Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup
source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
Many OMAP2+ DTS are not using the defined constants to express
the GPIO polarity. Replace these so the DTS are easier to read.
Fix ldp gpio keys to use defines.
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
Looks like we're still missing the keypad map for LDP.
Let's add it since we have the binding now available
for the twl4030_keypad as otherwise we get the following
errors during the boot:
twl4030_keypad keypad.31: OF: linux,keymap property not defined
in /ocp/i2c@48070000/twl@48/keypad
twl4030_keypad keypad.31: Failed to build keymap
twl4030_keypad: probe of keypad.31 failed with error -2
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Fix the following warning during the boot:
mtd: partition "Filesystem" extends beyond the end of device
"omap2-nand.0" -- size truncated to 0x6000000
Looks like I got the last partition size wrong while setting
up the .dts file. Note that this does not affect the partition
as the size has been getting truncated to the right size.
Looks like we have some GPMC NAND timings missing device
width. This fixes "gpmc_cs_program_settings: invalid width 0!"
errors during boot.
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Acked-by: Roger Quadros <rogerq@ti.com>
With the IO chain reconfigure fixed, we can now enable the PMIC
scripts for LDP.
Note that at least on my es3.0 based LDP, the UART seems to be
flakey after wake-up events from off-idle and hangs but eventually
continues.
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull OMAP DT fbdev updates from Tomi Valkeinen:
"Here are display related device tree data changes for OMAP. They are
based on an already merged branch to satisfy the dependencies for the
dts file changes.
Add OMAP DT data:
- omap5 display subsystem
- display data for omap5 uEVM board
- am43xx display subsystem
- display data for am43xx ePOS and GP boards (LCD only)
- display data for GTA04 board
- display data for overo board
- display data for duovero-parlor board
- display data for omap3 evm and ldp boards"
* tag 'fbdev-omap-dt-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
ARM: omap5.dtsi: Add audio related parameters to hdmi node
ARM: omap4.dtsi: Add audio related parametes to hdmi node
ARM: dts: duovero-parlor: Add HDMI output
ARM: dts: overo: Add support for 3.5'' LCD output
ARM: dts: overo: Add support for 4.3'' LCD output
ARM: dts: overo: Add support for DVI output
ARM: dts: Add LCD panel sharp ls037v7dw01 support for omap3-evm and ldp
ARM: dts: omap3-gta04: Add display support
ARM: dts: omap5-uevm.dts: add display nodes
ARM: dts: omap5-uevm.dts: add tca6424a
ARM: dts: omap5.dtsi: add DSS nodes
ARM: dts: am43x-epos-evm: add LCD data
ARM: dts: am437x-gp-evm: add LCD data
ARM: dts: am4372.dtsi: add DSS information
Looks like quite a few omap3 boards have sharp ls037v7dw01 that's
configured as various panel dpi entries for whatever legacy reasons.
For device tree based support, let's just configure these properly for
panel ls037v7dw01 instead of panel dpi.
This patch creates a common file for panel ls037v7dw01, and makes
boards ldp and omap3-evm to use it.
The ls037v7dw01 also seems to be coupled with an ad7846 touchscreen
controller for the omaps, so let's add a basic configuration for
the touchscreen also using the default values.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
We've had deeper idle states working on omaps for few years now,
but only in the legacy mode. When booted with device tree, the
wake-up events did not have a chance to work until commit
3e6cee1786a1 (pinctrl: single: Add support for wake-up interrupts)
that recently got merged. In addition to that we also needed commit
79d9701559a9 (of/irq: create interrupts-extended property) and
9ec36cafe43b (of/irq: do irq resolution in platform_get_irq) that
are now also merged.
So let's fix the wake-up events for some selected omaps so devices
booted in device tree mode won't just hang if deeper power states
are enabled, and so systems can wake up from suspend to the serial
port event.
Note that there's no longer need to specify the wake-up bit in
the pinctrl settings, the request_irq on the wake-up pin takes
care of that.
Cc: devicetree@vger.kernel.org
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Nishanth Menon <nm@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
[tony@atomide.com: updated comments, added board LDP]
MMC1 is the only MMC interface available on the platform. Further,
since the platform is based on older revision of SoC which is not
capable of doing multi-block reads, mark it with compatibility for the
same and add pinmux to ensure that all relevant pins are configured
for non-MMC boot mode.
Signed-off-by: Nishanth Menon <nm@ti.com>
Acked-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Chris Ball <chris@printf.net>
Basic things like serial, Ethernet, MMC, NAND, DSS, touchscreen
and GPIO keys work.
For twl4030-keypad we're still missing the binding, but
support for that should be trivial to add once the driver
has been updated.
MUSB I'm pretty sure I got got to enumerate once, but I
suspect the battery charging somehow disrupts it and it's
not enumerating in general for some reason.
Patches are welcome to improve things if people are
still using this board.
For reference, here's some more info on this old board:
http://www.openomap.org/wiki/tiki-index.php?page=HardwareInfo
