When the WiFi support was added to the IGEP0020 board, the MMC subsystem
did not provide a mechanism to define power sequence providers. So a DT
hack was used to toggle the WiFi chip reset and power down pins by using
fake fixed regulators whose enable GPIO was the GPIOs connected to these
pins.
But now the simple MMC power sequence provider can be used for this and
the workaround removed.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Enric Balletbo Serra <enric.balletbo@collabora.com>
I see that people are still sending emails to my old address (that no
longer exists) since is the one mentioned in the IGEP DTS. Replace it
with my current email address to avoid this.
uart2 pinmux is already defined in omap3-igep0020-common.dtsi, remove
the duplicate node.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Javier Martinez Canillas <javier@osg.samsung.com>
Use the omap3-igep0020-common.dtsi file and remove repeated parts leaving
the nodes that are not common between IGEPv2 hardware revisions.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
New IGEP boards revisions will use another Wifi module, so this patch moves
the DT nodes outside the common omap3-igep.dtsi file to specific DT for every
board.
We'll introduce new hardware revisions soon. This patch is only to
indicate which board revision supports this device tree file in order
to avoid confusions.
At this moment all supported boards use same NAND chip, so has more sense
move the GPMC and NAND configuration to the omap3-igep.dtsi common place.
UART2 is used to connect the processor with the bluetooth chip, these pins
are not common between IGEPv2 boards and IGEP COM MODULE boards. This patch
muxes the correct pins for every board and removes UART2 configuration from
common omap3-igep.dtsi file.
Looks like we have some GPMC NAND timings missing device
width. This fixes "gpmc_cs_program_settings: invalid width 0!"
errors during boot.
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Acked-by: Roger Quadros <rogerq@ti.com>
The IGEPv2 board has a SMSC LAN9221i ethernet chip and not a
SMSC LAN911x connected to the GPMC. Each chip needs different
timings in order to operate correctly so is wrong to include
omap-gpmc-smsc911x.dtsi instead of omap-gpmc-smsc9221.dtsi.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
[tony@atomide.com: this is needed to avoid potential memory corruption]
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull OMAP fbdev changes from Tomi Valkeinen:
"This is based on the already pulled fbdev-main changes, and this also
merges .dts branch from Tony Lindgren (which has also been pulled), so
that I was able to add the display related .dts changes.
This contains OMAP related fbdev changes for 3.15. The bulk of the
patches are for adding Device Tree support for OMAP Display Subsystem:
- SoCs: OMAP2/3/4
- Boards: OMAP4 Panda, OMAP4 SDP, OMAP3 Beagle, OMAP3 Beagle-xM,
OMAP3 IGEP0020, OMAP3 N900
- Devices: TFP410 Encoder, tpd12s015 HDMI companion chip, Sony
acx565akm panel, MIPI DSI Command mode panel and HDMI, DVI and
Analog TV connectors"
* tag 'fbdev-omap-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (45 commits)
OMAPDSS: HDMI: fix interlace output
OMAPDSS: add missing __init for dss_init_ports
ARM: OMAP2+: remove pdata quirks for displays
OMAPDSS: remove DT hacks for regulators
Doc/DT: Add DT binding documentation for tpd12s015 encoder
Doc/DT: Add DT binding documentation for TFP410 encoder
Doc/DT: Add DT binding documentation for Sony acx565akm panel
Doc/DT: Add DT binding documentation for MIPI DSI CM Panel
Doc/DT: Add DT binding documentation for HDMI Connector
Doc/DT: Add DT binding documentation for DVI Connector
Doc/DT: Add DT binding documentation for Analog TV Connector
ARM: omap3-n900.dts: add display information
ARM: omap3-igep0020.dts: add display information
ARM: omap3-beagle-xm.dts: add display information
ARM: omap3-beagle.dts: add display information
ARM: omap4-sdp.dts: add display information
Doc/DT: Add DT binding documentation for OMAP DSS
OMAPDSS: acx565akm: Add DT support
OMAPDSS: connector-analog-tv: Add DT support
OMAPDSS: hdmi-connector: Add DT support
Add DT data for OMAP3 IGEPv2 board. The board has the following displays:
dvi: uses TFP410 encoder to convert DPI to DVI
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
This patch is based on commit:
016c12d2 ("ARM: OMAP3: Fix hardware detection for omap3630 when booted with device tree")
and fixes a boot hang due the IGEP board being wrongly initialized
as an OMAP3430 platform instead of an OMAP3630.
