This reverts commit 2f1f60c4b903f0f5464560783655ff74c9663a92 which was
commit 7be4b5dc7ffa9499ac6ef33a5ffa9ff43f9b7057 upstream.
It requires a driver that was not merged until 4.16, so remove it from
this stable tree as it is pointless.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Andrew F. Davis <afd@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Sasha Levin <alexander.levin@microsoft.com>
[ Upstream commit 7be4b5dc7ffa9499ac6ef33a5ffa9ff43f9b7057 ]
The correct DT property for specifying a GPIO used for reset
is "reset-gpios", fix this here.
Fixes: 14e3e295b2b9 ("ARM: dts: omap3-n900: Add TLV320AIC3X support")
Signed-off-by: Andrew F. Davis <afd@ti.com>
Sakari mentioned that some parts of the dts are not needed and do
not have proper documentation, yet.
As the camera works without them, remove them for now.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Add camera support to N900 dts. Also add a note about MMC & debugging.
Acked-by: Pali Rohár <pali.rohar@gmail.com>
Replace deprecated "vmmc_aux" with the generic "vqmmc" binding for
MMC IO supply.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Add bcm2048 node and its system clock to the N900 device tree file.
Apart from that a reference to the new clock has been added to
wl1251 (which uses it, too).
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Device tree changes for omaps for v4.11 merge window. These
changes add earlycon stdout-path propety for the SoCs so far
tested with it. The other changes are addition of BeagleBone
green and making WLAN work on BeagleBone black wireless and
green wireless. The rest of the changes are the usual enabling
features on various devices:
- Enable devices on am335x-sl50
- Changes to dra7-evm boards to enable enable irqs for dp83867
eth phys, add pinmux configuration for mmc, remov erratum
i869 pinmux configurations, disable NAND support because of
pin conflict, add pcf8575 used for lcd
- Remove NAND partition table for omap3-igep
- Configure USB Ethernet MAC from device tree for beagleboard
xm, pandaboard, omap5-uevm and igepv5
- Configure am335x-chilisom to wake from RTC-only state
- Update Nanobone for external FRAM chip
- Clean up n900 dts
- Update am335x-phycore and am335x-wega for various devices
- Changes for am57xx-beagle-x15 to implement rgmii2 errata
* tag 'omap-for-v4.11/dt-signed-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (35 commits)
ARM: dts: dra72/1-evm: add pcf8575 used for lcd
ARM: dts: dra7xx: Add stdout-path property
ARM: dts: am57xx: Add stdout-path property
ARM: dts: am43xx: Add stdout-path property
ARM: dts: am33xx: Add stdout-path property
ARM: dts: am335x-sl50: Enable the Ambient Light Sensor.
ARM: dts: am335x-sl50: Enable the MCP23017 GPIO Expander.
ARM: dts: am335x-sl50: Enable BQ32000 Real Time Clock.
ARM: dts: am335x-sl50: Enable SPI0 interface and Flash Memory.
ARM: dts: am335x-sl50: Enable UART1.
ARM: dts: am335x-sl50: Remove I2C1 node.
ARM: dts: omap3-igep: Remove NAND partition table
ARM: dts: am57xx-beagle-x15: implement errata "Ethernet RGMII2 Limited to 10/100 Mbps"
ARM: dts: am335x-phycore-som: Remove partition tables
ARM: dts: dra72-evm-revc: enable irqs for dp83867 eth phys
ARM: dts: Configure BeagleBone peripheral USB VBUS irq
ARM: dts: omap5-igep0050: Allow bootloader to configure USB Ethernet MAC
ARM: dts: omap5-uevm: Allow bootloader to configure USB Ethernet MAC
ARM: dts: pandaboard: Allow bootloader to configure USB Ethernet MAC
ARM: omap3: beagleboard-xm: dt: Add ethernet to the device tree
Fix GPIO comment to be consistent with rest of file and add comment what
tpa6130 is.
Reviewed-By: Sebastian Reichel <sre@kernel.org>
Reviewed-By: Pali Rohár <pali.rohar@gmail.com>
Trying to initialize eMMC slot as SDIO or SD cause failure in n900 port of
qemu. eMMC itself is not detected and is not working.
