Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
This patch fixes the following DTC warnings for omap3-igep0020.dtb
and omap3-igep0020-rev-f.dtb:
"encoder@0 has a unit name, but no reg property"
"endpoint@0 has a unit name, but no reg property"
"connector@0 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
A host device that supports write protection should refuse to write to
an SD card that is designated read-only when write-protect is set. This
is an optional feature of the SD specification.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Use the OMAP3 pinmux IOPAD macro to define the physical address instead
of the offset from the padconf address. It makes the DTS easier to read
since matches the addresses listed in the Technical Reference Manual.
I see that people are still sending emails to my old address (that no
longer exists) since is the one mentioned in the IGEP DTS. Replace it
with my current email address to avoid this.
Only the IGEPv2 boards have a LAN9221i chip connected to the GPMC
so the pinmux configuration for the GPIO connected to the IRQ line
of the LAN chip should not be defined in the IGEP common dtsi but
in the one common to the IGEPv2 boards.
While there, use the OMAP3_CORE1_IOPAD() macro for the padconf reg.
Suggested-by: Ladislav Michl <ladis@linux-mips.org>
Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Use the omap3-igep0020-common.dtsi file and remove repeated parts leaving
the nodes that are not common between IGEPv2 hardware revisions.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