The omap3_pmx_core pinmux device in the device tree handles the system
controller module (SCM) PADCONFS fonction. Its control registers are
split in two distinct areas, with other SCM registers in-between. Those
other registers can't thus be requested by other drivers as the memory
region gets reserved by the pinmux driver.
Split the omap3_pmx_core device tree node in two for the two memory
regions. The second region address and size depends on the SoC model.
The change in omap3.dtsi fixes an "external abort on non-linefetch" when
doing
cat /sys/kernel/debug/pinctrl/.../pins
on a Nokia N900.
Note that the core2 padconf region is different for 3430 vs 3630,
and does not exist on 3517 as noted by Nishanth Menon <nm@ti.com>.
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-By: Sebastian Reichel <sre@debian.org>
Signed-off-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: updated for 3430 vs 3630 core2 based on Nishant's patch]
On Device Tree boot the VDDS_DSI regulator is not linked to
the DPI device so omapfb driver probing fails with:
[ 3.186035] OMAPFB: omapfb_probe
[ 3.190704] omapdss DPI error: can't get VDDS_DSI regulator
[ 3.196594] omapfb omapfb: failed to connect default display
[ 3.202667] omapfb omapfb: failed to init overlay connections
[ 3.208892] OMAPFB: free_resources
[ 3.212493] OMAPFB: free all fbmem
[ 3.216735] omapfb omapfb: failed to setup omapfb
As a workaround name the VPLL2 regulator from twl4030 as vdds_dsi
so getting the VDDS_DSI regulator will succeed on dpi_init_regulator().
The IGEPv2 has a TFP410 DPI-to-DVI encoder attached to OMAP's
Display SubSystem (DSS).
Add mux setup for DSS pins and also for the GPIO 170 pin that
is used to ensure that the DVI-D is powered down on power up.
Most of the boards are using the TI AM/DM37x processor, there is only a small
quantity of IGEP Processor Boards based on TI OMAP3530. So it's better use the
omap36xx.dtsi include instead of omap34xx.dtsi include. We can add support
for the 34xx based variant later on as needed.
To avoid confusion we have added to the model the (TI AM/DM37x) comment.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
[tony@atomide.com: updated comments for the 34xx to 36xx include change]
Looks like at least Igep, Zoom and EVM boards can use a
common file for the GPMC connected smsc911x.
Commit 840ef8b7 ("ARM: dt: add header to define IRQ flags") added
constants for IRQ edge/level triggered types so use it instead of
a magic number to enhance the DT readability.
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
Add device nodes for the HS USB Host port 1, USB PHY and its
required regulator and also pin mux setup for HS USB1 pins.
Tested-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The IGEPv2 has a number of GPIO LED connected to OMAP
pins. Configure these pins as output GPIO.
Tested-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Use standard GPIO constants to enhance the readability of DT GPIOs.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
The IGEPv2 board has an 512MB NAND flash memory.
Add a device node for this NAND and its partition layout.
The IGEPv2 board has an SMSC LAN9221i ethernet chip connected to
the OMAP3 processor though the General-Purpose Memory Controller.
This patch adds a device node for the ethernet chip as a GPMC child
and all its dependencies (regulators, GPIO and pin muxs).
ISEE IGEPv2 is an TI OMAP3 SoC based embedded board.
This patch adds an initial device tree support to boot
an IGEPv2 from the MMC/SD.
Currently is working everything that is supported by DT
on OMAP3 SoCs (MMC/SD, GPIO LEDs, EEPROM, TWL4030 audio).
[benoit.cousson@linaro.org: Update the Makefile for 3.8-rc2]
