARM: dts: AM33XX: Add hwspinlock node ARM: dts: OMAP5: Add hwspinlock node ARM: dts: OMAP4: Add hwspinlock node ARM: dts: use 'status' property for PCIe nodes ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts ARM: mvebu: Add the core-divider clock to Armada 370/XP ...
2013-10-19Merge 3.12-rc6 into usb-next.Greg Kroah-Hartman
We want those USB fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-14Merge branches 'omap-for-v3.13/dt' and 'omap-for-v3.13/quirk' into ↵Tony Lindgren
omap-for-v3.13/board-removal We need the fixes in v3.12-rc5, dts changes in omap-for-v3.13/dt, and the platform data quirk changes in omap-for-v3.13/quirk to start removing omap3 board files without breaking things.
2013-10-11ARM: dts: omap3-beagle-xm: Add USB Host supportRoger Quadros
Provide RESET GPIO and Power regulator for the USB PHY, the USB Host port mode and the PHY device for the controller. Also provide pin multiplexer information for USB host pins. We also relocate omap3_pmx_core pin definations so that they are close to omap3_pmx_wkup pin definations. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2013-10-08ARM: OMAP3: Fix hardware detection for omap3630 when booted with device treeNishanth Menon
SoC family definitions at the moment are reactive to board needs as a result, beagle-xm would matchup with ti,omap3 which invokes omap3430_init_early instead of omap3630_init_early. Obviously, this is the wrong behavior. With clock node dts conversion, we get the following warnings before system hangs as a result and 3630 based platforms fails to boot (uart4 clocks are only present in OMAP3630 and not present in OMAP3430): ... omap_hwmod: uart4: cannot clk_get main_clk uart4_fck omap_hwmod: uart4: cannot _init_clocks WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2434 _init+0x6c/0x80() omap_hwmod: uart4: couldn't init clocks ... WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2126 _enable+0x254/0x280() omap_hwmod: timer12: enabled state can only be entered from initialized, idle, or disabled state ... WARNING: CPU: 0 PID: 46 at arch/arm/mach-omap2/omap_hwmod.c:2224 _idle+0xd4/0xf8() omap_hwmod: timer12: idle state can only be entered from enabled state WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2126 _enable+0x254/0x280() omap_hwmod: uart4: enabled state can only be entered from initialized, idle, or disabled state So, add specific compatiblity for 3630 to allow match for Beagle-XM platform. Signed-off-by: Nishanth Menon <nm@ti.com> [tony@atomide.com: left out ti,omap343x, updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-09-27ARM: dts: omap: update usb_otg_hs dataKishon Vijay Abraham I
Updated the usb_otg_hs dt data to include the *phy* and *phy-names* binding in order for the driver to use the new generic PHY framework. Also updated the Documentation to include the binding information. The PHY binding information can be found at Documentation/devicetree/bindings/phy/phy-bindings.txt Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17ARM: dts: omap3-beagle-xm: fix string error in compatible propertyRobert Nelson
The beagle and beagle-xm entries were inside the same double quote. Split them to have two distinct entries. Signed-off-by: Robert Nelson <robertcnelson@gmail.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2013-06-18ARM: dts: TWL4030: fix mux and wakeup for SYS_NIRQ lineKevin Hilman
On most OMAP3 platforms, the twl4030 IRQ line is connected to the SYS_NIRQ line on OMAP. Add another DTS include file (twl4030_omap3.dtsi) for boards that hook up the twl4030 this way to include. This allows RTC wake from off-mode to work again on OMAP3-based platforms with twl4030. Tested on 3530/Beagle, 3730/Beagle-xM, 3530/Overo, 3730/Overo-STORM. Special thanks to Florian Vaussard for suggesting use of preprocessor feature. Cc: Florian Vaussard <florian.vaussard@epfl.ch> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP3: beagle: enable user button via gpio_keys, enable wakeupKevin Hilman
Using the gpio-keys bindings, configure the user button on Beagle boards. Since the user button is enabled as a wakeup source, also ensure the GPIO pin is mux'd correctly and has IO ring wakeups enabled, so it can also wakeup from off mode. Special thanks to Florian Vaussard for suggesting the preprocessor feature. Cc: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP3: beagle/overo: mux console UART, enable wakeupKevin Hilman
Ensure the console uart (UART3) on these boards is mux'd correctly, and IO ring wakeup is enabled. This is needed for serial console wakeups when using DT boot. Thanks to Florian Vaussard for suggestion to use preprocessor features. Cc: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP2+: Use existing constants for GPIOsFlorian Vaussard
Use standard GPIO constants to enhance the readability of DT GPIOs. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP2+: Use #include for all device treesFlorian Vaussard
Replace /include/ by #include for OMAP2+ DT, in order to use the C pre-processor, making use of #define features possible. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-05-09ARM: dts: don't assume boards are using twl4030 for omap3Jason Cooper
If a board isn't using twl4030, then dtc will complain about the missing phandle (which is in twl4030.dtsi). Move the phy declaration to the dts files. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-04-09ARM: dts: OMAP3: use twl4030 vdd1 regulator for CPUNishanth Menon
Define VDD1 regulator in twl4030 DT and mark it as the supply for the various OMAP34xx/35xx/36xx/37xx platforms (all use TWL4030 variants with VDD1 supplying the CPU). NOTE: This currently will use I2C1 bus communication path to set the voltage in device tree boot. In the legacy non device tree boot, we continue to use twl-common.c which bypasses I2C1 bus communication path and uses I2C4 bus path using OMAP voltage libraries. We should eventually be able to use I2C4 path once we have voltage regulator for OMAP which is capable of using the voltage controller/voltage processor IP blocks. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jon Hunter <jon-hunter@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP: Add usb_otg and glue data to OMAP3+ boardsKishon Vijay Abraham I
Add usb otg data node in omap4/omap3 device tree file. Also update the node with board specific setting in omapx-<board>.dts file. The dt data specifies among others the interface type (ULPI or UTMI), mode which is mostly OTG, power that specifies the amount of power this can supply when in host mode. The information about usb otg node is available @ Documentation/devicetree/bindings/usb/omap-usb.txt Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap3-beagle-xm: Use pwm-leds for pmu_stat LEDPeter Ujfalusi
We have proper driver stack to handle the pmu_stat LED which is connected PWMB of twl4030. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2012-10-29ARM: dts: Add omap3-beagle.dtsJon Hunter
Add a minimal dts for original OMAP3430/3530 version of the Beagle board. This version of the Beagle board has 256MB of DDR and features the same TWL4030 power management IC (PMIC) as the Beagle board XM. Given that the Beagle and Beagle-XM boards use the same PMIC, move the definition of the VSIM regulator into the TWL4030.dtsi file so that we do not need to duplicate in the Beagle board dts file. This has been boot tested on an OMAP3530 Beagle board and verifing that the SD/MMC interface is working with a SD card. V2 changes - Rebased upon of devel-dt - Corrected copyright date in omap3-beagle.dts file - Added LED support after verifing that Beagle and Beagle XM have the same LED configuration Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-09-10arm/dts: Add omap36xx.dtsi file and rename omap3-beagle to omap3-beagle-xmTony Lindgren
The extra serial port is not available on 34xx. And the current omap3-beagle.dts file is for omap3-beagle-xm.dts as it lists 512MB of memory. Please somebody submit a new omap3-beagle.dts for the original 34xx BeagleBoard after testing it properly. Cc: Benoit Cousson <b-cousson@ti.com> Cc: devicetree-discuss@lists.ozlabs.org Signed-off-by: Tony Lindgren <tony@atomide.com>