Real Nokia N900 harware does not have this problem. As eMMC is really not
SDIO or SD based such change is harmless and will fix support for qemu.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
This patch fixes the following DTC warnings for omap3-n900.dtb:
"dmtimer-pwm@9 has a unit name, but no reg property"
Add the needed DT data to enable IR TX driver
Signed-off-by: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
DTS fixes for omaps for v4.7 merge window for issues noted
with patches in Linux next:
- Fix omap5 and am57xx-idk input voltages to fix micro-sd
probing at least for some omap5-uevm configurations
- Fix unhandled fault for igepv5 audio
- Fix UART wakeirqs for omap5 by removing WAKUP_EN flags,
those are managed by the wakeirq and can currently confuse
the wakeirqs as there is no handler necessarily registered
- Fix LDO7 source for igepv5
Also included are few minor changes not strictly fixes
are good to have merged:
- Fix HP T410 boot time warnings for eMMC and disable the
unused MMC interfaces while at it
- Add dra7 gpmc dma channel
- Add igep00x0 SD card detect and write protect GPIOs
* tag 'omap-for-v4.7-dts-fixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: igep0020: Add SD card write-protect pin.
ARM: dts: igep00x0: Add SD card-detect.
ARM: dts: am57xx-idk-common: Fix input supply names
ARM: dts: dra7: Add gpmc dma channel
ARM: dts: disable mmc by default and enable when needed for dm814x
ARM: dts: Add non-removable to hsmmc on hp-t410
ARM: dts: Fix ldo7 source for HDMI on igepv5
ARM: dts: Fix uart wakeirq on omap5 by removing WAKEUP_EN for omaps
ARM: dts: Fix igepv5 audiopwon-gpio
ARM: dts: omap5-board-common: Describe the voltage supply mapping accurately
The padconf register WAKEUP_EN is now handled in a generic way using
Linux wakeirqs where pinctrl-single toggles the WAKEUP_EN bit when
a wakeirq is enabled or disabled.
At least omap5 gets confused if the WAKEUP_EN bit is set and the pin
is not claimed as a wakeirq. The end result is that wakeirqs don't
work properly as there is nothing handling the wakeirq.
So let's just remove the WAKEUP_EN usage from dts files.
Without that, regulators are left in the mode last set by the bootloader or
by the kernel the device was rebooted from. This leads to various problems,
like non-working peripherals.
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
This change does not break existing userspace or Maemo software because
isp1704_charger.c always export power supply device under isp1704 name.
This makes DTS structure more readable.
Acked-By: Sebastian Reichel <sre@kernel.org>
Add linux,can-disable; to all gpios exported from gpio-keys driver, so
userspace can disable them
This patch adds adp1653 device into n900 DT structure. DT support in
adp1653 driver is there since v4.2-rc1 version.
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup
source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
Fix dts to match what the Linux kernel expects. This works around
touchscreen problems in 4.1 linux on Nokia n900.
Reviewed-by: Felipe Balbi <balbi@ti.com>
N900 audio recording needs that codec provides bias voltage for integrated
digital microphone and headset microphone depending which one is used.
Digital microphone uses 2 V bias and it comes from the codec A part. Codec
B part drives the headset microphone bias and that is set to 2.5 V.
Cc: stable@vger.kernel.org # v3.16+
[Jarkko: Headset mic bias changed to 2 (2.5 V) as it was before commit
e2e8bfdf6157 ("ASoC: tlv320aic3x: Convert mic bias to a supply widget")]
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
This adds support for the N900's accelerometer to
the Nokia N900 DTS file.
Reviewed-by: Éric Piel <eric.piel@tremplin-utc.net>
This patch moves content of file omap34xx-hs.dtsi into omap3-n900.dts and enable
omap sham support (omap HW support for SHA + MD5). After testing both omap hwmod
and omap-sham.ko drivers it looks like signed Nokia X-Loader enable L3 firewall
for omap sham. There is no kernel crash with both official bootloader and crypto
enable bootloader. So we can safely enable sham code.
Offset for smc91x must be zero otherwise smc91x linux kernel driver does not
detect smc91x ethernet hardware in qemu N900 machine.
The 0x300 offset was used to supress a warning the smsc911x
driver produces about non-standard offset as 0x300 seems to
be the EEPROM default. As only three address lines are
connected both 0 and 0x300 will work just fine with 0 being
correct. The warning about the non-standard offset can be
fixed by writing to EEPROM as that's needed in any case to
set the MAC address.
[tony@atomide.com: updated comments, just use 0 instead of 0x0]
With legacy boot i2c buses on Nokia N900 are numbered i2c1, i2c2 and i2c3.
Commit 20b80942ef4e ("ARM: dts: OMAP3+: Add i2c aliases") fixed the
numbering with DT boot, but introduced a regression on N900 - aliases
become i2c0, i2c1 and i2c2. Fix that by providing the correct aliases in
the board dts.
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: this is needed for legacy user space to work]
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
This fixes english in comments and removes extra empty newline.
