Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
This patch fixes the following DTC warnings for many boards:
"Node /gpio_keys/button0@10 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup
source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: "BenoƮt Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Chestnut43, Gallop43 and Palo43 expansion boards have a ZIF connector
for a 4.3'' LCD. Add a common include file for this configuration, and
use it on relevant expansion boards.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Palo43 is an expansion board for Gumstix Overo products.