Revert "ARM: dts: Disable smc91x on n900 until bootloader
dependency is removed". We've now fixed the issues that
caused problems with uninitialized hardware depending on
the bootloader version. Mostly things got fixed with
the following commits:
9a894953a97b ("ARM: dts: Fix bootloader version dependencies by muxing n900 smc91x pins")
7d2911c43815 ("net: smc91x: Fix gpios for device tree based booting")
Note that this only affects the early development boards
with Ethernet that we still have in a few automated boot
test systems. And it's also available supposedly in some
versions of qemu.
Tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Pull "More dts changes for omaps to add support for new devices" from Tony Lindgren:
- Add DCAN support am335x, am437x and dra7
- Add devices for sb-t3x computers
- Add support for NovaTech OrionLXm
- Add n900 battery and si4713 support
* tag 'omap-for-v3.19/dt-part2-updated' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (26 commits)
ARM: dts: am335x-evm: Add DCAN1 details
ARM: dts: am33xx: Update DCAN nodes
ARM: dts: am33xx: Add control module syscon node
ARM: dts: am437x-gp: Add dcan support
ARM: dts: am4372: Add DCAN nodes
ARM: dts: am4372: Add control module syscon node
ARM: dts: dra72-evm: Add CAN support
ARM: dts: dra7-evm: Add CAN support
ARM: dts: DRA7: Add DCAN nodes
ARM: dts: dra7: Add syscon regmap for CORE CONTROL area
ARM: dts: sbc-t3x30: add audio support
ARM: dts: sbc-t3x: add TV out display alias
ARM: dts: cm-t3x: add TV out support
ARM: dts: cm-t3x: add I2C1 pinmux
ARM: dts: AM43xx: add tscadc DT entries for am437x-evm and am43x-epos-evm
ARM: dts: cm-t3x30: add keypad support
ARM: dts: sb-t35: add EEPROM support
ARM: dts: cm-t3x: add EEPROM support
ARM: OMAP2+: remove cm-t3x touchscreen pdata quirk
ARM: dts: cm-t3x: add ADS7846 touchscreen support
This adds support for the N900's battery to the
Add si4713 node to the N900 device tree file.
Pull "Device tree related changes for omaps" from Tony Lindgren:
- Fix currently harmless but wrong sizes for various GPMC connected
devices
- Set up timings for several GPMC connected devices to get rid of
bootloader dependencies in later patches
- Enable various drivers for dra7xx
- Prepare Igep boards to support new variants
- Add intial support for BeagleBoard-X15
* tag 'omap-for-v3.19/dt-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (37 commits)
ARM: dts: DRA7: Add aliases for all serial ports
ARM: dts: Add am57xx-beagle-x15
ARM: OMAP2+: igep00x0: Add pdata-quirks for the btwilink device.
ARM: dts: omap3-igep00x0: Remove i2c2 node.
ARM: dts: omap3-igep0020-rev-f: Support IGEPv2 Rev. F
ARM: dts: omap3-igep0020-common: Introduce igep0020 common dtsi file.
ARM: dts: omap3-igep0030-rev-g: Support IGEP COM MODULE Rev. G
ARM: dts: omap3-igep0030-common: Introduce igep0030 common dtsi file.
ARM: dts: omap3-igep00x0: Move outside common file the on board Wifi module.
ARM: dts: omap3-igep0020: Specify IGEPv2 revision in device tree.
ARM: dts: omap3-igep0030: Specify IGEP COM revision in device tree.
ARM: dts: omap3-igep00x0: Move NAND configuration to a common place.
ARM: dts: omap3-igep00x0: Fix UART2 pins that aren't common.
ARM: dts: dra7: add labels to DWC3 nodes
ARM: dts: dra72x-evm: Enable CPSW and MDIO
ARM: dts: dra7-evm: Keep all VDD rails always-on
ARM: dts: dra72-evm: Add MMC nodes
ARM: dts: dra72-evm: Add power button node
ARM: dts: dra72-evm: Provide explicit pinmux for TPS PMIC
ARM: dts: dra72-evm: Add regulator information to USB2 PHYs
Pull networking fixes from David Miller:
"A bit has accumulated, but it's been a week or so since my last batch
of post-merge-window fixes, so...
1) Missing module license in netfilter reject module, from Pablo.
Lots of people ran into this.
2) Off by one in mac80211 baserate calculation, from Karl Beldan.
3) Fix incorrect return value from ax88179_178a driver's set_mac_addr
op, which broke use of it with bonding. From Ian Morgan.
4) Checking of skb_gso_segment()'s return value was not all
encompassing, it can return an SKB pointer, a pointer error, or
NULL. Fix from Florian Westphal.
This is crummy, and longer term will be fixed to just return error
pointers or a real SKB.
6) Encapsulation offloads not being handled by
skb_gso_transport_seglen(). From Florian Westphal.
7) Fix deadlock in TIPC stack, from Ying Xue.
8) Fix performance regression from using rhashtable for netlink
sockets. The problem was the synchronize_net() invoked for every
socket destroy. From Thomas Graf.
9) Fix bug in eBPF verifier, and remove the strong dependency of BPF
on NET. From Alexei Starovoitov.
10) In qdisc_create(), use the correct interface to allocate
->cpu_bstats, otherwise the u64_stats_sync member isn't
initialized properly. From Sabrina Dubroca.
11) Off by one in ip_set_nfnl_get_byindex(), from Dan Carpenter.
12) nf_tables_newchain() was erroneously expecting error pointers from
netdev_alloc_pcpu_stats(). It only returna a valid pointer or
NULL. From Sabrina Dubroca.
13) Fix use-after-free in _decode_session6(), from Li RongQing.
14) When we set the TX flow hash on a socket, we mistakenly do so
before we've nailed down the final source port. Move the setting
deeper to fix this. From Sathya Perla.
15) NAPI budget accounting in amd-xgbe driver was counting descriptors
instead of full packets, fix from Thomas Lendacky.
16) Fix total_data_buflen calculation in hyperv driver, from Haiyang
Zhang.
17) Fix bcma driver build with OF_ADDRESS disabled, from Hauke
Mehrtens.
18) Fix mis-use of per-cpu memory in TCP md5 code. The problem is
that something that ends up being vmalloc memory can't be passed
to the crypto hash routines via scatter-gather lists. From Eric
Dumazet.
19) Fix regression in promiscuous mode enabling in cdc-ether, from
Olivier Blin.
20) Bucket eviction and frag entry killing can race with eachother,
causing an unlink of the object from the wrong list. Fix from
Nikolay Aleksandrov.
21) Missing initialization of spinlock in cxgb4 driver, from Anish
Bhatt.
22) Do not cache ipv4 routing failures, otherwise if the sysctl for
forwarding is subsequently enabled this won't be seen. From
Nicolas Cavallari"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (131 commits)
drivers: net: cpsw: Support ALLMULTI and fix IFF_PROMISC in switch mode
drivers: net: cpsw: Fix broken loop condition in switch mode
net: ethtool: Return -EOPNOTSUPP if user space tries to read EEPROM with lengh 0
stmmac: pci: set default of the filter bins
mpls: Allow mpls_gso to be built as module
mpls: Fix mpls_gso handler.
r8152: stop submitting intr for -EPROTO
netfilter: nft_reject_bridge: restrict reject to prerouting and input
netfilter: nft_reject_bridge: don't use IP stack to reject traffic
netfilter: nf_reject_ipv6: split nf_send_reset6() in smaller functions
netfilter: nf_reject_ipv4: split nf_send_reset() in smaller functions
netfilter: nf_tables_bridge: update hook_mask to allow {pre,post}routing
drivers/net: macvtap and tun depend on INET
drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets
drivers/net: Disable UFO through virtio
net: skb_fclone_busy() needs to detect orphaned skb
gre: Use inner mac length when computing tunnel length
mlx4: Avoid leaking steering rules on flow creation error flow
net/mlx4_en: Don't attempt to TX offload the outer UDP checksum for VXLAN
With legacy booting, the platform init code was taking care of
the configuring of GPIOs. With device tree based booting, things
may or may not work depending what bootloader has configured or
if the legacy platform code gets called.
Let's add support for the pwrdn and reset GPIOs to the smc91x
driver to fix the issues of smc91x not working properly when
booted in device tree mode.
And let's change n900 to use these settings as some versions
of the bootloader do not configure things properly causing
errors.
Reported-by: Kevin Hilman <khilman@linaro.org>
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Acked-by: Roger Quadros <rogerq@ti.com>
Apparently some versions of nolo don't mux the all the necessary GPMC
pins for the smc91x probe to work properly. Let's fix this issue
by adding mux support for GPMC to the kernel.
Note that GPMC clk needs input enabled for OnenNAND to work.
Cc: Kevin Hilman <khilman@kernel.org>
Cc: Roger Quadros <rogerq@ti.com>
I added smc91x support but turns out we currently do not set the
smc91x timings in gpmc.c but rely on the bootloader timings. This
produces the following error unless the smc91x GPMC timings are
initialized by the bootloader:
Unhandled fault: external abort on non-linefetch (0x1008) at 0xd080630e
[<c04067fc>] (smc_drv_probe) from [<c038e9c4>] (platform_drv_probe+0x2c/0x5c)
[<c038e9c4>] (platform_drv_probe) from [<c038d450>] (driver_probe_device+0x104/0x22c)
[<c038d450>] (driver_probe_device) from [<c038d60c>] (__driver_attach+0x94/0x98)
[<c038d60c>] (__driver_attach) from [<c038bc3c>] (bus_for_each_dev+0x54/0x88)
[<c038bc3c>] (bus_for_each_dev) from [<c038cc3c>] (bus_add_driver+0xd8/0x1d8)
[<c038cc3c>] (bus_add_driver) from [<c038dd74>] (driver_register+0x78/0xf4)
[<c038dd74>] (driver_register) from [<c0008924>] (do_one_initcall+0x80/0x1c0)
[<c0008924>] (do_one_initcall) from [<c0852d9c>] (kernel_init_freeable+0x1b8/0x28c)
[<c0852d9c>] (kernel_init_freeable) from [<c05ce86c>] (kernel_init+0x8/0xec)
[<c05ce86c>] (kernel_init) from [<c000e728>] (ret_from_fork+0x14/0x2c)
Let's fix the issue by disabling the smc91x module for now until we
have sorted out the issues in gpmc.c.
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
As we have support for this in board-rx51-peripherals.c, let's
add it to the .dts files too.
Note that the reset GPIO will eventually go to the driver.
For now let's just pull it down and skip any further reset
in case the bootloader has configured the MAC address so
NFSroot works.
Also note that after 3430-sdp are using proper GPMC timings
we can remove the tests for smsc,lan91c94 in gpmc.c.
There are external pulls on these lines and enabling the
internal pulls can cause issue. This is because the internal
pulls are parallel with the external pulls. So let's clear
the internal I2C pulls.
The quite-recently-added analog-tv-connector bindings say that the
compatible string for composite video connector is
"composite-connector". That string is also used in the omap3-n900.dts
file. However, the connector driver uses "composite-video-connector", so
this has never worked.
While changing the driver's compatible string to "composite-connector"
would be safer, as published DT bindings should not be changed, I'd
rather fix the bindings in this case for two reasons:
* composite-connector is a bit too generic name, as it doesn't even hint
at video.
* it's clear that this has never worked, which means no one has used
those bindings, which should make it safe to change this.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
regulators
Commit 43fef47f94a1 (mfd: twl4030-power: Add a configuration to turn
off oscillator during off-idle) added support for configuring the PMIC
to cut off resources during deeper idle states to save power.
This however caused regression for n900 display power that needed the
PMIC configuration to be disabled with commit d937678ab625 (ARM: dts:
Revert enabling of twl configuration for n900).
Turns out the root cause of the problem is that we must use
TWL4030_RESCONFIG_UNDEF instead of DEV_GRP_NULL to avoid disabling
regulators that may have been enabled before the init function
for twl4030-power.c runs. With TWL4030_RESCONFIG_UNDEF we let the
regulator framework control the regulators like it should. Here we
need to only configure the sys_clken and sys_off_mode triggers for
the regulators that cannot be done by the regulator framework as
it's not running at that point.
This allows us to enable the PMIC configuration for n900.
Fixes: 43fef47f94a1 (mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle)
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Commit 9188883fd66e9 (ARM: dts: Enable twl4030 off-idle configuration
for selected omaps) allowed n900 to cut off core voltages during
off-idle. This however caused a regression where twl regulator
vaux1 was not getting enabled for the LCD panel as we are not
requesting it for the panel.
Turns out quite a few devices on n900 are using vaux1, and we need
to either stop idling it, or add proper regulator_get calls for all
users. But until we have a proper solution implemented and tested,
let's just disable the twl off-idle configuration for now for n900.
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Fixes: 9188883fd66e9 (ARM: dts: Enable twl4030 off-idle configuration for selected omaps)
N900 now seems to shut down the external oscillator when hitting
off-idle.
And Beagle XM seems to have OSC_EN pin connected to allow shutting
down the oscillator looking at the schematics. The oscillator
output is cut off in off-idle and you can monitor it from R56 on
the bottom side of the board near the power jack. Note that for
beagle we need to also enable the UART wake-up event, the others
have that enabled in earlier patches.
OMAP37XX EVM (TMDSEVM3730) does not seem to have twl4030 clken
pin connected, so there is no point trying to enable shutting
down of the oscillator on it for the extra latency it adds.
